2215-G111-P1M1-S0-0.2A 数据手册
Thermal-Magnetic Circuit Breaker 2215-L.../G...
Description
Miniaturised single pole thermal-magnetic circuit breakers with trip-free
mechanism and toggle actuation (S-type TM CBE to EN 60934). Two
designs provide the option of either printed circuit board or threadneck
panel mounting. A separate shunt tap terminal and auxiliary contacts
are available. Fast acting, medium or long delay characteristics can be
specified for both models.
Suitable for use in distribution rails – see section Power Distribution
Systems.
Complies with CBE standard EN 60934 (IEC 60935).
1
Typical applications
Control equipment, communications systems, instrumentation.
Suitable for mounting on Euro cards.
2215-L1..
2215-G1...
Technical data
Ordering information 2215-G1
Type No.
2215 single pole thermal-magnetic circuit breaker
Mounting
G1 threadneck panel mounting
Number of poles
1 1-pole protected
Mounting hardware
1 2 hex nuts 1/4“-40 UNS-2A, serrated washer,
location pin (-G1 only)
Terminal design (main contacts)
P1 blade terminals 6.3-0.8, without shunt terminal
Characteristic curve
F1 fast acting:1.01-1.4xIN; magn.2-4xIN DC (DC only)
M1 standard delay: therm. 1.01-1.4xIN;
magn. 4.5-10.5xIN DC; magn. 3.5-8xIN AC
T1 delayed: therm. 1.01-1.4xIN; DC
magn. 8-17xIN DC, 6-13xIN AC
Auxiliary contacts
S0 without auxiliary contact
S11 with auxiliary contact (change over)
blade terminals 6.3x0.8 (QC .250)
Current ratings
0.05...10 A
2215 - G1 1 1 - P1 F1 - S11 - 0.5 A
ordering example
Ordering information 2215-L1
Type No.
Mounting
L1 PCB mounting
Number of poles
1 1-pole protected
Mounting hardware
0 without accessories
L1 solder pins, without shunt terminal
Auxiliary contacts - terminal design
S12 with auxiliary contact (change over)
solder pins
Current ratings
0.05...10 A
For further details please see: www.e-t-a.de/ti_e
Voltage rating
AC 250 V (50/60 Hz); DC 50 V
(UL: AC 250 V; DC 75 V)
Current rating range
0.05...10 A
(higher current ratings to special order)
Auxiliary circuit
1 A, AC 250 V / DC 28 V
Typical life
10,000 operations at 1 x IN
Ambient temperature
-30...+60 °C (-22...+140 °F)
Insulation co-ordination
rated impulse
pollution
(IEC 60664 and 60664 A) withstand voltage degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
IEC 60664 and 60664A)
test voltage
operating area
AC 3,000 V
main/aux. circuit
AC 1,500 V
Insulation resistance
> 100 MΩ (DC 500 V)
Interrupting capacity Icn 300 A
(UL 1077)
IN UN
0.05 A
AC 250 V
200 A
0.1...6 A
AC 250 V
1,000 A
8...10 A
AC 250 V
2,000 A
0.05...10 A DC 50 V
1,000 A
Degree of protection
operating area IP30
(IEC 60529/DIN 40050) terminal area IP00
Vibration
curve F1:
6 g (57-500 Hz), ± 0.46 mm (10-57 Hz)
curves M1, T1:
8 g (57-500 Hz), ± 0.61 mm (10-57 Hz)
to IEC 60068-2-6, test Fc
10 frequency cycles/axis
Shock
curves F1, M1, T1:
30 g (11 ms), directions 1, 2, 3, 4, 5,
curve F1:
10 g (11 ms), direction 6
curves M1, T1:
15 g (11 ms), direction 6
to IEC 60068-2-27, test Ea
Corrosion
96 hours at 5 % salt mist
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
Mass
approx. 25 g
Approvals
Authority
Standard
Rated voltage
Current ratings
2215 - L1 1 0 - L1 F1 - S12 - 0.5 A ordering example
UL
UL 1077
AC 250 V
DC 75 V
0.05 A…10 A
0.05 A…10 A (20 A)
Please be informed that we have minimum ordering quantities to be
observed.
CSA
C22.2 No.
235
AC 250 V
DC 75 V
0.05 A…10 A
0.05 A…10 A (20 A)
1942
www.e-t-a.de
1
Standard current ratings and typical internal resistance values
Current
ratings (A)
Internal
resistance (Ω)
0.05
440
1.5
0.55
0.1
108
2
0.34
0.2
29.9
2.5
0.21
0.3
14.2
3
0.15
0.084
0.057
0.6
3.5
6
0.043
0.8
1.8
8
≤ 0.02
1.2
10
16
.630
4
5
19
.748
≤ 0.02
12
11
14
4
.157
LINE
2
4
.157
1
3
.118
mounting area
(standard insulation)
Dimensions 2215-L1..
25°
25°
4
.157
spacer
Internal connection diagram
14
.551
I
11
.433
7.9
5.0
35
1.38
0.4
0.5
1
operating area
(reinforced insulation)
14
.551
Internal
resistance (Ω)
1.7
.067
ø1.5
.059
25.6
1.01
line
1
I
11
11
.433
52
2.05
49
1.93
5
.197
12
14
LINE
2.5
.098
12
11
14
1
I>
1x0.8
1x.031
2
6
.236
11.5
.453
2
29
1.14
Shock directions
Dimensions 2215-G1..
5
10° 10°
I
lock washer
11
14
6
.236
29
1.14
1
53.5
2.11
blade terminals
DIN 46244-A6.3-0.8
(QC .250)
9
.354
LINE
2.5
.098
2
11
.433
12
1
8
.315
hex nut
2
3
4
ø3
.118
serrated washer
19
.748
threadneck
1/4"-40 UNS-2A
6
tightening torque max. 1 Nm
52.5
2.07
11.5
.453
front panel cut-out
ø6.4+0.1
.252+.004
6.1
.240
1
Current
ratings (A)
Installation drawing
ø2.4+0.1
.094+.004
2
This is a metric design and millimeter dimensions take precedence ( mm )
inch
www.e-t-a.de
1942
Typical time/current characteristics
-F1 0.05…6 A
DC only
-F1 8…10 A
DC only
-M1 0.05…6 A
1000
1000
1000
100
100
100
10
1
Trip time in seconds
10000
10000
10000
10
1
1
0.1
0.1
0.01
0.01
0.01
0.001
1
2
1
4 6 8 10
… times rated current
-M1 8…10 A
AC/DC 1)
2
0.001
4 6 8 10
-T1 0.05…6 A
AC/DC 1)
1
1000
1000
100
100
100
1
1000
10000
10000
10
1
0.1
0.01
0.01
0.01
0.001
0.001
2
4 6 8 10
+60 °C
+140 °F
1
-30 °C
-22 °F
+23 °C
+73.4 °F
0.05...10 A:
1)
AC/DC 1)
1
0.1
1
4 6 8 10
10
0.1
0.001
2
-T1 8…10 A
10000
10
1
10
0.1
0.001
AC/DC 1)
2
4 6 8 10
1
2
4 6 8 10
Magnetic tripping currents are increased by 30 % on DC supplies (curve M1 and T1).
Ambient °F
temp.
°C
-22
-30
-4
-20
+14
-10
+32 +73.4 +86
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the circuit
+104 +122 +140 breaker current ratings by the derating factor shown below. See also section
+40 +50 +60 Technical information.
Derating factor
0.76 0.79
0.83
0.88
1.11
1
1.04
1.19
1.29
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
1942
www.e-t-a.de
3
1
4
www.e-t-a.de
1942
2215-G111-P1M1-S0-0.2A 价格&库存
很抱歉,暂时无法提供与“2215-G111-P1M1-S0-0.2A”相匹配的价格&库存,您可以联系我们找货
