BDTL175
BDTL175
    EATON(伊顿)
    LUG FOR 6 #14 WIRES
BDTL175 数据手册
Accessories 175A – 200A Bussmann® for Non-Fusible Disconnect Switches Fusible For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit BDNF200A + BDS240 + BDH110 + BDTL25 175 – 200 Amp switches, 600V UL general purpose amp rating 2 pole 3 pole Non-Fused BDNF175A 4 pole Maximum horsepower rating IEC AC21 Amp rating 200V 208V 240V 480V 600V 175 200 250 250 — — — — — — — — — — BDNF175A2 BDNF200A2 175 200 250 250 30 60 30 60 40 75 75 150 100 200 BDNF175A BDNF200A 175 200 250 250 30 60 30 60 40 75 75 150 100 200 BDNF175A4 BDNF200A4 Three phase Pistol handles — for use with shafts BDH108 Enclosed Fused NEMA type IEC type 1,3R,12 1,3R,12 1,3R,12 1,3R,12 1,3R,4,4X,12 1,3R,4,4X,12 Catalog number .31 x .31" ( 8 x 8mm) Color Length mm Marking Defeatable Padlockable Weight (lbs) Catalog number IP65 IP65 IP65 IP65 Black Red/Yellow Black Red/Yellow 2.6/65 2.6/65 3.1/80 3.1/80 O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On Yes Yes Yes Yes Yes Yes Yes Yes 0.29 0.29 0.30 0.30 BDH108 BDH109 BDH110 BDH111 IP66 IP66 Black Red/Yellow 3.1/80 3.1/80 O/I & Off/On O/I & Off/On Yes Yes Yes Yes 0.30 0.30 CDHXB88 CDHXY88 BDH109 Shafts — for use with pistol handles Enclosed Non-Fused Shaft length inches/mm BDS__ 5.5/140 9.5/240 13.4/340 19.5/500 Twisted shafts — Rotates handle 45° Shaft length inches/mm 13.4/340 CDS340T 42 .31 x .31" ( 8 x 8mm) Mounting depth1 in inches BDNF175A – BDNF200A Weight (lbs) Catalog number 0.15 0.26 0.36 0.54 BDS140 BDS240 BDS340 BDS500 Mounting depth1 in inches BDNF175A – BDNF200A Weight (lbs) Catalog number 12.6 – 16.6 0.36 CDS340T 4.7 8.7 12.6 18.9 – – – – 8.7 12.6 16.6 22.9 .31 x .31" ( 8 x 8mm) 1 Mounting depth is the distance from the outside of the door to the disconnect switch mounting plate. Shaft can be cut to desired length. 2 Availability to be announced. Accessories Bussmann® for 175A – 200A Non-Fusible Disconnect Switches Terminal lug kits Wire size For use on: BDTL25 BDNF175A & BDNF200A Kit weight (lbs.) Wire type Terminal lugs per kit Catalog number #6 – 300 kcmil 0.93 Cu/Al 6 BDTL25 #6 – 300 kcmil 0.47 Cu/Al 3 BDTL253P *(6) #14 – 6 0.55 Cu/Al 3 BDTL175 Fusible *A load side distribution lug eliminates the need to purchase, install and wire a separate distribution block. BDTL175 Weight (lbs) AC thermal amp rating AC rated voltage Catalog number 1 N.O. + 1 N.C. 0.09 10 600 BDAUX12 2 N.O. + 2 N.C. 0.18 10 600 BDAUX13 0.35 10 600 BDAUX16 Description* For use on: 4 N.O. + 4 N.C. BDNF175A 2 N.O. BDNF200A 0.09 10 600 BDAUX14 4 N.O. 0.18 10 600 BDAUX15 8 N.O. 0.35 10 600 BDAUX17 Non-Fused Auxiliary contacts1 *Contact configuration when mounted on switch, not shelf state. BDAUX12, 13 BDZX129 Description For use on: Weight (lbs) AC thermal amp rating AC rated voltage Catalog number Detachable neutral mounts on side of switch or DIN rail BDNF175A BDNF200A 0.84 200 600 BDZX129 For use on: Weight (lbs) Enclosed Fused Terminal poles Description BDTS2 Includes one set of 3 shrouds for use on line or load side BDNF175A BDNF200A 0.40 Enclosed Non-Fused Terminal shrouds Catalog number BDTS2 Handle support bracket Description BDZX131 Allows handle to be directly mounted to switch behind the door For use on: BDNF175A BDNF200A Weight (lbs) Catalog number 0.33 BDZX131 1 UL File E57057 43 Accessories Bussmann® for 175A – 200A Non-Fusible Disconnect Switches Locking accessories Fusible CDETL-ZW16 Description For use on: Cam attachment for Kirk Key, Castell, Lowe & Fletcher and Ronis interlock. For adapting to the interlock system The interlock is not included. 5, 6 & 8mm shafts Electrical interlock1 Closed circuit principle for interlocking the switch movement. When the coil circuit is dead, A-types cannot be operated to ON-position and L-types cannot be operated to ON- or OFF-position. Coil voltages 110VAC, 220VAC, 24VDC, 48VDC, 60 VDC, 110VDC, 220VDC, P = 15W U = 0.7 – 1.1 Un (U = coil voltage, Un = nominal voltage) BDNF175A – BDNF200A Weight (lbs.) 0.29 Catalog number CDETL-ZW16 CDETL-ZT80A/ 2.42 CDETL-ZT80L/ BDNF175A – BDNF200A 0.35 CDETL-ZT140 Description For use on: Weight (lbs.) Catalog number Joins two shafts together for applications where extended length is required 12mm shafts 0.26 BDZW95 Mounting bracket Non-Fused - Coil voltage CDETL-ZT 80A Enclosed Fused CDETL-ZT140 Shaft extension coupler Enclosed Non-Fused BDZW95 Shaft adapter CDZT123 44 Description For use on: Weight (lbs.) Catalog number Adapts one end of an 8mm shaft to a 12mm shaft. Use with shaft extension coupler. 8mm shafts 0.20 CDZT123 1 CDETL-ZT140 mounting bracket required. Accessories Bussmann® for 175A – 200A Non-Fusible Disconnect Switches Conversion mechanisms • Switches are not included BDZW18 BDZW20 BDZW20X BDZW21 BDZW21X BDZW19 1 6 or 8 pole — BDZW18 IO N BDZW20 6 (8) pole mechanism allows two switches controlled by one handle to open or close simultaneously. Shafts included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • One handle POS.I O X SW. B O X 1 SW. A SW. B SW. A SW. B SW. A SW. B LOAD LOAD LOAD I O II POS. I POS.O POS.II SW. A X O O SW. B O O X X = Closed O = Open 1 Bypass — BDZW21 BDZW21 POS. O SW. A X = Closed O = Open Transfer — BDZW20 Transfer mechanism manually transfers between two power sources using two switches and a center OFF position. A 3-position handle is included: (Type 1, 3R, 12) or (Type 1, 3R, 4, 4X, 12) Shafts included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches Bypass mechanism operates three switches: Two switches in series and one changeover switch to allow power bypass. A 3-position handle is included: (Type 1,3R & 12) or (Type 1, 3R, 4, 4X, 12) Shafts included. Equipment required for a complete installation: • One conversion mechanism • Three disconnect switches POS. I POS.O POS.II SW. A O O X SW. B O O X SW. C X O O SW. A POS. I SW. B POS. I SW. A X O SW. B O X X = Closed O = Opean Mechanical interlock — BDZW19 Mechanical interlock mechanism prevents both switches from being in the ON position at the same time. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • Two handles • Two shafts BDZW19 1 Fusible BDNF175A BDNF200A 1.61 6.17 6.17 7.27 7.27 4.41 Catalog number Non-Fused BDZW18 Weight (lbs) 1 X = Closed O = Open = Three poles 45 Enclosed Fused 6 or 8 pole Transfer Transfer Bypass Bypass Mechanical interlock For use on: Enclosed Non-Fused Description
BDTL175 价格&库存
很抱歉,暂时无法提供与“BDTL175”相匹配的价格&库存,您可以联系我们找货
