BDTA1
BDTA1
    EATON(伊顿)
    FUSE ADAPTER KIT T-TYPE 100A
BDTA1 数据手册
Productivity Through Protection™ Disconnect Switches Table of Contents Disconnect Switches Compact, Heavy-Duty Enclosed Fusible Disconnect Switches ..................Page 71 Enclosed Non-Fusible Disconnect Switches..........Page 75 Index by Part Number ............................................... Page 86 Non-Fused Non-Fused Enclosed Fused Fused Enclosed Non-Fusible Disconnect Switches...........................Page 29 Enclosed Non-Fused Non-Fused Enclosed Fusible Disconnect Switches .....................................Page 2 Fusible Table of Contents Overview for Fusible Disconnect Switches CFD30CC3 – FD800L3 Fusible CFD30AJ3 CFD60J3 Catalog number 3 pole General purpose amp rating CFD100J3 CFD30ACC3 A CFD30AJ3 FD400J3 FD600J3 CFD60J3 CFD100J3 CFD200J03 FD800L3 FD400J3 FD600J3 FD800L3 30 30 60 100 200 400 600 800 N/A UL98 & IEC UL98 & IEC N/A UL98 & IEC UL98 & IEC N/A UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC V 600 600 600 600 600 600 600 600 HP HP HP HP 5/7.5 7.5 15 20 5/7.5 7.5 15 20 15 15 30 50 25 30 60 75 50 60 125 150 100/125 125 250 350 150 200 400 500 200 250 500 600 HP HP 2 3 2 3 — — — — — — — — — — — — CC J J J J J,T J,T L 1000 1000 750 750 1000 1000 1000 1000 A A 32 32 32 32 63 63 125 125 200 200 400 400 630 600 800 720 A A 32 32 32 32 63 63 125 125 200 200 400 400 630 630 800 800 kW kW 14/15 25 14/15 25 30 60 80/90 132 110 200 210/230 330 315/340 540 350/380 600 lb lb 1.54 1.98 1.54 1.98 2.86 3.52 3.30 3.96 5.9 7.5 17.2 19.4 37.48 46.3 37.48 46.3 H in W in D in 3.82 4.17 4.21 3.82 4.17 4.21 3.94 5.63 5.04 5.66 7.06 5.09 6.5 7.1 5.2 7.87 11.22 8.11 11.42 14.69 9.21 11.42 14.69 9.21 Double break contacts S S S S S S S S Fuse cover S S S • S S S S Terminal lug kit Integral Integral Integral BDTL24 CDTL200 BDTL26 BDTL27 BDTL27 Terminal shroud Not required Not required Not required Auxiliary contact • • • • • • • • • • • • • Handle UL/NEMA type Type 1, 3R, 12 Type 1, 3R, 4, 4X, 12 • • • • • • • • • • • • • • • • Conversion kit 6 pole Electrical interlock • • • • — — — — • • • • • • • • Approvals1 2 pole 3 pole 4 pole Technical ratings (UL, cULus) Non-Fused Max operating voltage Max horsepower rating Three phase 200 – 208V 240V 480V 600V Single phase 120V 240V UL fuse class Technical ratings (IEC) Enclosed Fused Rated insulation and operational voltage. AC20 and DC202 Rated thermal current, Ith AC 20/DC 20 open AC 20/DC 20 enclosed AC 21A 500V 690V Rated operational power AC23 400/415V 690V Physical characteristics Enclosed Non-Fused Weight 3 pole switch 4 pole Dimension 3 pole Accessories S = Standard • = Available — = Not available 1 UL Listed switches are also cULus approved. 2 1000V IEC 408 2 UL Listed, cULus approved, IEC rated, CE marked 30A Fusible Disconnect Switches Base & DIN Rail Mounted UL Fuse Class J, CC For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft + BDS__ + CDH3S Fusible CFD30AJ3 30 Amp switches, 600V UL general purpose amp rating UL Fuse type 600V Maximum horsepower rating Terminal lugs Three phase 200V 208V 240V 480V Wire size 600V Wire type Catalog number 3 pole 30 J 5 7.5 7.5 15 20 #18 – 8 Cu CFD30AJ3 301 CC 5 7.5 7.5 15 20 #18 – 8 Cu CFD30ACC3 30 J 5 7.5 7.5 15 20 #18 – 8 Cu CFD30AJ4 301 CC 5 7.5 7.5 15 20 #18 – 8 Cu CFD30ACC4 CFD30AJ3 Selector handles — for use with shafts NEMA type IEC type .24 x .24" ( Non-Fused 4 pole 6 x 6 mm) Color Defeatable Padlockable Weight (lbs.) Catalog number CBDH3S CBDH3S, 5S 1,3R,12 IP65 Black — Yes 0.16 1,3R,12 IP65 Red/Yellow — Yes 0.16 CBDH4S 1,3R,12 IP65 Black Yes Yes 0.16 CBDH5S 1,3R,12 IP65 Red/Yellow Yes Yes 0.16 CBDH6S Enclosed Fused All marked both O/I & Off/On CBDH4S, 6S Shaft length (inches/mm) BDS__ .24 x .24" ( Mounting depth (in inches) 6 x 6 mm) Weight (lbs.) Enclosed Non-Fused Shafts — for use with CBDH selector handles Catalog number 3.3/85 5.5 – 5.7 0.04 BDS85S 4.1/105 5.5 – 6.5 0.04 BDS105S 4.7/120 5.5 – 7.1 0.05 BDS120S 5.1/130 5.5 – 7.5 0.05 BDS130S 7.1/180 6.3 – 9.4 0.08 BDS180S 9.8/250 9.1 – 12.2 0.10 BDS250S 13.0/330 12.2 – 15.4 0.14 BDS330S 1 Rejection style fuses only. 3 Handles & Shafts for 30A Fusible Disconnect Switches For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft Fusible CFD30AJ3 + Pistol handles — for use with shafts BDH56, BDH58 NEMA type IEC type 1,3R,12 1,3R,12 1,3R,12 BDS__ .24 x .24" ( + BDH59 6 x 6 mm) Color Marking Length inches/mm Defeatable Padlockable Weight (lbs.) Catalog number IP65 Black O/I & Off/On 1.8/45 Yes Yes 0.28 IP65 Red/Yellow O/I & Off/On 1.8/45 Yes Yes 0.28 BDH57 IP65 Black O/I & Off/On 2.6/65 Yes Yes 0.29 BDH58 BDH56 Non-Fused 1,3R,12 IP65 Red/Yellow O/I & Off/On 2.6/65 Yes Yes 0.29 BDH59 1,3R,4,4X,12 IP65 Black O/I & Off/On 2.6/65 Yes Yes 0.29 CDHXB65L6 1,3R,4,4X,12 IP65 Red/Yellow O/I & Off/On 2.6/65 Yes Yes 0.29 CDHXY65L6 1,3R,12 IP65 Black Off/On/Test 2.6/65 Yes Yes 0.29 BDH58T 1,3R,12 IP65 Red/Yellow Off/On/Test 2.6/65 Yes Yes 0.29 BDH59T BDH57, BDH59 Enclosed Fused Shafts — for use with pistol handles .24 x .24" ( 6 x 6 mm) Shaft length (inches/mm) Mounting depth (in inches) Weight (lbs.) 5.9/150 4.9 – 8.9 0.07 6.7/170 5.9 – 9.7 0.08 BDS170 10.4/265 9.5 – 13.4 0.12 BDS265 BDS__ Catalog number BDS150 15.8/400 15.0 – 18.7 0.18 BDS400 19.7/500 20.5 – 22.6 0.23 BDS500 Enclosed Non-Fused Direct mount handle — mounts directly to switch, no shaft necessary NEMA type Color Marking Length mm Padlockable Weight (lbs.) Catalog number 1 Blk O/I/Test 50 Yes 0.10 BDHA79 BDHA79 5.20" 132mm 5.20"/132mm BDHA79 Mounted 4 BDHA79 Mounted depth Accessories for 30A Fusible Disconnect Switches Auxiliary contacts1 For use on: Weight (lbs) AC thermal amp rating AC rated voltage 0.04 6 250 (2 maximum) CFD30_ for direct mounting to switch 1 N.O. 1 N.C. (6 maximum) CFD30_ CDAUXB mounting base required 0.03 Description For use with: Weight (lbs) Catalog number Mounting base CDAUX10, CDAUX01K 0.08 CDAUXB Description NEMA A600,P600 BDAUX157 CDAUX10 CDAUX01K Fusible Form C 1 N.O. & 1 N.C. Catalog number CFD30AJ3 with auxiliaries Non-Fused Mounting base Terminal pole Description CFDZX171 Detachable neutral mounts on side of switch or DIN rail For use on: Weight (lbs) AC thermal amp rating AC rated voltage 30 600 Catalog number CFD30_ 0.45 CFDZX171 For use on: Weight (lbs.) Length inches/mm Catalog number 35mm DIN Rail CFD30_ .38 39.4/1000 NDNA100 35mm Aluminum DIN Rail CFD30_ .75 78.8/2000 NDNA200 Description Enclosed Fused DIN rail NDNA100 Fuse Carriers (Replacement Parts) For use on: CC fuse carrier J fuse carrier BDCF30CC_ BDCF30J_ Class CC Solid link CFD30_ Catalog number BDZD48 BDZD28 Enclosed Non-Fused Description NNB-R BDZD48 Terminal cover (replacement part) Description For use on: Catalog number Covers terminal below fuse carrier CFD30_ CDBY67121 CXBY67121 1 UL File # E83510 5 Accessories for 30A Fusible Disconnect Switches Conversion mechanisms • Switches are not included Fusible BDZW6 Description For use on: Weight (lbs) 6 pole CFD30 1.74 BDZW6 8 pole CFD30 1.90 BDZXB8 6 or 8 pole — BDZW5 6 (8) pole mechanism allows two switches, controlled by one handle, to open or close simultaneously. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • One handle • One 5 mm shaft Non-Fused Enclosed Fused Enclosed Non-Fused 1 6 Catalog number = Three poles 1 POS. O POS. I SW. A O X SW. B O X X = Closed O = Open 60A – 100A for Fusible Disconnect Switches For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit CFD60J3 + BDS210 + Fusible UL Fuse Class J BDH58 60 – 100 Amp switches, 600V UL general purpose amp rating UL Fuse type 600V Maximum horsepower rating 200V 208V 60 J 15 15 15 30 50 100 J 25 25 30 60 75 Three phase 240V 480V Catalog number 600V 3 pole CFD100J3 4 pole 60 J 15 15 15 30 50 CFD60J4 100 J 25 25 30 60 75 CFD100J4 NEMA/UL type IEC type 1,3R,12 1,3R,12 .24 x .24" ( Non-Fused 4 pole Pistol handles — CFD100J3 CFD60J3 6 x 6mm) Color Length in/mm Marking Defeatable Padlockable Weight (lbs.) Catalog number IP65 Black 2.6/65 O/I & Off/On Yes Yes 0.29 BDH58 IP65 Red/Yel 2.6/65 O/I & Off/On Yes Yes 0.29 BDH59 1,3R,12 IP65 Black 3.1/80 O/I & Off/On Yes Yes 0.30 BDH60 1,3R,12 IP65 Red/Yel 3.1/80 O/I & Off/On Yes Yes 0.30 BDH61 1,3R,4,4X,12 IP65 Black 3.1/80 O/I & Off/On Yes Yes 0.30 CDHXB86 1,3R,4,4X,12 IP65 Red/Yel 3.1/80 O/I & Off/On Yes Yes 0.30 CDHXY86 Shafts — .24 x .24" ( Enclosed Fused CFD60J3 3 pole 6 x 6mm) Shaft length (inches/mm) Mounting depth (inches) 5.9/150 8.3/210 11.4/290 14.2/360 16.9/430 5.5 8.0 11.0 13.8 16.5 – – – – – 8.5 11.0 14.0 16.8 19.7 Weight (lbs.) Catalog number 0.09 0.13 0.18 0.23 0.27 BDS150 BDS210 BDS290 BDS360 BDS430 Enclosed Non-Fused BDH58,60 BDH59,61 Twisted shafts — Rotates handle 45° .24 x .24" ( Shaft length (inches/mm) 6 x 6mm) Mounting depth (inches) 5.1/130 8.3/210 11.4/290 14.2/360 4.8 8.0 11.0 13.8 – – – – 7.8 11.0 14.0 16.8 Weight (lbs.) Catalog number 0.08 0.13 0.18 0.23 BDST4 BDST25 BDST29 BDST30 BDS__ Direct mount handle — mounts directly to switch, no shaft necessary NEMA type 1 Color Marking Length mm Padlockable Weight (lbs.) Catalog number Black O/I/Test 50 Yes 0.10 CDH4 BDST_ 7 Accessories for 60A – 100A Fusible Disconnect Switches Terminal lug kit For use on: Wire size Kit weight (lbs) Wire type Terminal lugs per kit Catalog number CFD60J_ #14 – 4 — Cu — Integral CFD100J_ #14 – 2/0 0.43 Cu/Al 6 BDTL24 Weight (lbs) AC thermal amp rating AC rated voltage Catalog number 0.07 0.07 10 10 600 600 CDAUX10 CDAUX01K BDTL24 Fusible Auxiliary contacts Description 1 N.O. 1 N.C. For use on: CFD60 – CFD100 CDAUX10, CDAUX01K Replacement fuse clip Non-Fused CFC60J Description For use on: Catalog number Removable fuse carrier CFD60 CFC60J CFCVR100 Replacement fuse covers Description For use on: Catalog number Transparent fuse cover CFD100 CFCVR100 Enclosed Fused Terminal shroud Description For use on: Weight (lbs) Catalog number Includes one terminal shroud for line or load side CFD100, 1-POLE 0.04 CFTS100 Description For use on: Weight (lbs) AC thermal amp rating AC rated voltage Detachable neutral mounts on side of switch or DIN rail CFD60 0.13 63 600 CFZ1 CFD100 0.31 125 600 CFZ2 Description For use on: Weight (lbs.) 35mm Aluminum DIN Rail CFD60 .38 39.4/1000 NDNA100 35mm Aluminum DIN Rail CFD60 .75 78.8/1000 NDNA200 CFTS100 Enclosed Non-Fused Terminal poles CFZ1 Catalog number DIN rail NDNA100 Length inches/mm Catalog number “T” type fuse adapter kit BDTA1 8 Description For use on: Catalog number 100A, 600V CFD100 BDTA1 Accessories for 60A – 100A Fusible Disconnect Switches Locking accessories Description Weight (lbs) Catalog number CFD60 – CFD100 0.25 CDETL-ZW16 Description For use on: Weight (lbs) Joins two shafts together for applications where extended length is required 6mm shafts 12mm shafts 0.26 0.26 For use on: Weight (lbs) Catalog number 6mm shafts 0.20 CDZK19 Fusible Cam attachment for Kirk Key, Castell, Lowe & Fletcher and Ronis interlock. Cam attachment for adapting to the interlock system. The interlock is not included. For use on: CDETL-ZW16 Shaft extension coupler BDZX167 BDZW95 Non-Fused BDZX167 BDZW95 Catalog number Description x-1 x 12 Adapts one end of a 6mm shaft to 12mm. Use with shaft extension coupler Enclosed Fused Shaft adapter CDZK19 (X=6MM) Conversion mechanisms BDZW2 Description For use on: Weight (lbs) Catalog number 6 and 8 pole CFD60 – CFD100 1.52 BDZW2 Mechanical interlock CFD60 – CFD100 0.55 BDZW10 6 or 8 pole — BDZW2 6 (8) pole mechanism allows two switches controlled by one handle, to open or close simultaneously. Shafts included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • One handle 1 Enclosed Non-Fused • Switches are not included 1 POS. O POS. I SW. A O X SW. B O X X = Closed O = Open = Three poles 9 200A Fusible Disconnect Switches UL Fuse Class J Fusible For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit CFD200J03 + BDS210 + BDH58 + CDTL200 200 Amp Switches, 600V UL general purpose amp rating UL fuse type 600V 200V 208V Three phase 240V 480V 600V 200 J 50 50 60 125 150 CFD200J03 200 J 50 50 60 125 150 CFD200J04 Maximum horsepower rating Catalog number 3 pole BDH58,60 4 pole Non-Fused Pistol handles - BDH58,61 Enclosed Fused UL/ NEMA type IEC type 1,3R,12 1,3R,12 1,3R,12 1,3R,12 IP65 IP65 IP65 IP65 1,3R,4,4X,1 1,3R,4,4X,12 IP65 IP65 Shafts - .24 x .24” ( Length inches/mm Marking Black Red/Yel Black Red/Yel 2.6/65 2.6/65 3.1/80 3.1/80 O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On Yes Yes Yes Yes Yes Yes Yes Yes 0.29 0.29 0.30 0.30 BDH58 BDH59 BDH60 BDH61 Black Red/Yel 3.1/80 3.1/80 O/I & Off/On O/I & Off/On Yes Yes Yes Yes 0.30 0.30 CDHXB86 CDHXY86 Color .24 x .24” ( BDS_ Defeatable Padlockable Weight (lbs) Catalog number 6 x 6mm) Shaft length (inches/mm) 5.9/150 8.3/210 11.4/290 14.2/360 16.9/430 6 x 6mm) Mounting dept (inches) Enclosed Non-Fused 5.5-8.5 8.0-11.0 11.0-14.0 13.8-16.8 16.5-19.7 Weight (lbs) Catalog number 0.09 0.13 0.18 0.23 0.27 BDS150 BDS210 BDS290 BDS360 BDS430 Twisted shafts - rotates handle 45˚ .24 x .24” ( 6 x 6mm) Shaft length (inches/mm) 5.1/130 8.3/210 11.4/290 14.2/360 BDST_ Mounting dept (inches) 4.8-7.8 8.0-11.0 11.0-14.0 13.8-16.8 Weight (lbs) Catalog number 0.08 0.13 0.18 0.23 BDST4 BDST25 BDST29 BDST30 Direct mount handle - mounts directly to switch, no shaft necessary Nema Type 1 1 10 Color Black Red/Yel Marking O/I O/I Padlockable Yes Yes (lbs) 0.1 0.3 Catalog number CDHSB20 CDHSY20 Accessories for 200A Fusible Disconnect Switches Terminal Lug Kits For use on: Wire Size Wire Type #4-300kcmil CFD200JO3 #4-300kcmil CFD200J04 (6) 14-6 AWG Description ----Distribution lug Cu/Al Terminal lugs per kit 6 3 3 Weight (lbs) 0.5 0.25 Catalog number CDTL200 CDTL200/3P CDTL206 Fusible CDTL200 Auxiliary Contacts For use on: 1 N.O. 1 N.C. CFD200J03, CFD200J04 0.07 0.07 Module for auxililary contacts Weight (lbs) Description Screw mounting to the left side of the switch 0.1 Catalog number CDAUX10 CDAUX01K Catalog number Non-Fused CDAUX10, CDAUX01K Weight (lbs) Description CDAUXM28 Mounting on the left side of the switch: Max. 8 auxiliary contact blocks with the CDAUXM28 Mounting under the mechanism cover: Max. 4 auxiliary contact blocks Replacement parts Description For use on: Fuse cover Phase barrier CFD200J03 and CFD200J04 Terminal For use on: Description CFD200J03 and CFD200J04 Long type Short type Long type Short type Number of poles Catalog number CFCVR200 CPBR200 Weight (lbs) Enclosed Fused CDSS200S3 Catalog number 3 3 4 4 0.2 0.13 0.26 0.18 CDSS200L3 CDSS200S3 CDSS200L4 CDSS200S4 Weight (lbs) AC thermal amp rating AC rated voltage 0.88 200 600 Enclosed Non-Fused CDSS200L3 Terminal poles Description Detachable neutral mounts on side of switch or DIN CDETL-ZW16 Catalog number CDD200P Locking accessories Description Cam attachment for Kirk Key, Castell, Lowe & Fletcher and Ronis interlock. Cam attachment for adapting to the interlock system. The interlock is not included. Weight (lbs) 0.25 Catalog number CDETL-ZW16 11 Accessories for 200A Fusible Disconnect Switches Shaft extension coupler Description Joins two shafts together for applications where extended length is required Weight (lbs) For use on: 6mm shafts 12mm shafts 0.26 Catalog number BDZX167 BDZX95 BDZX167, BDZW95 Fusible Shaft adapter Description Adapts one end of a 6mm shaft to 12mm. Use with shaft extension coupler. For use on: Catalog number 6mm shafts CDZK19 x-1 x 12 CDZK19 (X=6mm) Non-Fused BDZW2 Enclosed Fused Enclosed Non-Fused 12 Conversion mechanisms Description Weight (lbs) UL/NEMA type 6 and 8 pole 1.52 ----------------------- Catalog number BDZW2 400A – 800A Fusible Disconnect Switches UL Fuse Class J, T, L FD400J3 + BDS280 + BDH114 + BDTL26 Fusible For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit 400 – 800 Amp switches, 600V Maximum horsepower rating UL Fuse type 600V 200V 208V 240V 480V 600V 400 J1 — — — — — FD400J2 600 J1 — — — — — FD600J2 800 L — — — — — Three phase 2 pole 2 pole 3 pole FD400J3 FD800L2 3 pole 400 J1 100 125 125 250 350 FD400J3 600 J1 150 150 200 400 500 FD600J3 800 L 200 200 250 500 600 4 pole 60A - 100A Catalog number Non-Fused UL general purpose amp rating FD800L3 4 pole 400 J1 100 125 125 250 350 FD400J4 600 J1 150 150 200 400 500 FD600J4 800 L 200 200 250 500 600 FD800L4 UL Fuse Class J BDH112 IEC type 1,3R,12 1,3R,12 .47 x .47" ( 12 x 12mm) Color Length inches/mm Marking Defeatable Padlockable Weight (lbs) IP65 Black 4.9/125 O/I & Off/On Yes Yes 0.39 BDH112 IP65 Red/Yel 4.9/125 O/I & Off/On Yes Yes 0.39 BDH113 1,3R,12 IP65 Black 5.7/145 O/I & Off/On Yes Yes 0.39 BDH114 1,3R,12 IP65 Red/Yel 5.7/145 O/I & Off/On Yes Yes 0.39 BDH115 1,3R,12 IP65 Black 6.9/175 O/I & Off/On Yes Yes 0.41 BDH116 1,3R,12 IP65 Red/Yel 6.9/175 O/I & Off/On Yes Yes 0.41 BDH117 1,3R,4,4X,12 IP65 Black 5.7/145 O/I & Off/On Yes Yes 0.39 CDHXB12 1,3R,4,4X,12 IP65 Red/Yel 5.7/145 O/I & Off/On Yes Yes 0.39 CDHXY12 1,3R,4,4X,12 IP65 Black 6.9/175 O/I & Off/On Yes Yes 0.41 CDHXB22 1,3R,4,4X,12 IP65 Red/Yel 6.9/175 O/I & Off/On Yes Yes 0.41 CDHXY22 1,3R,4,4X,12 IP65 Metal 8.7/220 Off/On — Yes 1.50 BDH8 Enclosed Fused NEMA type Catalog number Enclosed Non-Fused Pistol handles — FD600J3 FD800L3 BDH113 1 J type fuse clips are standard. If 600V Type “T” fuse clips are desired, please order a "T" type fuse adapter kit. 13 Accessories for 400A – 800A Fusible Disconnect Switches Shafts — .47 x .47" ( 12 x 12mm) Mounting depth1 in inches Shaft length Weight Catalog For use on FD400J_ BDS__ Fusible 8.7/220 7.9 – 12.2 0.61 BDS220 9.8/250 9.1 – 13.4 0.70 BDS250 11.0/280 10.2 – 14.5 0.77 BDS280 12.8/325 12.0 – 16.3 0.90 BDS325 15.6/395 14.8 – 19.1 1.10 BDS395 18.3/465 17.5 – 21.9 1.32 BDS465 21.1/535 20.3 – 24.6 1.54 BDS535 For use on FD600J_ – FD800J_ BDS_45 Non-Fused BDTL26 9.8/250 10.0 – 12.8 0.70 BDS250 11.0/280 11.2 – 14.0 0.77 BDS280 12.8/325 13.0 – 15.8 0.90 BDS325 15.6/395 15.8 – 18.6 1.10 BDS395 18.3/465 18.5 – 21.3 1.32 BDS465 21.1/535 21.1 – 24.1 1.54 BDS535 Twisted shafts — Rotates handle 45° Shaft length (inches/mm) .47 x .47" ( 12 x 12mm) Mounting depth (inches) Weight (lbs.) Catalog number For use on FD400J_ Enclosed Fused 11.0/280 10.2 – 14.5 0.77 BDS28045 12.8/325 12.0 – 16.3 0.90 BDS32545 18.3/465 17.5 – 21.9 1.32 BDS46545 11.0/280 11.2 – 14.0 0.77 BDS28045 12.8/325 13.0 – 15.8 0.90 BDS32545 18.3/465 18.5 – 21.3 1.32 BDS46545 For use on FD600J_ – FD800J_ BDTL27 Terminal lug kit Enclosed Non-Fused For use on: FD400J_ FD600J – FD800L FD600J_ & FD800L_ Wire size #2 – 600 kcmil (12)#14-16 – 600 kcmil (2)#2 – 600 kcmil Kit weight (lbs) 3.50 1.10 4.62 Wire type Cu/Al Cu/Al Cu/Al Terminal lugs per kit 6 3 6 Catalog number BDTL26 BDTL175/400 BDTL27 BDTL175/400 “T” type fuse adapter kit For use on: AC thermal amp rating FD400J_ FD600J_ 400 600 AC rated voltage 600 600 Poles Catalog number 3 3 BDTA4 BDTA6 BDTA_ 1 14 Mounting depth is the distance from the outside of the door to the disconnect switch mounting plate. Shaft can be cut to desired length. Accessories for 400A – 800A Fusible Disconnect Switches Auxiliary contacts1 Description 1 N.O. + 1 N.C. 2 N.O. + 2 N.C. 4 N.O. + 4 N.C. 2 N.O. 4 N.O. 8 N.O. BDAUX_ FD400 – FD800 Weight (lbs) AC thermal amp rating AC rated voltage 0.20 0.26 0.40 0.18 0.25 0.40 10 10 10 10 10 10 600 600 600 600 600 600 Catalog number BDAUX1 BDAUX2 BDAUX3 BDAUX4 BDAUX5 BDAUX6 600A & 800A Switches Fusible 200A & 400A Switches For use on: Fuse covers (replacement part) Description 2 pole 3 pole 4 pole BDZX272 BDZX196 FD400 FD600 – FD800 Weight (lbs) Catalog number 0.30 0.40 0.53 BDZX271 BDZX272 BDZX273 0.40 0.50 0.67 BDZX216 BDZX196 BDZX197 Non-Fused BDZX271 BDZX216 2 pole 3 pole 4 pole For use on: BDZX273 BDZX197 Description For use on: Prevents the fuse cover from being opened when the switch is in the ON position FD400FD800 Enclosed Fused Fuse cover interlock Catalog number BDZX204 BDZX204 Terminal shroud For use on: Weight (lbs) Catalog number Includes one terminal shroud for FD400 0.13 BDTSF4 line or load side FD600 – FD800 0.11 BDTSF6 Enclosed Non-Fused Description BDT5F_ Terminal pole Description For use on: Detachable neutral mounts on FD400 side of switch or DIN rail FD600 – FD800 Weight (lbs) AC thermal amp rating AC rated voltage Catalog number 1.04 400 600 BDTP85 1.19 800 600 BDTP88 BDTP85 BDTP88 1 UL file #E57057 15 Accessories for 400A – 800A Fusible Disconnect Switches Locking accessories Description Cam attachment for Kirk Key, Castell, Lowe & Fletcher and Ronis interlock. For adapting to the interlock system. The interlock is not included. Fusible CDETL-ZW5 Electrical interlock Closed circuit principle for interlocking the switch movement. When the coil circuit is dead, A-types cannot be operated to ON-position and L-types cannot be operated to ON- or OFF-position. For use on: Weight (lbs) Catalog number FD400 – 0.29 CDETL-ZW5 2.42 CDETL-ZT80A/ FD800 FD600 – FD800 CDETL-ZT80L/ Coil voltages 110VAC, 220VAC, 24VDC, 48VDC, 60 VDC 110VDC, 220VDC, P = 15W Non-Fused H - Coil voltage Shaft extension coupler Description For use on: Weight (lbs) Catalog number Joins two shafts together for applications where extended length is required 12mm shafts 0.26 BDZW95 CDETL-ZT80 Enclosed Fused BDZW95 Shorting bars Description For use on: Solid links FD400 (1 per kit) FD600 – FD800 AC thermal amp rating AC rated voltage Catalog number 400 600 FDSBZK98 800 600 FDSBZL79 Enclosed Non-Fused FDSBZK98 FDSBZL79 90° angle kit BDZX108 16 Description For use on: Weight (lbs) Converts switch mechanism from front operation to side operation FD400 – FD800 4.63 Catalog number BDZX108 Accessories for 400A – 800A Fusible Disconnect Switches Conversion mechanisms • Switches are not included Description For use on: 6 or 8 pole Weight (lbs) Catalog number 2.42 BDZW9 BDZW9 1 POS. O POS. I SW. A O X SW. B O X X = Closed O = Open Enclosed Non-Fused Enclosed Fused Non-Fused 6 or 8 pole — BDZW9 6 (8) pole mechanism allows two switches controlled by one handle, to open or close simultaneously. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • One handle • One additional shaft (Only one shaft is included with mechanism) Fusible FD400 – FD800 1 = Three poles 17 Side Operated Fusible Disconnect Switches for 30A – 400A UL Fuse Class J, CC, T Fusible For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit CFD30AJ3S + BDS170 + BDH59SH Side operated switches — 3 pole UL general purpose amp rating UL fuse type 600V 200V 208V Three phase 240V 480V 600V Weight (lbs) 30 30 60 100 200 400 J CC J J1 J1 J1 5 5 15 25 50 100 7.5 7.5 15 25 50 125 7.5 7.5 15 30 60 125 15 15 30 60 125 250 20 20 50 75 150 350 1.54 1.54 3.52 3.97 15.21 17.20 IEC type Color Length inches/mm CFD60J3S Maximum horsepower rating Catalog number CFD30AJ3S CFD30ACC3S CFD60J3S CFD100J3S FD200J3-S FD400J3-S Non-Fused Handles NEMA type Marking Defeatable Padlockable Weight Catalog number For use with CFD30J3S & CFD30CC3S 1, 3R, 12 IP65 Black 2.6/65 OFF/ON/TEST Yes Yes 0.29 BDH58SH 1, 3R, 12 IP65 Red/Yellow 2.6/65 OFF/ON/TEST Yes Yes 0.29 BDH59SH For use with CFD60J3S & CFD100J3S CFD100J3S 1, 3R, 12 IP65 Black 3.1/80 OFF/ON/TEST Yes Yes 0.30 BDH110SH 1, 3R, 12 IP65 Red/Yellow 3.1/80 OFF/ON/TEST Yes Yes 0.30 BDH111SH For use with FD200J3-S & FD400J3-S Enclosed Fused 1, 3R, 12 IP65 Black 4.9/145 OFF/ON/TEST Yes Yes 0.39 BDH114SH 1, 3R, 12 IP65 Red/Yellow 4.9/145 OFF/ON/TEST Yes Yes 0.39 BDH115SH 1, 3R, 12 IP65 Metal 4.9/145 OFF/ON/TEST — Yes 1.50 BDZX74 — = No Shafts Length (inches/mm) Description Weight (lbs.) CFD30AJ3S & CFD30ACC3S 6.7/170 0.24 x 0.24" (6 x 6mm) 0.08 BDS170 CFD60J3S & CFD100J3S 8.3/210 0.24 x 0.24" (6 x 6mm) 0.13 BDS210 FD200J3-S & FD400J3-S 12.8/325 0.47 x 0.47" (12 x 12mm) 0.90 BDS325 For use with: Catalog number Enclosed Non-Fused BDZX74 Terminal lug kit BDS325 For use on: Wire size Kit weight (lbs) Wire type Lugs per kit Catalog number CFD30J3S & CFD30CC3S CFD60J3S #14 – 4 #14 – 4 — — Cu Cu — — Integral Integral CFD100J3S #14 – 2/0 0.43 Cu/Al 6 BDTL24 FD200J3-S #6 – 300 kcmil 0.93 Cu/AI 6 BDTL25 FD400J3-S #2 – 600 kcmil 3.50 Cu/AI 6 BDTL26 BDTL25 1 18 J type fuse clips are standard. If 600V Type "T" fuse clips are desired, please order the "T" type fuse adapter kit. Flange Operated Fusible Disconnect Switches for 30A – 100A UL Fuse Class J, CC, T CFD30J3F + BDFHS12 + BDFHNHS12 Fusible For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit Flange operated switches — 3 pole UL fuse type 600V Maximum horsepower rating 200V 208V Three phase 240V 480V 600V Weight (lbs) Catalog number 30 30 60 100 J CC J J 5 5 15 25 7.5 7.5 15 25 7.5 7.5 15 30 15 15 30 60 20 20 50 75 2.20 2.50 3.52 3.97 CFD30AJ3F CFD30ACC3F CFD60J3F CFD100J3F Non-Fused UL general purpose amp rating Handles Color Length inches/mm Marking Defeatable Padlockable Weight (lbs) 1, 3R, 12 4, 4X Metal Metal 6.9/175 6.9/175 O/I & OFF/ON O/I & OFF/ON Yes Yes Yes Yes 3.52 3.52 Catalog number BDFHNHS12 BDFHNHS4 Shafts Shaft length inches Mounting depth in inches 12 17 22.5 Weight (lbs) Catalog number 0.39 0.55 0.73 BDFHS12 BDFHS17 BDFHS22 Enclosed Fused BDFHNHS__ NEMA type For use on: Wire size Kit weight (lbs) Wire type Lugs per kit Catalog number BDCF30J6_& BDFLF60J6-F #14 – #4 #14 – #4 — — Cu Cu — — Standard Standard BDFLF100J6-F #14 – 2/0 0.43 Cu/Al 6 BDTL24 Enclosed Non-Fused Terminal lug kit BDFHS__ Door hardware — NEMA 12 BDTL24 Item Weight (lbs) Catalog number Safety door latch, 2 point with 6" handle 1.92 BDDHK Roller for 3 point latch, add to FH-DHK 0.39 BD3RL 19 Cable Operated Fusible Disconnect Switches for 30A – 800A UL Fuse Class CC, J, L & T For a complete assembly, please select one each of the following: + + + + Handle Cable Switch Lug kit (as required) Operating mechanism Fusible Fusible UL general purpose amp rating 30 30 60 100 Switch UL fuse type 600V Maximum horsepower rating 200-208V 240V Three-phase 480V 600V Poles CC J J J/T 5/7.5 5/7.5 15 25 7.5 7.5 15 30 15 15 30 60 20 20 50 75 Mechanism Part Number Switch Part Number 3 3 3 3 BMKCS2 BMKCS2 BMKCS3 BMKCS4 CFD30ACC3 CFD30AJ3 CFD60J3 CFD100AJ3 Non-Fused 200 J 50 60 125 150 3 BMKCS4 CFD200J03 400 J/T 100 125 250 350 3 Incl. FD400J3-FC 600 J/T 150 200 400 500 3 Incl. FD600J3-FC 800 L 200 250 500 600 3 Incl. FD800J3-FC Flange handles - UL 98; File #E101914 Environmental rating For use with: NEMA 1, 3R, 12 NEMA 4, 4X NEMA 1, 3R, 12 NEMA 4, 4X CFD30 - CFD200 Handle Catalog number FD400 - FD-800 BDHFC12 BDHFC4 BK7FCH BK7FCH4 Enclosed Fused Flexible cables Cable length (inches) For use with: Catalog number 36 48 60 72 84 96 108 48 60 72 84 CFD30 - CFD200 BFCL36 - BFCL108 BK7C048 - BK7C084 FD400 - FD800 Enclosed Non-Fused BFCL36 BFCL48 BFCL60 BFCL72 BFCL84 BFCL96 BFCL108 BK7C048 BK7C060 BK7C072 BK7C084 Terminal lug kits For use with: Wire size #4-300kcmil Cu/Al - 6 CDTL200 CFD100 - CFD200 #4-300kcmil Cu/Al - 3 CDTL200/3P Dist. lug 3 CDTL206 Lug kit 20 Lugs Description per kit Catalog number (6)#4-6AWG Cu/Al FD400J #2-600kcmil Cu/Al 6 BDTL26 FD600J - FD800L (12)#14-16 - 600kcmil Cu/Al 3 BDTL175/400 FD600J - & FD800L (2)#2 - 600kcmil Cu/Al 6 BDTL27 Door hardware — NEMA 12 BDTL175/400 Wire type Item Safety door latch, 2 point, door less than 40" high Safety door latch, 3 point, door greater than 40" high Catalog number BKDH2R BKDH3R UL & cULus Technical Data for Fusible Disconnect Switches CFD30CC3 – FD800L3 UL & cULus Catalog number 3 pole CFD30_3 CFD60J3 CFD100J3 FD400J3 FD600J3 FD800L3 Approvals1 2 pole 3 pole 4 pole N/A UL98 & IEC UL98 & IEC N/A UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC UL98 & IEC A 30 60 100 200 400 600 800 V 600 600 600 600 600 600 600 Max operating voltage Max horsepower rating/ Max motor FLA current pf = 0.4 – 0.5 Three phase 200 – 208V HP/A 5/16.8 – 7.5/24.2 15/46.2 25/75.0 50/143.0 100/273 – 125/344 150/396 200/528 240V HP/A 7.5/22.0 15/42.0 30/80.0 60/145.0 125/312.0 200/480.0 250/602.0 480V HP/A 15/21.0 30/40.0 60/77.0 125/156.0 250/302.0 400/477.0 500/590.0 600V HP/A 20/22.0 50/52.0 75/77.0 150/144.0 350/336.0 500/472.0 600/ — Single phase 120V HP/A 2/24.0 — — — — — — 240V HP/A 3/17.0 — — — — — — 200 200 200 200 200 200 200 Short circuit rating with fuse kA UL Fuse size A 30 60 100 200 400 600 800 J/CC J J/T J J/T J/T L 6000 6000 6000 6000 1000 1000 500 operation 20,000 20,000 20,000 20,000 12,000 10,000 7000 3 pole lb 1.54 2.86 3.30 5.9 17.2 37.48 37.48 4 pole lb 1.98 3.52 3.96 7.5 19.4 46.3 46.3 H in 3.82 3.94 5.66 6.5 7.87 11.42 11.42 W in 4.17 5.63 7.06 7.1 11.22 14.69 14.69 D in 4.21 5.04 5.09 5.2 8.11 9.21 9.21 in .24 x .24 .24 x .24 .24 x .24 .24 x .24 .47 x .47 .47 x .47 .47 x .47 UL Fuse type Endurances Min. Electrical endurance, pf = 0.75 – 0.80 operation cycles Fusible -40° to 40°C General purpose amp rating pf = 0.7 – 0.8 Non-Fused Technical ratings CFD200J03 Mechanical endurance Weight Dimension 3 pole Shaft size square Switch operating torque for rotary 3 pole switches mm 6x6 6x6 6x6 6x6 12 x 12 12 x 12 12 x 12 lb. in. 26.6 35.5 70.9 195 195 248 248 Integral Integral BDTL24 CDTL200 BDTL26 BDTL27 BDTL27 AWG #18 – 8 #14 – 4 #14 – 2/0 #4 – 300kcmil #2 – 600kcmil (2) #2 – 600 kcmil (2) #2 – 600 kcmil Terminal lug kits Wire range Torque: Wire tightening lb. in. 17 30 120 275 500 375 375 Lug mounting lb. in. N/A N/A 50 150 480 500 480 Enclosed Fused Physical characteristics NEMA ratings, AC — A600 A600 A600 A600 A600 A600 A600 250 600 600 600 600 600 600 600 A 6 10 10 10 10 10 10 10 AC maximum volt ampere making VA — 7200 7200 7200 7200 7200 7200 7200 AC maximum volt ampere breaking VA — 720 720 720 720 720 720 720 — P300 R300 R300 R300 P600 P600 P600 600 AC rated voltage AC thermal rated current VAC NEMA ratings, DC DC rated voltage VDC — 300 300 300 300 600 600 DC thermal rated current A — 1 1 1 1 5 5 5 DC maximum make break current A — 28 28 28 28 138 138 138 Enclosed Non-Fused Auxiliary contacts Torque: Wire tightening lb. in. 7 7 7 7 7 7 7 Wire range AWG #22 – 14/#18 – 14 #18 – 14 #22 – 14 #18 – 14 #22 – 14 #22 – 14 #22 – 14 1 The following UL Listed switches are also cULus approved. 21 IEC Technical Data for Fusible Disconnect Switches CFD30CC3 – FD800L3 IEC Catalog number 3 pole Technical ratings Rated insulation voltage1 Pollution degree 38V Dielectric strength CFD30_3 CFD60J3 CFD100J3 CFD200J03 FD400J3 FD600J3 FD800L3 -40° to 40°C 1000 50Hz/60Hz, 1 min kV Rated impulse withstand voltage kV 1000 1000 1000 1000 1000 1000 10 10 10 10 10 10 10 12 12 12 12 12 12 12 Fusible Rated thermal current, Ith/ max. fuse power dissipation2 AC 20/DC 20 open3 A/W 32/3.5 63/7.5 160/12 200/17 400/45 630/60 800/65 40°C enclosed A/W 32/3.5 63/7.5 160/10, 135/12 200/17 400/34, 360/37 600/45, 570/50 720/55 Enclosed with solid links A/W 32 85 175 280 450 700 900 with minimum cable cross section Cu mm2 6 16 70 95 240 2 x 185 2 x 240 1000 1000 1000 1000 1000 1000 1000 800 Rated operational voltage AC 20 and DC 20V AC Rated operational currents AC 21A AC 22A Non-Fused AC 23A 500V A 32 63 160 200 400 630 690V A 32 63 160 200 400 630 800 500V A 32 63 160 200 400 630 800 690V A 32 63 160 200 400 630 800 500V A 32 63 160 200 400 630 720 690V A 32 636 1606 200 400 630 720 DC Rated operational currents/poles in series DC21A DC22A Enclosed Fused DC23A 48V4 A 32/2 5 5 200/1 400/2 630/2 800/2 110V A 32/2 5 5 200/1 400/2 630/2 800/2 220V A 32/2 5 5 200/1 400/2 630/2 800/2 440V A 32/4 5 5 200/2 400/2 630/2 800/2 750V A — 5 5 180/4 400/3 630/1 800/3 1000V A — 5 5 — 400/4 630 800/4 48V4 A 32/2 5 5 200/1 400/2 630/2 800/2 110V A 32/2 5 5 200/1 400/2 630/2 800/2 220V A 32/2 5 5 200/1 400/2 630/2 800/2 440V A 32/4 5 5 200/2 400/2 630/2 800/2 750V A — 5 5 180/4 400/3 630/3 800/3 1000V A — 5 5 — 400/4 630/4 800/4 48V4 A 32/2 5 5 200/1 400/2 630/2 800/2 110V A 32/2 5 5 200/1 400/2 630/2 800/2 220V A 32/2 5 5 200/1 400/2 630/2 800/2 440V A 32/4 5 5 200/2 400/2 630/2 800/2 750V A — 5 5 180/4 400/3 630/3 800/3 1000V A — 5 5 — — 630/4 800/4 Rated operational power AC23A Enclosed Non-Fused 230V kW 8 18.5 45 60 110 180 200 400V kW 14 30 80 110 210 315 350 415V kW 15 30 90 110 230 340 380 500V kW 18 37 110 140 280 400 470 690V kW 25 60 132 190 330 540 600 Load 2 poles in series 1 2 3 4 5 6 8 3 poles in series 4 poles in series 1000V, IEC 408. Ambient temperature 60°C: derating 20 percent. Mounting on ceiling: derating 10 percent. Mounting on wall, horizontal fuses: derating 8 percent. The ambient air temperature does not exceed +40°C and its average over a period of 24h does not exceed +35°C according to IEC 947. For 30A switches, use 2 parallel contacts in series. Available on request. IEC 947-3, utilization category B, infrequent operation. Pollution degree 3: Conductive pollution occurs, or dry, non-conductive pollution occurs, which becomes conductive due to condensation. 22 2 + 2 Parallel contacts in series IEC Technical Data for Fusible Disconnect Switches CFD30CC3 – FD800L3 IEC Catalog number 3 pole CFD30_3 CFD60J3 CFD100J3 CFD200J03 FD400J3 FD600J3 FD800L3 Rated breaking capacity in category AC-23A 500V A 256 504 1280 1600 3200 5760 5760 690V A 256 504 1280 1600 3200 5760 5760
BDTA1 价格&库存
很抱歉,暂时无法提供与“BDTA1”相匹配的价格&库存,您可以联系我们找货
