Technical data 2092
Effective December 2015
Supersedes June 2011
BUSSMANN
SERIES
1-Pole IEC Class I coordinated lightning current arresters for
75V to 1000V TN and TT wind power systems
TN and 1-phase TT system arresters
The features of these single-pole devices are for
use as a single device or in combination with other
devices.
TT system arresters
Remote
contact
signaling
available
Provide a current arresting means between
neutral conductor and protective conductor in
TT systems. These devices help ensure fulfilling
the requirements for protection of personnel and
equipment in “3+1” and “1+1” circuits.
Optional remote contact signaling
easyID™ local
visual status
indication
The three-pole terminal remote contact signaling
option has a floating changeover contact for use
as a break or make contact, according to circuit
concept.
Specifications:
System volts
t
Catalog symbol:
75Vac to 1000Vac (see ordering information
table for details)
t
BSPG1230WE
System types
t
BSPG1230WER
t
TN
t
BSPM_WE
t
TT
t
BSPM_WER
Agency information
Description:
Eaton’s Bussman™ series of one-pole IEC Class
II modular surge arresters feature local, easyID™
visual indication and optional remote contact
signaling. The unique module locking system on
the 75 to 690 volt arresters fixes the protection
module to the base part. Modules can be easily
replaced without tools by simply depressing the
release buttons. Integrated mechanical coding
between the base and protection module ensures
against installing an incorrect replacement module.
t
CE
t
CSA
t
KEMA
t
RoHS compliant
Mounting
t
35mm DIN-Rail
Warranty
t
Five years
Technical Data 2092
1-Pole IEC Class II surge arresters for
75V-1000V TN and TT wind power systems
Dimensions - mm:
Module circuit diagrams:
75V to 690V
Shown with optional remote contact signaling.
Gas discharge tube (single)
Thermal disconnecter
MOV
BSPM175WE(R)
BSPM1400WE(R)
BSPM1690WE(R)
1000V
BSPG1230WE(R)
BSPM11000WE(R)
2
Eaton.com/bussmannseries
Technical Data 2092
Ordering information:
System voltage (50-60Hz) / poles
Max. Continuous Operating Voltage
(MCOV) [UC] AC (50-60Hz)
W/ remote
signaling
Catalog numbers
(base + modules)
W/ remote
signaling
Replacement modules
Specifications
Line system type
Max. continuous operating DC voltage
[UC]
Rated varistor voltage AC [Umov]
Nominal discharge current (8/20μs) [In]
Max. discharge current (8/20μs) [Imax]
Follow current extinguishing capability [Ifi]
Lightning impulse current (10/350μs) [Iimp]
Voltage protection level
[UP]
[UP] at 5kA
Response time [tA]
Max. mains-side overcurrent protection
Short-circuit withstand capability for max.
mains-side overcurrent protection (ISCCR)
Withstand
Temporary Overvoltage
(TOV) [UT]
Safe failure
Agency information
Capacity (DIN 43880)
SPD according to
Operating environment [TU]
Operating state/fault indication
Number of ports
Min.
Cross-Sectional Area
Max.
Mounting
Enclosure material
Location category
Degree of protection
Product warranty
75V / 1
230V / 1
400V / 1
400V†/690V†† / 1 1000V / 1
75V
255V
440V
600V
1000V
BSPM175WE
BSPG1230WE
BSPM1400WE
BSPM1690WE
BSPM11000WE
BSPM175WER
BSPG1230WER
BSPM1400WER
BSPM1690WER
BSPM11000WER
BPM75WE
BPG255NPEWE*
BPM440WE
BPM750WE
N/A
TN / TT
TT
TN / TT
TN / TT
TN / TT
100V
585
600V
1000V
10kA
40kA
) 0.4kV
) 0.35kV
) 25 ns
125A gG
20kA
40kA
100 Arms
12kA
) 1.5kV
) 100 ns
20kA
40kA
) 2.0kV
) 1.7kV
) 25 ns
125A gG
750V
15kA
25kA
) 3kV
) 2.5kV
) 25 ns
100A gG
1000V
15kA
30kA
) 4.2kV
) 3.5kV
) 25 ns
100A aM**
50kArms
25kArms
25kArms
25kArms
90V / 5 sec.
1200V / 200ms
580V / 5 sec.
900V / 5 sec.
1000V / 5 sec.
KEMA, CSA
1 Mod.
2 Mod.
KEMA, CSA
KEMA
KEMA, CSA
1 Mod.
1 Mod.
1 Mod.
EN 61643-11 Type 2, IEC 61643-11 Class II
-40°C to +80°C, 5% to 95% RH
Green (good) / Red (replace)
1
1.5mm2 / 14AWG solid / flexible
35mm2 / 2AWG stranded-25mm2 / 4AWG flexible
35mm DIN-Rail per EN 60715
Thermoplastic, UL 94V0
Indoor
IP20 (built-in)
Five years***
Remote contact signaling
Remote contact signaling type
Changeover contact
AC
250V / 0.5A
Switching capacity
(volts/mps)
DC
250V / 0.1A; 125V / 0.2A; 75V / 0.5A
Conductor ratings and cross-sectional area 60/75°C Max. 1.5mm2 / 14AWG solid / flexible
Order from catalog numbers above
N-PE surge arrester for location between neutral conductor and protective conductor in TT systems.
125A gG @ 690Vac.
See Eaton’s Bussmann series SPD limited warranty statement (3A1502) for details at www.cooperbussmann.com/surge.
400V [L-N]
690V [L-L]
Recommended Bussmann series NH DIN back up fuses
Size
Fuse catalog number
00
100NHG00B-690
00
125NHG00B-690
3
Technical Data 2092
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 2092 — MC-SB15XXX
December 2015
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BPG255NPEWE”相匹配的价格&库存,您可以联系我们找货
