SL221R020-B
SL221R020-B
    MATRIXORBITAL
    ICL1OHM20%20A22MM
SL221R020-B 数据手册
Data Sheet SL22 1R020 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 22.0 ± max 6.0 ± max 1.0 ± nom S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 4.0 ± max B: 9.20 ± nom C: 2.74 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 1.0 Ω ± 20 % 20.00 A 65 J 200 J Maximum Capacitance @ 120 VAC: 4,400 µf Maximum Capacitance @ 240 VAC: 1,000 µf Resistance @ 100% Max Current: 0.00 Ω Resistance @ 50% Max Current: 0.03 Ω 187.00 °c 32.4 mw/°c 40 Sec. Max Rec. Energy Rating: Actual Failure Instantaneous Energy: Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): B SL22 1R020 Date: 01/08/2016 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Chad Terry Revison: B
SL221R020-B 价格&库存
很抱歉,暂时无法提供与“SL221R020-B”相匹配的价格&库存,您可以联系我们找货
