MS325R020
MS325R020
    MATRIXORBITAL
    ICL5OHM25%20A30MM
MS325R020 数据手册
Data Sheet MS32 5R020 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 31.0 ± max 8.0 ± max 1.0 ± nom S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 5.0 ± max B: 7.80 ± nom C: 5.70 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 5.0 Ω ± 20 % 20.00 A Max Rec. Energy Rating: 300 J Actual Failure Instantaneous Energy: 670 J Maximum Capacitance @ 120 VAC: 20,700 µf Maximum Capacitance @ 240 VAC: 5,209 µf Maximum Capacitance @ 440 VAC: 1,204 µf Maximum Capacitance @ 680 VAC: 600 µf Resistance @ 100% Max Current: 0.00 Ω Resistance @ 50% Max Current: 0.10 Ω 204.00 °c 55.4 mw/°c 194 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): G MS32 5R020 Date: 11/11/2008 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: 1 (7/26/2015)
MS325R020 价格&库存
很抱歉,暂时无法提供与“MS325R020”相匹配的价格&库存,您可以联系我们找货
