MS355R025
MS355R025
    MATRIXORBITAL
    ICL5OHM25A35MM
MS355R025 数据手册
Data Sheet MS35 5R025 ISO9001:2008 Certified Mechanical Specifications (mm) D: 38.0 T: 10.0 ± Max 2.5 ± Nom Lead Diameter ± Max S: 19.0 ± Nom L: 40.0 ± Nom Coating Lead Run Down (straight Leads) 7.0 ± Max B: C: ± 7.50 ± Nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 5.0 Ω ± 25 % 25.00 A 600 J 1200 J Maximum Capacitance @ 120 VAC: 41,250 µf Maximum Capacitance @ 240 VAC: 10,419 µf Maximum Capacitance @ 440 VAC: 2,408 µf Maximum Capacitance @ 680 VAC: 1,200 µf Resistance @ 100% Max Current: 0.03 Ω Resistance @ 50% Max Current: 0.08 Ω 212.00 °c 102.5 mw/°c 134 Sec. Max Rec. Energy Rating: Actual Failure Instantaneous Energy: Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): H MS35 5R025 Date: 08/15/2012 Ametherm, Inc. 3111 N. Deer Run Road Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landi Approved By: Mehdi Samii Revison:
MS355R025 价格&库存
很抱歉,暂时无法提供与“MS355R025”相匹配的价格&库存,您可以联系我们找货
