SL1210006-03
SL1210006-03
    MATRIXORBITAL
    ICL10OHM20%6A12MM
SL1210006-03 数据手册
DATA SHEET Part Number: SL12 10006-03 Ordering Different Lead Types: Inside Kinked Leads Outside Kinked Leads Use -A after Ametherm’s part # Use -B after Ametherm’s part # For example: to order an inside kinked lead use part number SL12 10006-03-A D D D T C B L S S S STRAIGHT LEADS OUTSIDE KINKED LEADS INSIDE KINKED LEADS Electrical Specifications: Mechanical Specifications: Resistance @ 25°C Max Steady State Current Up to 65°C Max Recommended Energy Rating (Joules) Actual Failure Point of Instantaneous Energy (Joules) Resistance @ 100% of Max Current Resistance @ 50% of Max Current Body Temperature @ 100% Current Rating Dissipation Constant Thermal Time Constant Material Type Max Recommended Capacitance @ 120VAC/240VAC 10.0 Ω ± 20% 6.0 A 40.0 J 80.0 J 0.120 Ω 0.242 Ω 177 °C 13.5mW/°C 42 seconds “C” 2700µF/690µF CSA File Number: #CA118061 D T Lead Diameter S L Straight Leads Coating Run Down B C 12.0 ± 0.5 mm 5.1 ± 0.2 mm 1.0 ± 0.1 mm 7.8 ± 2.0 mm 38.0 ± 9.0 mm 5.0 ± 1.0 mm 6.35 ± 0.60 mm 3.42 ± 0.5 mm Revision Date: March 19, 2003 Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com
SL1210006-03
物料型号: - 型号:SL12 10006-03 - 订购不同引线类型时,内部弯曲引线使用后缀-A,外部弯曲引线使用后缀-B。
器件简介: - 该器件为Ametherm公司生产的电路保护热敏电阻。
引脚分配: - 引脚直径:1.0±0.1 mm。
参数特性: - 25°C时的电阻:10.0 ±20% - 65°C以下最大稳态电流:6.0 A - 最大推荐能量额定值(焦耳):40.0J - 实际故障点的瞬时能量(焦耳):80.0J - 100%最大电流时的电阻:0.120 - 50%最大电流时的电阻:0.242 - 100%电流额定值时的体温度:177°C - 耗散常数:13.5mW/°C - 热时间常数:42秒 - 材料类型:"C" - 120VAC/240VAC下最大推荐电容:2700 F/690uF
功能详解: - 该热敏电阻主要用于电路过载保护,当电流超过规定值时,其电阻迅速增加,限制电流,从而保护电路。
应用信息: - 适用于需要过载保护的电路,例如电源、电机等。
封装信息: - 直径D:12.0±0.5 mm - 高度T:5.1±0.2 mm - 引线间距S:7.8±2.0 mm - 长度L:38.0±9.0 mm - 直引线涂层流下距离:5.0±1.0 mm - 宽度B:6.35±0.60 mm - 深度C:3.42±0.5 mm
SL1210006-03 价格&库存
很抱歉,暂时无法提供与“SL1210006-03”相匹配的价格&库存,您可以联系我们找货
