AS3210015
AS3210015
    MATRIXORBITAL
    ICL10OHM25%15A30MM
AS3210015 数据手册
DATA SHEET Part Number: AS32 10015 D T L A S C B Electrical Specifications: Mechanical Specifications: 10.0   25 % 15.0 A D 30.0 mm Max Max recommended energy rating (Joules) 250.00 J T 8.50 mm Max Actual failure point of instantaneous energy (Joules) 500.00 J 17.1 mm Nom Resistance @ 100% of Max Current 0.046  S Straight Leads Coating run down L A (Lead Width) 2.2 mm Nom B 3.7 mm Nom C (Lead Thickness) 0.8 mm Nom Resistance @ 25°c Max Steady State Current Up to 65°c Resistance @ 50% of Max Current Body Temperature @ 100% Current rating Dissipation Constant Cool down time: 50% of Initial R Cool down time: 100% of Initial R Material Type ROHS Compliant MSL (moisture sensitivity level) 0.100 185 °C 85.20 mW/°C 33 sec 64 sec I Yes #1 Revision Date: 11/1/21 Ametherm, Inc. 961 Fairview Dr. Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com 5.0 mm Max 21.0 mm Nom
AS3210015 价格&库存
很抱歉,暂时无法提供与“AS3210015”相匹配的价格&库存,您可以联系我们找货
