AS3250006
AS3250006
    MATRIXORBITAL
    ICL50OHM25%6A30MM
AS3250006 数据手册
DATA SHEET Part Number: AS32 50006 D T L A C S B Electrical Specifications: Mechanical Specifications: 50.0   25 % 6.0 A D 30.0 mm Max Max recommended energy rating (Joules) 250.00 J T 9.0 mm Max Actual failure point of instantaneous energy (Joules) 600.00 J 17.1 mm Nom Resistance @ 100% of Max Current 0.305  S Straight Leads Coating run down L A (Lead Width) 2.2 mm Nom B 5.3 mm Nom C (Lead Thickness) 0.8 mm Nom Resistance @ 25°c Max Steady State Current Up to 65°c Resistance @ 50% of Max Current Body Temperature @ 100% Current rating Dissipation Constant Cool down time: 50% of Initial R Cool down time: 100% of Initial R Material Type ROHS Compliant MSL (moisture sensitivity level) 1.050  212 °C 78.20 mW/°C 38 sec 73 sec B Yes #1 Revision Date: 11/1/21 Ametherm, Inc. 961 Fairview Dr. Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com 5.5 mm Max 21.0 mm Nom
AS3250006 价格&库存
很抱歉,暂时无法提供与“AS3250006”相匹配的价格&库存,您可以联系我们找货
