AS353R030
AS353R030
    MATRIXORBITAL
    ICL3OHM25%30A36MM
AS353R030 数据手册
DATA SHEET Part Number: AS35 3R030 D T L A C S B Electrical Specifications: Mechanical Specifications: 3.0   25 % 30.0 A D 36.0 mm Max Max recommended energy rating (Joules) 600.0 J T 8.5 mm Max Actual failure point of instantaneous energy (Joules) 1200.0 J 19.0mm Nom Resistance @ 100% of Max Current 0.020  S Straight Leads Coating run down L 21.0 mm Nom A (Lead Width) 2.2 mm Nom B 5.5 mm Nom C (Lead Thickness) 0.8 mm Nom Resistance @ 25°c Max Steady State Current Up to 65°c Resistance @ 50% of Max Current Body Temperature @ 100% Current rating Dissipation Constant Thermal Time Constant Material Type ROHS Compliant MSL (moisture sensitivity level) 0.048  226 °C 83.50 Mw/°C 55 seconds B Yes #1 Revision Date: 10/29/21 Ametherm, Inc. 961 Fairview Drive Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com 6.0 mm Max
AS353R030 价格&库存
很抱歉,暂时无法提供与“AS353R030”相匹配的价格&库存,您可以联系我们找货
