AS3220010
AS3220010
    MATRIXORBITAL
    ICL20OHM25%10A29MM
AS3220010 数据手册
DATA SHEET Part Number: AS32 20010 D T L A S C B Electrical Specifications: Mechanical Specifications: 20.0   25 % 10.0 A D 29.0 ±2.0mm Max recommended energy rating (Joules) 250.00 J T 9.0 ±1.0mm Actual failure point of instantaneous energy (Joules) 500.00 J S Straight Leads Coating run down L 17.1 ±2.0mm A (Lead Width) 2.2 ±0.2mm B 6.4±1.0mm C (Lead Thickness) 0.9 ±0.2mm Resistance @ 25°c Max Steady State Current Up to 65°c Resistance @ 100% of Max Current Body Temperature @ 100% Current rating Dissipation Constant Cool down time: 50% of Initial R Cool down time: 100% of Initial Resistance Material Type ROHS Compliant MSL (moisture sensitivity level) 0.150  192°C 58mW/°C 36 sec 67 sec I Yes #1 Revision Date: 11/1/21 Ametherm, Inc. 961 Fairview Dr. Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com 5.0 ±3.0mm 22.0±2.0mm
AS3220010 价格&库存
很抱歉,暂时无法提供与“AS3220010”相匹配的价格&库存,您可以联系我们找货
