SL1522101-A
SL1522101-A
    MATRIXORBITAL
    ICL220OHM25%1A15MM
SL1522101-A 数据手册
DATA SHEET Part Number: SL15 22101 Ordering Different Lead Types: Inside Kinked Leads Outside Kinked Leads Use -A after Ametherm’s part # Use -B after Ametherm’s part # For example: to order an inside kinked lead use part number SL15 22101-A D D D T C B L S S S STRAIGHT LEADS OUTSIDE KINKED LEADS INSIDE KINKED LEADS Electrical Specifications: Mechanical Specifications: Resistance @ 25°C Max Steady State Current Up to 65°C Max Recommended Energy Rating (Joules) Resistance @ 100% of Max Current Resistance @ 50% of Max Current Body Temperature @ 100% Current Rating Dissipation Constant Thermal Time Constant Material Type Max Capacitance @ 120VAC/240VAC 220.0 Ω ± 25% 1.0 A 50.0 J 1.900 Ω 4.500 Ω 179 °C 15mW/°C 45 seconds “L” 3200µF/800µF D T Lead Diameter S L Straight Leads B C Coating Run Down on the Straight Leads CSA File Number: #CA118061 15.0 ± 0.5 mm 5.0 ± 0.2 mm 0.8 ± 0.1 mm 7.8 ± 0.30 mm 38.0 ± 1.50 mm Standard 7.50 ± 0.70 mm 3.60 ± 0.40 mm 5.00 ± 0.5 mm Revision Date: July 8, 2003 Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com
SL1522101-A 价格&库存
很抱歉,暂时无法提供与“SL1522101-A”相匹配的价格&库存,您可以联系我们找货
