MS3220010-B
MS3220010-B
    MATRIXORBITAL
    ICL20OHM25%10A31MM
MS3220010-B 数据手册
Data Sheet MS32 20010 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: 31.0 T: 10.0 ± max 1.0 ± nom Lead Diameter ± max S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 4.0 ± max B: 7.80 ± nom C: 6.70 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 20.0 Ω ± 25 % 10.00 A Max Rec. Energy Rating: 250 J Actual Failure Instantaneous Energy: 500 J Maximum Capacitance @ 120 VAC: 17,000 µf Maximum Capacitance @ 240 VAC: 4,341 µf Maximum Capacitance @ 440 VAC: 1,003 µf Maximum Capacitance @ 680 VAC: 500 µf Resistance @ 100% Max Current: 0.00 Ω Resistance @ 50% Max Current: 0.64 Ω 224.00 °c 45.4 mw/°c 194 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): I MS32 20010 Date: 02/05/2009 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
MS3220010-B 价格&库存
很抱歉,暂时无法提供与“MS3220010-B”相匹配的价格&库存,您可以联系我们找货
