MS2222103
MS2222103
    MATRIXORBITAL
    ICL220OHM25%3.5A20MM
MS2222103 数据手册
Data Sheet MS22 22103 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: 23.0 T: 10.0 ± max 1.0 ± nom Lead Diameter ± max S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 4.0 ± max B: 9.20 ± nom C: 7.30 ± nom Electrical Specifications Resistance: 220.0Ω Max Steady State Current upto 65°c: ± 25 % 3.00 A 75 J 175 J Maximum Capacitance @ 120 VAC: 5,100 µf Maximum Capacitance @ 240 VAC: 1,302 µf Maximum Capacitance @ 440 VAC: 301 µf Maximum Capacitance @ 680 VAC: 150 µf Resistance @ 100% Max Current: 1.00 Ω Resistance @ 50% Max Current: 2.75 Ω 144.00 °c 45.4 mw/°c 114 Sec. Max Rec. Energy Rating: Actual Failure Instantaneous Energy: Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): L MS22 22103 Date: 11/11/2008 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
MS2222103 价格&库存
很抱歉,暂时无法提供与“MS2222103”相匹配的价格&库存,您可以联系我们找货
