AS321R030
AS321R030
    MATRIXORBITAL
    ICL1OHM25%30A30MM
AS321R030 数据手册
Data Sheet AS32 1R030 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: 30.0 ± Max 8.0 ± Max Lead Diameter ± S: 17.1 ± Nom L: 22.0 ± Nom Coating Lead Run Down (straight Leads) 4.5 ± Max B: 2.40 ± Nom C: 0.80 ± Nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 1.0 Ω ± 25 % 30.00 A Max Rec. Energy Rating: 300 J Actual Failure Instantaneous Energy: 600 J Resistance @ 100% Max Current: 0.01 Ω Resistance @ 50% Max Current: 0.03 Ω 215.00 °c 48.0 mw/°c 55 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): B AS32 1R030 Date: 03/15/2011 Ametherm, Inc. 3111 N. Deer Run Road Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
AS321R030
物料型号:AS321R030
器件简介:文档中未提供器件简介
引脚分配:文档中未提供引脚分配信息。
参数特性: - 电阻:1.0欧姆 - 25°C时最大稳态电流:30.00A - 最大推荐能量等级:300焦耳 - 实际故障瞬间能量:600焦耳 - 100%最大电流时的电阻:0.01欧姆 - 50%最大电流时的电阻:0.03欧姆 - 100%最大电流时的体温度:215.00°C - 耗散常数:48.0毫瓦/°C - 热时间常数:55秒 - 材料类型(用于Beta和曲线):B
功能详解:文档中未提供功能详解
应用信息:文档中未提供应用信息
封装信息:引脚直径D:30.0mm,最大长度L:22.0mm,标称长度17.1mm,标称间距S:±8.0mm,标称涂层铅下垂±4.5mm,标称C:±0.80mm,标称B:2.40mm。
AS321R030 价格&库存
很抱歉,暂时无法提供与“AS321R030”相匹配的价格&库存,您可以联系我们找货
