SL0810001-A
SL0810001-A
    MATRIXORBITAL
    ICL10OHM20%1A8MM
SL0810001-A 数据手册
DATA SHEET Part Number: SL08 10001 Ordering Different Lead Types: Inside Kinked Leads Outside Kinked Leads Use -A after Ametherm’s part # Not Available For example: to order an inside kinked lead use part number SL08 10001-A D D D T C B L S S S STRAIGHT LEADS OUTSIDE KINKED LEADS INSIDE KINKED LEADS Electrical Specifications: Mechanical Specifications: Resistance @ 25°C Max Steady State Current Up to 65°C Max Recommended Energy Rating (Joules) Actual Failure Point of Instantaneous Energy (Joules) Resistance @ 100% of Max Current Resistance @ 50% of Max Current Power Consumption @ Max Current Body Temperature @ 100% Current Rating Dissipation Constant Thermal Time Constant 10.0 Ω ± 20% 1.0 A 8.0 J 17.0 J 0.680 Ω 1.20 Ω 1.935 Watts 134 °C 9.0mW/°C 27 Seconds CSA File #: CA 118061 D T Lead Diameter S L Inside Kink B C 8.0 ± 0.3 mm 3.5 ± 0.3 mm 0.5 ± 0.1 mm 6.35 ± 0.5 mm 38.0 ± 9.0 mm See Dimension B 7.5 ± 3.50 mm 2.82 ± 0.5 mm Revision Date: March 19, 2003 Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com
SL0810001-A 价格&库存
很抱歉,暂时无法提供与“SL0810001-A”相匹配的价格&库存,您可以联系我们找货
