SL0822101
SL0822101
    MATRIXORBITAL
    ICL220OHM25%1A8MM
SL0822101 数据手册
DATA SHEET Part Number: SL08 22101 Ordering Different Lead Types: Inside Kinked Leads Outside Kinked Leads Use -A after Ametherm’s part # Not Available For example: to order an inside kinked lead use part number SL08 22101-A D D D T C B L S S S STRAIGHT LEADS OUTSIDE KINKED LEADS INSIDE KINKED LEADS Electrical Specifications: Mechanical Specifications: Resistance @ 25°C Max Steady State Current Up to 65°C Max Recommended Energy Rating (Joules) Actual Failure Point of Instantaneous Energy (Joules) Resistance @ 100% of Max Current Resistance @ 50% of Max Current Body Temperature @ 100% Current Rating Dissipation Constant Thermal Time Constant Material Type Max Recommended Capacitance @ 120 VAC Max Operating Temperature 220.0 Ω ± 25% 1.0 A 8.0 J 16.0 J 1.90 Ω 4.14 Ω 152 °C 9.0mW/°C 20 seconds “M” 450µF 150°C CSA File #: CA 118061 D T Lead Diameter S L Straight Leads Coating Run Down B C 8.0 ± 0.5 mm 4.0 ± 0.5 mm 0.5 ± 0.1 mm 6.4 ± 2.0 mm 38.0 ± 3.0 mm 5.0 ± 1.0 mm 11.5 ± 3.50 mm 1.50 ± 0.2 mm Revision Date: March 19, 2003 Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com
SL0822101 价格&库存
很抱歉,暂时无法提供与“SL0822101”相匹配的价格&库存,您可以联系我们找货
