DATA SHEET
Part Number: SL08 22101
Ordering Different Lead Types:
Inside Kinked Leads
Outside Kinked Leads
Use -A after Ametherm’s part #
Not Available
For example: to order an inside kinked lead use part number SL08 22101-A
D
D
D
T
C
B
L
S
S
S
STRAIGHT
LEADS
OUTSIDE
KINKED LEADS
INSIDE
KINKED LEADS
Electrical Specifications:
Mechanical Specifications:
Resistance @ 25°C
Max Steady State Current Up to 65°C
Max Recommended Energy Rating (Joules)
Actual Failure Point of Instantaneous Energy (Joules)
Resistance @ 100% of Max Current
Resistance @ 50% of Max Current
Body Temperature @ 100% Current Rating
Dissipation Constant
Thermal Time Constant
Material Type
Max Recommended Capacitance @ 120 VAC
Max Operating Temperature
220.0 Ω ± 25%
1.0 A
8.0 J
16.0 J
1.90 Ω
4.14 Ω
152 °C
9.0mW/°C
20 seconds
“M”
450µF
150°C
CSA File #: CA 118061
D
T
Lead Diameter
S
L
Straight Leads
Coating Run Down
B
C
8.0 ± 0.5 mm
4.0 ± 0.5 mm
0.5 ± 0.1 mm
6.4 ± 2.0 mm
38.0 ± 3.0 mm
5.0 ± 1.0 mm
11.5 ± 3.50 mm
1.50 ± 0.2 mm
Revision Date: March 19, 2003
Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701
Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670
www.ametherm.com
很抱歉,暂时无法提供与“SL0822101-A”相匹配的价格&库存,您可以联系我们找货
