SL125R005-A
SL125R005-A
    MATRIXORBITAL
    ICL5OHM20%5A12MM
SL125R005-A 数据手册
DATA SHEET Part Number: SL12 5R005 Ordering Different Lead Types: Inside Kinked Leads Outside Kinked Leads Use -A after Ametherm’s part # Use -B after Ametherm’s part # For example: to order an inside kinked lead use part number SL12 5R005-A D D D T C B L S S S STRAIGHT LEADS OUTSIDE KINKED LEADS INSIDE KINKED LEADS Electrical Specifications: Mechanical Specifications: Resistance @ 25°C Max Steady State Current Up to 65°C Max Recommended Energy Rating (Joules) Actual Failure Point of Instantaneous Energy (Joules) Resistance @ 100% of Max Current Resistance @ 50% of Max Current Body Temperature @ 100% Current Rating Dissipation Constant Thermal Time Constant Max Recommended Capacitance @ 265Vrms Max Voltage Rating 5.0 Ω ± 20% 5.0 A 25.0 J 50.0 J 0.150 Ω 0.300 Ω 172 °C 12.7mW/°C 47 seconds 350µF 265Vrms CSA File Number: #CA118061 D T Lead Diameter S L Straight Leads Coating Run Down B C 12.0 ± 0.5 mm 5.1 ± 0.2 mm 0.8 ± 0.1 mm 7.8 ± 2.0 mm 38.0 ± 9.0 mm 5.0 ± 1.0 mm 6.0 ± 0.60 mm 3.42 ± 0.50 mm Revision Date: March 19, 2003 Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com
SL125R005-A 价格&库存
很抱歉,暂时无法提供与“SL125R005-A”相匹配的价格&库存,您可以联系我们找货
