SL1210006-B
SL1210006-B
    MATRIXORBITAL
    ICL10OHM20%6A13MM
SL1210006-B 数据手册
Data Sheet SL12 10006 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 12.3 ± max 5.5 ± max 0.8 ± nom S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 5.0 ± max B: 6.00 ± nom C: 3.78 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 10.0 Ω ± 20 % 6.00 A Max Rec. Energy Rating: 40 J Actual Failure Instantaneous Energy: 80 J Maximum Capacitance @ 120 VAC: 2,778 µf Maximum Capacitance @ 240 VAC: 694 µf Resistance @ 100% Max Current: 0.00 Ω Resistance @ 50% Max Current: 0.24 Ω 177.00 °c 13.5 mw/°c 42 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): C SL12 10006 Date: 11/11/2008 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
SL1210006-B 价格&库存
很抱歉,暂时无法提供与“SL1210006-B”相匹配的价格&库存,您可以联系我们找货
