MS1215102-A
MS1215102-A
    MATRIXORBITAL
    ICL150OHM25%2A13.5MM
MS1215102-A 数据手册
Data Sheet MS12 15102 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 13.5 ± max 8.7 ± max 1.0 ± nom S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 4.0 ± 6.0 B: 7.00 ± nom C: 7.40 ± nom Electrical Specifications Resistance: 150.0Ω Max Steady State Current upto 65°c: ± 25 % 2.00 A Max Rec. Energy Rating: 110 J Actual Failure Instantaneous Energy: 231 J Maximum Capacitance @ 120 VAC: 7,500 µf Maximum Capacitance @ 240 VAC: 1,910 µf Maximum Capacitance @ 440 VAC: 441 µf Maximum Capacitance @ 680 VAC: 220 µf Resistance @ 100% Max Current: 1.00 Ω Resistance @ 50% Max Current: 2.70 Ω 172.00 °c 12.7 mw/°c 71 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): I MS12 15102 Date: 11/11/2008 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
MS1215102-A 价格&库存
很抱歉,暂时无法提供与“MS1215102-A”相匹配的价格&库存,您可以联系我们找货
