MS1515004-A
MS1515004-A
    MATRIXORBITAL
    ICL15OHM25%4.5A15MM
MS1515004-A 数据手册
DATA SHEET Part Number: MS15 15004 Ordering Different Lead Types: Inside Kinked Leads Outside Kinked Leads Use -A after Ametherm’s part # Use -B after Ametherm’s part # For example: to order an inside kinked lead use part number MS15 15004-A D D D T C B L S S S STRAIGHT LEADS OUTSIDE KINKED LEADS INSIDE KINKED LEADS Electrical Specifications: Mechanical Specifications: Resistance @ 25°C Max Steady State Current Up to 65°C Max Recommended Energy Rating (Joules) Actual Failure Point of Instantaneous Energy (Joules) Resistance @ 100% of Max Current Resistance @ 50% of Max Current Body Temperature @ 100% Current Rating Dissipation Constant Thermal Time Constant Material Type Max Recommended Capacitance @120/240/440VAC 15.0 Ω ± 25% 4.5A 155.0 J 310.0 J 0.200 Ω 0.850 Ω 144 °C 49.4mW/°C 114 seconds “G” 10500µF/2600µF/ 800µF D T Lead Diameter S L Straight Leads Coating Run Down B C 15.0 ± 1.0 mm 7.0 ± 0.7 mm 1.0 ± 0.1 mm 7.8 ± 2.0 mm 38.0 ± 9.0 mm 5.0 ± 1.0 mm 6.30 ± 0.60 mm 6.50 ± 0.60 mm Revision Date: March 19, 2003 Ametherm, Inc. 3111 N. Deer Run Road #4 Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com
MS1515004-A 价格&库存
很抱歉,暂时无法提供与“MS1515004-A”相匹配的价格&库存,您可以联系我们找货
