MS2212103-A
MS2212103-A
    MATRIXORBITAL
    ICL120OHM25%3A23MM
MS2212103-A 数据手册
Data Sheet MS22 12103 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: 23.0 T: 10.0 ± max 1.0 ± nom Lead Diameter ± max S: 7.8 ± nom L: 38.0 ± nom Coating Lead Run Down (straight Leads) 4.0 ± max B: 9.20 ± nom C: 7.60 ± nom Electrical Specifications Resistance: 120.0Ω Max Steady State Current upto 65°c: ± 25 % 3.00 A Max Rec. Energy Rating: 220 J Actual Failure Instantaneous Energy: 450 J Maximum Capacitance @ 120 VAC: 15,000 µf Maximum Capacitance @ 240 VAC: 3,820 µf Maximum Capacitance @ 440 VAC: 883 µf Maximum Capacitance @ 680 VAC: 440 µf Resistance @ 100% Max Current: 1.28 Ω Resistance @ 50% Max Current: 2.65 Ω 165.00 °c 75.4 mw/°c 124 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): M MS22 12103 Date: 02/05/2009 Ametherm, Inc. 3111 N. Deer Run Road Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
MS2212103-A 价格&库存
很抱歉,暂时无法提供与“MS2212103-A”相匹配的价格&库存,您可以联系我们找货
