MS2275004-A
MS2275004-A
    MATRIXORBITAL
    ICL75OHM25%4A23MM
MS2275004-A 数据手册
Data Sheet MS22 75004 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 23.0 ± max 9.0 ± max 1.0 ± nom S: 7.8 ± nom nom L: 38.0 ± Coating Lead Run Down (straight Leads) 4.0 ± max B: 9.20 ± nom C: 6.90 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 75.0 Ω ± 25 % 4.00 A Max Rec. Energy Rating: 240 J Actual Failure Instantaneous Energy: 430 J Maximum Capacitance @ 120 VAC: 16,400 µf Maximum Capacitance @ 240 VAC: 4,167 µf Maximum Capacitance @ 440 VAC: 963 µf Maximum Capacitance @ 680 VAC: 480 µf Resistance @ 100% Max Current: 0.00 Ω Resistance @ 50% Max Current: 0.90 Ω 169.00 °c 51.8 mw/°c 122 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): M MS22 75004 Date: 11/11/2008 Ametherm, Inc. 961 Fairview Drive Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: A
MS2275004-A 价格&库存
很抱歉,暂时无法提供与“MS2275004-A”相匹配的价格&库存,您可以联系我们找货
