AS320R530
AS320R530
    MATRIXORBITAL
    ICL0.5OHM25%30A29MM
AS320R530 数据手册
DATA SHEET Part Number: AS32 0R530 D T L A C S B Electrical Specifications: Mechanical Specifications: 0.5   25 % 30.0 A D 29.0 ±2.0mm Max recommended energy rating (Joules) 300.00 J T 7.8 ±0.5mm Actual failure point of instantaneous energy (Joules) 600.00 J S Straight Leads Coating run down L 17.1 ±2.0mm A (Lead Width) 2.2 ±0.2mm B 4.8 ±0.2mm C (Lead Thickness) 0.9±0.2mm Resistance @ 25°C Max Steady State Current Up to 65°C Resistance @ 100% of Max Current Body Temperature @ 100% Current rating Dissipation Constant Thermal Time Constant Material Type ROHS Compliant MSL (moisture sensitivity level) 0.008 Ω 173º C 78.20 mW/ºC 55 seconds B YES #1 Revision Date: 11/1/21 Ametherm, Inc. 961 Fairview Drive Carson City, NV 89701 Telephone: (800) 808-2434 (775) 884-2434 Fax: (775) 884-0670 www.ametherm.com 5.0 ±2.0mm 22.0 ±2.0mm
AS320R530 价格&库存
很抱歉,暂时无法提供与“AS320R530”相匹配的价格&库存,您可以联系我们找货
