SL225R012-BT
SL225R012-BT
    MATRIXORBITAL
    ICL5OHM20%12A22MM
SL225R012-BT 数据手册
Data Sheet SL22 5R012 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 22.0 ± max 6.0 ± max 1.0 ± nom S: 7.8 ± nom L: 38.0 ± nom Coating Lead Run Down (straight Leads) 5.0 ± max B: 9.22 ± nom C: 3.92 ± nom Electrical Specifications Resistance: Max Steady State Current upto 65°c: 5.0 Ω ± 20 % 12.00 A Max Rec. Energy Rating: 100 J Actual Failure Instantaneous Energy: 210 J Maximum Capacitance @ 120 VAC: 6,400 µf Maximum Capacitance @ 240 VAC: 1,500 µf Resistance @ 100% Max Current: 0.05 Ω Resistance @ 50% Max Current: 0.12 Ω 214.00 °c 32.4 mw/°c 94 Sec. Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): G SL22 5R012 Date: 10/31/2008 Ametherm, Inc. 3111 N. Deer Run Road Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: a
SL225R012-BT 价格&库存
很抱歉,暂时无法提供与“SL225R012-BT”相匹配的价格&库存,您可以联系我们找货
