SL222R515-BT
SL222R515-BT
    MATRIXORBITAL
    ICL2.5OHM20%15A22MM
SL222R515-BT 数据手册
Data Sheet SL22 2R515 File: E209153 ISO9001:2008 Certified Mechanical Specifications (mm) D: T: Lead Diameter 22.0 ± max 6.0 ± max 1.0 ± nom S: 7.8 ± nom L: 38.0 ± nom Coating Lead Run Down (straight Leads) 5.0 ± max B: 11.50 ± nom C: ± nom 3.65 Electrical Specifications Resistance: Max Steady State Current upto 65°c: 2.5 Ω ± 20 % 15.00 A 90 J 200 J Maximum Capacitance @ 120 VAC: 6,000 µf Maximum Capacitance @ 240 VAC: 1,400 µf Resistance @ 100% Max Current: 0.03 Ω Resistance @ 50% Max Current: 0.07 Ω 172.00 °c 32.4 mw/°c 94 Sec. Max Rec. Energy Rating: Actual Failure Instantaneous Energy: Body Temperature at 100% Max Current: Dissipation Constant: Thermal Time Constant: Material Type (for Beta and Curve): H SL22 2R515 Date: 11/11/2008 Ametherm, Inc. 3111 N. Deer Run Road Carson City, Nevada USA 89701 www.ametherm.com Drawn by: Erin Landis Approved By: Mehdi Samii Revison: a
SL222R515-BT 价格&库存
很抱歉,暂时无法提供与“SL222R515-BT”相匹配的价格&库存,您可以联系我们找货
