Technical Data 10121
Effective September 2017
Supersedes July 2017
BUSSMANN
SERIES
10x38mm photovoltaic fuses — 1000 Vdc, 1-20 A
Operating class
gPV and UL PV fuse links
PV fuse coordination
With thin film cells and 4”, 5” and 6” crystalline
silicon cells
Agency information
Catalog symbols:
UL® Listed to 248-19*, Guide JFGA,
File E335324
IEC® 60269-6 (gPV)
CSA® File 53787, Class 1422-30 (1-15 A),
20 A pending
PV-(amp)A10F (cylindrical)
PV-(amp)A10-T (bolt mounting)
CCC®
PV-(amp)A10-1P (single PCB tab)
RoHS compliant
PV-(amp)A10-2P (dual PCB tab)
PV-(amp)10F-CT (in-line with crimp terminals)
Description:
Eaton’s Bussmann™ series of 10x38mm,
1000Vdc PV fuses are for protecting and isolating
photovoltaic strings. The fuses are specifically
designed for use in PV systems with extreme
ambient temperature, high cycling and low fault
current conditions (reverse current, multi-array
fault) string arrays.
Four styles available for application flexibility.
Basic fuse size
10x38 mm
Ratings
* Except crimp terminal version that is UL Recognized to
UL 248-19, Guide JFGA2, File E335324.
Packaging (carton quantity)
PV-(amp)A10F, PV-(amp)A10T and
PV-(amp)A10-_P: 10
PV-(amp)10F-CT in-line: 210
Features:
Meets UL and IEC photovoltaic standards for
global acceptance
Low watts loss performance for energy
efficiency
Low temperature rise performance for more
precise sizing
In-line crimp terminal version is easy to apply in
wire harness construction
Volts 1000 Vdc
Amps 1-20 A
Interrupting rating 50 kA
Typical applications:
Time constant: - 1-3ms
Combiner boxes
Inverters
PV wire harnesses
Specifications:
Catalog numbers / configurations
PCB fixing
Cylindrical
ferrule
Voltage
rating
(Vdc)
Energy integrals I2t (A2s)
Watts loss (W)
Pre-arcing
Total @
1000 V
0.8In
In
PV-1A10F
PV-1A10-T
PV-1A10-1P
PV-1A10-2P
PV-1A10F-CT
1
1000
0.15
0.4
0.8
1.5
PV-2A10F
PV-2A10-T
PV-2A10-1P
PV-2A10-2P
PV-2A10F-CT
2
1000
1.2
3.4
0.6
1.0
PV-3A10F
PV-3A10-T
PV-3A10-1P
PV-3A10-2P
PV-3A10F-CT
3
1000
4
11
0.8
1.3
PV-3-5A10F
PV-3-5A10-T
PV-3-5A10-1P
PV-3-5A10-2P
PV-3-5A10F-CT
3.5
1000
6.6
18
0.9
1.4
PV-4A10F
PV-4A10-T
PV-4A10-1P
PV-4A10-2P
PV-4A10F-CT
4
1000
9.5
26
1.0
1.5
PV-5A10F
PV-5A10-T
PV-5A10-1P
PV-5A10-2P
PV-5A10F-CT
5
1000
19
50
1.0
1.6
PV-6A10F
PV-6A10-T
PV-6A10-1P
PV-6A10-2P
PV-6A10F-CT
6
1000
30
90
1.1
1.8
PV-8A10F
PV-8A10-T
PV-8A10-1P
PV-8A10-2P
PV-8A10F-CT
8
1000
3
32
1.2
2.1
PV-10A10F
PV-10A10-T
PV-10A10-1P
PV-10A10-2P
PV-10A10F-CT
10
1000
7
70
1.2
2.3
PV-12A10F
PV-12A10-T
PV-12A10-1P
PV-12A10-2P
PV-12A10F-CT
12
1000
12
120
1.5
2.7
PV-15A10F
PV-15A10-T
PV-15A10-1P
PV-15A10-2P
PV-15A10F-CT
15
1000
22
220
1.7
2.9
PV-20A10F
PV-20A10-T
PV-20A10-1P
PV-20A10-2P
PV-20A10F-CT
34
350
2.1
3.6
Bolt fixing
Single pin
Double pin
In-line with
crimp terminal
Current
rating
(amps)
Dimensions/configurations - mm:
Cylindrical PV-(amp)A10F
Cylindrical with bolt fixings PV-(amp)A10-T
58.9±0.9
10.3±0.1
38.0±0.6
6
6.6
4.1
6
9.5
51.1±1.4
Cylindrical with PCB tabs PV-(amp)A10-1P (single pin),
PV-(amp)A10-2P (double pin)
39.2±0.9 Type 2P
76.00
3
38.0 Type 1P
1.2
3
5.1
2P
1P
The in-line crimp terminal version can be electrically insulated with
customer supplied overmolding or approved heat-shrink.
Operating temperature range
Recommended fuse blocks, holders and fuseclips:
-40°C to 90°C
Wire range and type
Cat. no.
Description and date sheet/publication no.
BPVM-_
Modular PV fuse block with optional covers 10265
Overmolding temperature parameters
CHPV1IU
1-Pole modular fuse holder with indication 10430
CHPV1U
1-Pole modular fuse holder without indication 10430
Terminals
CHPV2IU
2-Pole modular fuse holder with indication 10430
CHPV2U
2-Pole modular fuse holder without indication 10430
1A3400-_
PCB Fuseclips 2131
HPV-DV-_A
In-line fuse holder assembly 2157
2
Ø11.35
12.7
16.38
0.4
Type 1P
4.4
0.8
Type 2P
In-line with crimp terminals PV-(amp)A10F-CT
7
8
11
Eaton.com/bussmannseries
Single conductor, 12-10AWG 75°C/90°C Cu stranded PV
233°C for 180 sec Max
Crimp terminal for 12-10AWG PV copper conductors
Recommended tools
Sta-Kon® terminal crimping tool, catalog number ERG4002
Time-current characteristics
3.5 5
2 3 4 6
1
10,000
10 15
8
12
4
2
1000
6
4
Time in Seconds
2
100
6
4
2
10
6
4
2
1
6
4
2
0.1
1
2
4
6
8
10
2
4
6
8
100
2
4
6
8
1000
Available Current, DC - Time Constant < 1ms (Amps)
3
Temperature derating curves
No additional derating is required for PV fuse links installed in ganged modular fuse holders without spacing between units, provided that the
rating used is >1.56 x Isc.
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 10121 — BU-SB14107
September 2017
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Eaton trademarks without prior written
consent of Eaton.
The CCC mark is administered by
the Certification and Accreditation
Administration of the People’s Republic of
China.
CSA is a registered trademark of the
Canadian Standards Group.
IEC is a registered trademark of the
International Electrotechnical Commission.
Sta-Kon is a registered trademark of
Thomas & Betts.
UL is a registered trademark of the
Underwriters Laboratories, Inc
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“PV-15A10F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+847.867381+110.03771
- 国内价格
- 1+61.99813
- 3+59.62648
- 9+51.30177
- 20+46.07937
- 50+43.22860
- 100+40.61740
- 国内价格
- 1+649.44854
- 100+614.51011
- 500+585.78875
