PV-15A10-T
PV-15A10-T
    EATON(伊顿)
PV-15A10-T 数据手册
Technical Data 10121 Effective September 2017 Supersedes July 2017 BUSSMANN SERIES 10x38mm photovoltaic fuses — 1000 Vdc, 1-20 A Operating class • gPV and UL PV fuse links PV fuse coordination • With thin film cells and 4”, 5” and 6” crystalline silicon cells Agency information Catalog symbols: • UL® Listed to 248-19*, Guide JFGA, File E335324 • IEC® 60269-6 (gPV) • CSA® File 53787, Class 1422-30 (1-15 A), 20 A pending • PV-(amp)A10F (cylindrical) • PV-(amp)A10-T (bolt mounting) • CCC® • PV-(amp)A10-1P (single PCB tab) • RoHS compliant • PV-(amp)A10-2P (dual PCB tab) • PV-(amp)10F-CT (in-line with crimp terminals) Description: Eaton’s Bussmann™ series of 10x38mm, 1000Vdc PV fuses are for protecting and isolating photovoltaic strings. The fuses are specifically designed for use in PV systems with extreme ambient temperature, high cycling and low fault current conditions (reverse current, multi-array fault) string arrays. Four styles available for application flexibility. Basic fuse size • 10x38 mm Ratings * Except crimp terminal version that is UL Recognized to UL 248-19, Guide JFGA2, File E335324. Packaging (carton quantity) • PV-(amp)A10F, PV-(amp)A10T and PV-(amp)A10-_P: 10 • PV-(amp)10F-CT in-line: 210 Features: • Meets UL and IEC photovoltaic standards for global acceptance • Low watts loss performance for energy efficiency • Low temperature rise performance for more precise sizing • In-line crimp terminal version is easy to apply in wire harness construction • Volts 1000 Vdc • Amps 1-20 A • Interrupting rating 50 kA Typical applications: • Time constant: - 1-3ms • Combiner boxes • Inverters • PV wire harnesses Technical Data 10121 10x38mm photovoltaic fuses — 1000 Vdc, 1-20 A Effective September 2017 Specifications: Catalog numbers / configurations PCB fixing Cylindrical ferrule Voltage rating (Vdc) Energy integrals I2t (A2s) Watts loss (W) Pre-arcing Total @ 1000 V 0.8In In PV-1A10F PV-1A10-T PV-1A10-1P PV-1A10-2P PV-1A10F-CT 1 1000 0.15 0.4 0.8 1.5 PV-2A10F PV-2A10-T PV-2A10-1P PV-2A10-2P PV-2A10F-CT 2 1000 1.2 3.4 0.6 1.0 PV-3A10F PV-3A10-T PV-3A10-1P PV-3A10-2P PV-3A10F-CT 3 1000 4 11 0.8 1.3 PV-3-5A10F PV-3-5A10-T PV-3-5A10-1P PV-3-5A10-2P PV-3-5A10F-CT 3.5 1000 6.6 18 0.9 1.4 PV-4A10F PV-4A10-T PV-4A10-1P PV-4A10-2P PV-4A10F-CT 4 1000 9.5 26 1.0 1.5 PV-5A10F PV-5A10-T PV-5A10-1P PV-5A10-2P PV-5A10F-CT 5 1000 19 50 1.0 1.6 PV-6A10F PV-6A10-T PV-6A10-1P PV-6A10-2P PV-6A10F-CT 6 1000 30 90 1.1 1.8 PV-8A10F PV-8A10-T PV-8A10-1P PV-8A10-2P PV-8A10F-CT 8 1000 3 32 1.2 2.1 PV-10A10F PV-10A10-T PV-10A10-1P PV-10A10-2P PV-10A10F-CT 10 1000 7 70 1.2 2.3 PV-12A10F PV-12A10-T PV-12A10-1P PV-12A10-2P PV-12A10F-CT 12 1000 12 120 1.5 2.7 PV-15A10F PV-15A10-T PV-15A10-1P PV-15A10-2P PV-15A10F-CT 15 1000 22 220 1.7 2.9 PV-20A10F PV-20A10-T PV-20A10-1P PV-20A10-2P PV-20A10F-CT 20 1000 34 350 2.1 3.6 Bolt fixing Single pin Double pin In-line with crimp terminal Current rating (amps) Dimensions/configurations - mm: Cylindrical PV-(amp)A10F Cylindrical with bolt fixings PV-(amp)A10-T 58.9±0.9 10.3±0.1 38.0±0.6 6 6.6 4.1 6 9.5 51.1±1.4 Cylindrical with PCB tabs PV-(amp)A10-1P (single pin), PV-(amp)A10-2P (double pin) 39.2±0.9 Type 2P 76.00 3 38.0 Type 1P 1.2 3 5.1 2P 1P The in-line crimp terminal version can be electrically insulated with customer supplied overmolding or approved heat-shrink. Operating temperature range • Recommended fuse blocks, holders and fuseclips: -40°C to 90°C Wire range and type Cat. no. Description and date sheet/publication no. • BPVM-_ Modular PV fuse block with optional covers 10265 Overmolding temperature parameters CHPV1IU 1-Pole modular fuse holder with indication 10430 • CHPV1U 1-Pole modular fuse holder without indication 10430 Terminals CHPV2IU 2-Pole modular fuse holder with indication 10430 • CHPV2U 2-Pole modular fuse holder without indication 10430 1A3400-_ PCB Fuseclips 2131 HPV-DV-_A In-line fuse holder assembly 2157 2 Ø11.35 12.7 16.38 0.4 Type 1P 4.4 0.8 Type 2P In-line with crimp terminals PV-(amp)A10F-CT 7 8 11 Eaton.com/bussmannseries Single conductor, 12-10AWG 75°C/90°C Cu stranded PV 233°C for 180 sec Max Crimp terminal for 12-10AWG PV copper conductors Recommended tools • Sta-Kon® terminal crimping tool, catalog number ERG4002 Technical Data 10121 10x38mm photovoltaic fuses — 1000 Vdc, 1-20 A Effective September 2017 Time-current characteristics 3.5 5 2 3 4 6 1 10,000 10 15 8 12 20 6 4 2 1000 6 4 Time in Seconds 2 100 6 4 2 10 6 4 2 1 6 4 2 0.1 1 2 4 6 8 10 2 4 6 8 100 2 4 6 8 1000 Available Current, DC - Time Constant < 1ms (Amps) Eaton.com/bussmannseries 3 Technical Data 10121 10x38mm photovoltaic fuses — 1000 Vdc, 1-20 A Effective September 2017 Temperature derating curves No additional derating is required for PV fuse links installed in ganged modular fuse holders without spacing between units, provided that the rating used is >1.56 x Isc. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 10121 — BU-SB14107 September 2017 Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. The CCC mark is administered by the Certification and Accreditation Administration of the People’s Republic of China. CSA is a registered trademark of the Canadian Standards Group. IEC is a registered trademark of the International Electrotechnical Commission. Sta-Kon is a registered trademark of Thomas & Betts. UL is a registered trademark of the Underwriters Laboratories, Inc Follow us on social media to get the latest product and support information.
PV-15A10-T 价格&库存
很抱歉,暂时无法提供与“PV-15A10-T”相匹配的价格&库存,您可以联系我们找货
PV-15A10-T
  • 10+112.0654710+14.37360
PV-15A10-T
  • 10+114.15890
