170M1569
170M1569
    EATON(伊顿)
    FUSE SQ 160A 690VAC RECTANGULAR
170M1569 数据手册
Bussmann ® Square Body – DIN 43 620 690V (IEC/U.L.) 10-315A ® Electrical Characteristics Size 000 Rated Current RMS-Amps 10 16 20 25 32 40 50 63 80 100 125 160 200 250 315 Ordering Information Pre-arc Clearing at 660V Watts Loss DIN 000 Type T Indicator for Micro 3.8 7.2 11.5 19 40 69 115 215 380 695 1200 2300 4200 7750 12000 25.5 48 78 130 270 460 770 1450 2550 4650 8500 16000 28000 51500 80500 3.0 5.5 7 9 10 12 15 16 19 24 28 32 37 42 52 170M1558 170M1559 170M1560 170M1561 170M1562 170M1563 170M1564 170M1565 170M1566 170M1567 170M1568 170M1569 170M1570 170M1571 170M1572 I2t (A2S) n Interrupting rating 200kA (Estimated 300kA) RMS Symmetrical. n Watts loss provided at rated current. n Microswitch indicator ordered separately. Curves Carton Qty. Carton Weight (kg) 10 1.30 BIF # 17056310 1 kg = 2.2 lbs. 1 lb = 0.45 kg Rated Current The rated current of this fuse range has been given with copper conductors that have a current density of 1.3 A/mm2 (IEC 60269-4). For conductor cross section according to IEC 60269-1, the fuses with a rated current higher than 125A must be derated. Please contact Bussmann for application assistance. 7-11-01 SB01191 Form No. Page 1 of 2 BIF Doc #720016 Bussmann ® Square Body – DIN 43 620 10-315A 690V (IEC/U.L.) ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K , given as a function of applied working voltage, E g , (RMS). 1.5 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.4 1.2 103 9 8 7 6 K 1.0 0.5 0.4 1.0 Kp 0.8 UL 0.6 0.5 0.4 0.3 5 0.3 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 4 0.2 Eg Eg 3 200 100 200 300 400 500 600 690 300 400 500 600 690 Ib 0.1 30 40 50 60 70 80 90 100% Dimensions DIN 43 620: Type DIN 000 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 54 Max Indicator 15 48 79 21 6 35 The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 7-11-01 SB01191 Form No. Page 2 of 2 BIF Doc #720016
170M1569 价格&库存
很抱歉,暂时无法提供与“170M1569”相匹配的价格&库存,您可以联系我们找货
