C08G25
C08G25
    EATON(伊顿)
    轴向
    FUSE CRTRDGE 25A 400VAC NON STD
C08G25 数据手册
Cylindrical Fuse Links for Industrial Applications Class gG/gL and aM, 0.16 to 125A, 400 to 690Vac Class of Operation: gG-gL For general purpose applications aM For motor protection applications Catalogue Symbol: Class gG/gL Size (mm) Without Indicator (Example) With Indicator (Example) With Striker* (Example) 8 x 31 C08G(amps) (C08G4) C08G(amps)I (C08G4I) N/A 10 x 38 C10G(amps) (C10G4) C10G(amps)I (C10G4I) N/A 14 x 51 C14G(amps) (C14G4) C14G(amps)I (C14G4I) C14G(amps)S* (C14G4S) 22 x 58 C22G(amps) (C22G4) C22G(amps)I (C22G4I) C22G(amps)S* (C22G4S) C08M(amps) (C08M4) C10M(amps) (C10M4) C14M(amps) (C14M4) C22M(amps) (C22M12) N/A N/A C10M(amps)I (C10M4I) C14M(amps)I (C14M4I) C22M(amps)I (C22M12I) C14M(amps)S* (C14M4S) C22M(amps)S* (C22M12S) Class aM 8 x 31 10 x 38 14 x 51 22 x 58 Fuse Holders: Refer to data sheet 2143 Standards/Approvals: IEC 60269 Description: Cylindrical class gG-gL and aM fuse links are intended for industrial applications. Some industrial fuse links are available with an operated visible fuse indicator. Sizes 14 x 51, 22 x 58 in both class gG-gL and aM are also available with a built-in striker for micro-switch operation and remote indication. Packaging: MOQ: please contact our customer service department 00 44 (0) 1509 882 600 or bulesales@cooperindustries.com Technical Data: Rated voltage: from 400 to 690Vac Amps: 0.16 to 125A Rated breaking capacity: 20 to 120kA N/A * Striker fuse links can operate a micro-switch for remote fuse link operated indication Dimensions - mm Fuse Links - with or without indicator Fuse Links with striker Size (mm) A B C D E 14 x 51 14 51 13 8 4 22 x 58 22 58 16 8 4 For striker fuse link applications use CH141DMS or CH221DMS fuse holders with micro-switch auxiliary contacts. 04-06-09 SB-SB09488 Form No Cylindrical Fuse Links Page 1 of 9 Data Sheet 720115 Cylindrical Fuse Links for Industrial Applications Class gG/gL, 0.5 to 125A, 400 to 690Vac Class gG/gL - Catalogue Numbers Size (mm) 8x31 10x38 14x51 22x58 04-06-09 Current (A) Catalogue Numbers Without Indicator Catalogue Numbers With Indicator Catalogue Numbers With Striker 0.5 1 2 4 6 8 10 12 16 20 25 0.5 1 2 4 6 8 10 12 16 20 25 32 1 2 4 6 8 10 12 16 20 25 32 40 50 2 4 6 8 10 12 16 20 25 32 40 50 63 80 100 125 C08G0.5 C08G1 C08G2 C08G4 C08G6 C08G8 C08G10 C08G12 C08G16 C08G20 C08G25 C10G0.5 C10G1 C10G2 C10G4 C10G6 C10G8 C10G10 C10G12 C10G16 C10G20 C10G25 C10G32 C14G1 C14G2 C14G4 C14G6 C14G8 C14G10 C14G12 C14G16 C14G20 C14G25 C14G32 C14G40 C14G50 C22G2 C22G4 C22G6 C22G8 C22G10 C22G12 C22G16 C22G20 C22G25 C22G32 C22G40 C22G50 C22G63 C22G80 C22G100 C22G125 C08G2I C08G4I C08G6I C08G8I C08G10I C08G12I C08G16I C08G20I C08G25I C10G1I C10G2I C10G4I C10G6I C10G8I C10G10I C10G12I C10G16I C10G20I C10G25I C10G32I C14G1I C14G2I C14G4I C14G6I C14G8I C14G10I C14G12I C14G16I C14G20I C14G25I C14G32I C14G40I C14G50I C22G2I C22G4I C22G6I C22G8I C22G10I C22G12I C22G16I C22G20I C22G25I C22G32I C22G40I C22G50I C22G63I C22G80I C22G100I C22G125I C14G2S C14G4S C14G6S C14G8S C14G10S C14G12S C14G16S C14G20S C14G25S C14G32S C14G40S C14G50S C22G4S C22G6S C22G8S C22G10S C22G12S C22G16S C22G20S C22G25S C22G32S C22G40S C22G50S C22G63S C22G80S C22G100S C22G125S SB-SB09488 Form No Cylindrical Fuse Links Page 2 of 9 Voltage (V) Breaking Capacity (kA) 400V 20kA 500V 120kA 400V 690V 500V 80kA 120kA 400V 690V 500V 400V Data Sheet 720115 80kA 120kA Cylindrical Fuse Links for Industrial Applications Class gG/gL, 0.5 to 125A, 400 to 690Vac Pre-Arcing Time (s) Class gG/gL - Time-Current Characteristics Prospective Current (RMS A) 04-06-09 SB-SB09488 Form No Cylindrical Fuse Links Page 3 of 9 Data Sheet 720115 Cylindrical Fuse Links for Industrial Applications Class gG/gL, 0.5 to 125A, 400 to 690Vac Maximum Value of Current (kA Peak) Class gG/gL - Cut-off Characteristics Prospective Current (RMS kA) 04-06-09 SB-SB09488 Form No Cylindrical Fuse Links Page 4 of 9 Data Sheet 720115 Cylindrical Fuse Links for Industrial Applications Class gG/gL, 0.5 to 125A, 400 to 690Vac Class gG/gL - I2t Values Class gG/gL - Watts Loss Values Amp Size mm 10x38 14x51 1.2 1.43 1 2.0 2.77 3.90 2 0.5 0.60 0.90 1.00 4 0.8 0.70 1.00 1.10 6 1.1 0.85 1.15 1.30 8 1.3 0.75 1.00 1.10 10 1.0 1.00 1.30 1.50 12 1.2 1.30 1.70 1.80 16 1.5 1.60 2.00 2.10 20 2.0 2.00 2.50 2.70 25 2.6 2.60 3.30 3.30 2.90 3.50 3.50 40 4.75 4.00 50 4.80 5.50 63 6.90 80 7.80 100 9.00 125 11.40 Rated Current (A) 04-06-09 SB-SB09488 Form No Cylindrical Fuse Links Page 5 of 9 22x58 0.5 32 I2t Value (A2s) 8x31 Data Sheet 720115 Cylindrical Fuse Links for Industrial Applications Class aM, 0.16 to 125A, 400 to 690Vac Class aM - Catalogue Numbers Size (mm) 8x31 10x38 14x51 22x58 04-06-09 Current (A) 1 2 4 6 8 0.16 0.25 0.5 1 2 4 6 8 10 12 16 20 25 0.25 0.5 1 2 4 6 8 10 12 16 20 25 32 40 50 2 4 6 8 10 12 16 20 25 32 40 50 63 80 100 125 SB-SB09488 Catalogue Numbers Catalogue Numbers Catalogue Numbers Without Indicator With Indicator With Striker C08M1 C08M2 C08M4 C08M6 C08M8 C10M0.16 C10M0.25 C10M0.5 C10M1 C10M2 C10M4 C10M6 C10M8 C10M10 C10M12 C10M16 C10M20 C10M25 C14M0.25 C14M0.5 C14M1 C14M2 C14M4 C14M6 C14M8 C14M10 C14M12 C14M16 C14M20 C14M25 C14M32 C14M40 C14M50 C22M2 C22M4 C22M6 C22M8 C22M10 C22M12 C22M16 C22M20 C22M25 C22M32 C22M40 C22M50 C22M63 C22M80 C22M100 C22M125 C10M1I C10M2I C10M4I C10M6I C10M8I C10M10I C10M12I C10M16I C10M20I C10M25I C14M1I C14M2I C14M4I C14M6I C14M8I C14M10I C14M12I C14M16I C14M20I C14M25I C14M32I C14M40I C14M50I C22M2I C22M4I C22M6I C22M8I C22M10I C22M12I C22M16I C22M20I C22M25I C22M32I C22M40I C22M50I C22M63I C22M80I C22M100I C22M125I Form No Cylindrical Fuse Links C14M2S C14M4S C14M6S C14M8S C14M10S C14M12S C14M16S C14M20S C14M25S C14M32S C14M40S C14M50S - C22M12S C22M16S C22M20S C22M25S C22M32S C22M40S C22M50S C22M63S C22M80S C22M100S C22M-125S Page 6 of 9 Voltage (V) Breaking Capacity (kA) 400V 20kA 500V 120kA 400V 500V 120kA 400V 690V 500V 400V Data Sheet 720115 80kA 120kA Cylindrical Fuse Links for Industrial Applications Class aM, 0.16 to 125A, 400 to 690Vac Pre-Arcing Time (s) Class aM - Time-Current Characteristics Prospective Current (RMS A) 04-06-09 SB-SB09488 Form No Cylindrical Fuse Links Page 7 of 9 Data Sheet 720115 Cylindrical Fuse Links for Industrial Applications Class aM, 0.16 to 125A, 400 to 690Vac Maximum Value of Current (kA Peak) Class aM - Cut-Off Characteristics Prospective Current (RMS kA) 04-06-09 SB-SB09488 Form No Cylindrical Fuse Links Page 8 of 9 Data Sheet 720115 Cylindrical Fuse Links for Industrial Applications Class aM, 0.16 to 125A, 400 to 690Vac Class aM - Watts Loss Values Class aM - I2t Values I2t Value (A2s) Amp 8x31 0.16 0.24 0.25 0.36 0.41 0.5 0.49 0.69 SB-SB09488 Form No Cylindrical Fuse Links Page 9 of 9 22x58 1 0.10 0.10 0.14 2 0.16 0.18 0.24 0.29 4 0.25 0.31 0.45 0.48 6 0.35 0.32 0.42 0.47 8 0.40 0.52 0.70 0.73 10 0.65 0.55 0.53 0.74 12 0.63 0.88 0.83 16 0.92 1.16 1.21 20 0.96 1.23 1.29 25 1.40 1.46 1.53 32 2.04 2.13 40 2.60 3.40 45 2.85 50 2.90 3.48 63 4.46 80 5.86 100 6.61 125 8.42 Rated Current (A) 04-06-09 Size mm 10x38 14x51 Data Sheet 720115
C08G25 价格&库存
很抱歉,暂时无法提供与“C08G25”相匹配的价格&库存,您可以联系我们找货
