Technical Data 5009
Effective September 2017
Supersedes July 2017
TPS DC non-indicating power distribution fuses
Features
2011/65/EU
Catalog symbols:
TPS-_ (ferrule)
TPS-_L (horizontal PCB tab)
TPS-_V (vertical PCB tab)
TPS-_LB (bolt tag)
Description:
TPS DC power distribution non-indicating fuses
specifically designed to meet the unique needs
of DC power distribution systems. Available in
ferrule, vertical and horizontal PCB tab and bolt tab
configurations
Specifications:
Ratings
Volts
170 Vac/dc (up to 60 A)
170 Vdc (70 to 80 A)
Amps 1 - 80 A
IR 100 kA
Agency information
UL® Recognized, Guide JFHR2, File E56412
RoHS Compliant
CE
Telpower™ fuse line is the first to be specifically
designed to meet the unique needs of DC
The UL Recognized with a 100kA interrupting
rating and current-limiting capability make the
TPS fuse ideal for overcurrent protection on
existing DC distribution systems
A unique blue label is used on all Telpower
fuses to designate their DC capability
PCB and bolt tag versions available for
application flexibility
Silver-plated brass ferrules
Glass melamine tube
For use with Bussmann series fused disconnect
switch 15800
Spare fuse holder available (cat. no. TPSFH-AS)
Catalog no. (amps)
Ferrule
TPS-1
TPS-6
TPS-2
TPS-10
TPS-3
TPS-15
TPS-5
TPS-20
Horizontal PCB tab
TPS-1L
TPS-6L
TPS-2L
TPS-10L
TPS-3L
TPS-15L
TPS-5L
TPS-20L
Vertical PCB tab
TPS-10V
TPS-30V
TPS-15V
TPS-35V
TPS-25V
TPS-40V
Bolt tab
TPS-1LB
TPS-40LB
TPS-35LB
TPS-50LB
TPS-25
TPS-30
TPS-35
TPS-40
TPS-50
TPS-60
TPS-70
TPS-80
TPS-25L
TPS-30L
TPS-35L
TPS-40L
TPS-50L
TPS-60L
TPS-70L
TPS-50V
TPS-70V
TPS-80V
TPS-60LB
TPS-70LB
Technical Data 5009
Dimensions — in (mm)
TPS-(amp) — ferrule
0.563
0.875
(22)
(14)
TPS-(amp)L — horizontal PCB tab
0.755
(19)
1.76
(45)
TPS-(amp)V — vertical PCB tab
1.261
(32)
0.348
(9)
0.74
(19)
TPS-(amp)LB — bolt tab*
1.59
(40)
1.353
(34)
0.5
(13)
0.19
(5)
*Recommend #8 slotted hex washer head machine screw for mounting.
2
Eaton.com/bussmannseries
0.348
(9)
Technical Data 5009
3
5
6
10
15
30 35
40 50
60
70
80
1,000
1
Time-current curves
AMP
RATING
10
1
10,000
CURRENT IN AMPS
1,000
100
.01
10
.1
1
TIME IN SECONDS
100
3
Technical Data 5009
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 5009 — BU-SB15146
September 2017
Eaton, Bussmann and Telpower are valuable
trademarks of Eaton in the U.S. and other
countries. You are not permitted to use
the Eaton trademarks without prior written
consent of Eaton.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“TPS-30L”相匹配的价格&库存,您可以联系我们找货
