TPS-30V
TPS-30V
    EATON(伊顿)
    径向
    FUSE CRTRDGE 30A 170VDC RAD BEND
TPS-30V 数据手册
Technical Data 5009 Effective September 2017 Supersedes July 2017 TPS DC non-indicating power distribution fuses Features 2011/65/EU Catalog symbols: • TPS-_ (ferrule) • TPS-_L (horizontal PCB tab) • TPS-_V (vertical PCB tab) • TPS-_LB (bolt tag) Description: TPS DC power distribution non-indicating fuses specifically designed to meet the unique needs of DC power distribution systems. Available in ferrule, vertical and horizontal PCB tab and bolt tab configurations Specifications: Ratings • Volts • 170 Vac/dc (up to 60 A) • 170 Vdc (70 to 80 A) • Amps 1 - 80 A • IR 100 kA Agency information • UL® Recognized, Guide JFHR2, File E56412 • RoHS Compliant • CE • Telpower™ fuse line is the first to be specifically designed to meet the unique needs of DC power distribution systems • The UL Recognized with a 100kA interrupting rating and current-limiting capability make the TPS fuse ideal for overcurrent protection on existing DC distribution systems • A unique blue label is used on all Telpower fuses to designate their DC capability • PCB and bolt tag versions available for application flexibility • Silver-plated brass ferrules • Glass melamine tube • For use with Bussmann series fused disconnect switch 15800 • Spare fuse holder available (cat. no. TPSFH-AS) Catalog no. (amps) Ferrule TPS-1 TPS-6 TPS-2 TPS-10 TPS-3 TPS-15 TPS-5 TPS-20 Horizontal PCB tab TPS-1L TPS-6L TPS-2L TPS-10L TPS-3L TPS-15L TPS-5L TPS-20L Vertical PCB tab TPS-10V TPS-30V TPS-15V TPS-35V TPS-25V TPS-40V Bolt tab TPS-1LB TPS-40LB TPS-35LB TPS-50LB TPS-25 TPS-30 TPS-35 TPS-40 TPS-50 TPS-60 TPS-70 TPS-80 TPS-25L TPS-30L TPS-35L TPS-40L TPS-50L TPS-60L TPS-70L TPS-50V TPS-70V TPS-80V TPS-60LB TPS-70LB Technical Data 5009 TPS DC non-indicating power distribution fuses Effective September 2017 Dimensions — in (mm) TPS-(amp) — ferrule 0.563 0.875 (22) (14) TPS-(amp)L — horizontal PCB tab 0.755 (19) 1.76 (45) TPS-(amp)V — vertical PCB tab 1.261 (32) 0.348 (9) 0.74 (19) TPS-(amp)LB — bolt tab* 1.59 (40) 1.353 (34) 0.5 (13) 0.19 (5) *Recommend #8 slotted hex washer head machine screw for mounting. 2 Eaton.com/bussmannseries 0.348 (9) Technical Data 5009 TPS DC non-indicating power distribution fuses Effective September 2017 3 5 6 10 15 20 25 30 35 40 50 60 70 80 1,000 1 Time-current curves AMP RATING 10 1 10,000 CURRENT IN AMPS 1,000 100 .01 10 .1 1 TIME IN SECONDS 100 Eaton.com/bussmannseries 3 Technical Data 5009 TPS DC non-indicating power distribution fuses Effective September 2017 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 5009 — BU-SB15146 September 2017 Eaton.com/bussmannseries Eaton, Bussmann and Telpower are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
TPS-30V 价格&库存
很抱歉,暂时无法提供与“TPS-30V”相匹配的价格&库存,您可以联系我们找货
TPS-30V
  • 10+308.7203010+40.08580
