BK/HTC-140M
BK/HTC-140M
    EATON(伊顿)
    BK/HTC-140M
BK/HTC-140M 数据手册
Technical Data 2110 Effective July 2023 Supersedes February 2021 HTC PCB Fuse accessories for 5 mm fuses PCB Fuse blocks HTC-15M • UL 4248 rating: 250 V, 20 A • IEC 60217-6 rating: 250 V, 6.3 A, 1.6 W • Self-certified voltage rating: 500 V, 20 A • Tin plated brass terminals • cURus: Guide IZLT2 & IZLT8, File # 14853 • Cover available: Dimensions- inches (mm) 1.047" (26.6mm) .354 " (9.0mm) HTC-140M Cover .571 " (14.5mm) .217 " (5.5mm) .531 " Mounting Holes (13.5mm) .890 " .866 " (22.60mm) (22.0mm) _ .002" Dia. (Typ.) .059 " + .177 " HTC-150M (Transparent) Flammability rating: UL94-V2 • _ . 05mm) (1.50 + (4.5mm) HTC-140M (Beige/Natural) Flammability rating: UL94-V0 • • IEC 60127-6 rating: 250 V, 6.3 A, 1.6 W • Self-certified voltage rating: 500 V, 20 A • cURus: Guide IZLT2 & IZLT8, File # 14853 • 90 0.5 mm) (1.5 0.0197 x 0.047 (0.5 x 1.2mm) 0.890 (22.6mm) 0.890 (22.6mm) Mounting holes 0.039 (1.0mm) UL 4248 rating: 250 V, 20 A 0.138 (3.5mm) • 0.453 (11.5mm) HTC-78M 0.413 (10.5mm) 0.370 (9.4mm) 0.961 (24.4mm) Cover available: HTC-100M Flammability rating: UL94-V0 • .886" .354" (22.5mm) .551" • UL 4248 rating: 250 V, 20 A • IEC 60127-6 rating: 250 V, 6.3 A, 1.6 W • Tin plated bronze terminals (15.0mm) .102" Dia. Hole (2.6mm) .051" Dia. Hole (3.5mm) HTC-60M .591" (9.0mm) (1.3mm) .138" (3.5mm) 38.2±0.5 BK4-HTC-518M 27±0.3 Ø2 250 V, 15 A Bakelite, UL 94V-0, black • Clip: copper alloy, nickel plated • Terminals: brass, nickel plated Ø6.56 6.25±0.3 ± 0.0 • 3.8±0.2 5 • 34.4±0.5 8.5±0.5 0.5 15±.5 7±0.3 0.3±0.05 22.2±0.3 Terminals: brass, nickel plated 9±0.2 • 6.5±0.2 Clip: copper alloy, nickel plated 4.3 10±0.3 A 22.2±0.3 27±0.3 8.5±0.5 40° 15.4±0.5 A 5 .0 ±0 0.7 7±0.3 6.25±0.2 5 .0 ±0 Bakelite, UL 94V-0, black • 0.5 250 V, 15 A • 56 • 10±0.3 Ø6. BK4-HTC-528M SECTION A-A : HTC PCB Fuse accessories for 5 mm fuses  Technical Data 2110 Effective July 2023 Dimensions- inches (mm) .319" • Tin plated bronze • Tape and fan fold packed (12.7mm) BUSS HTC-200M .50" (8.1mm) BUSS .177" (4.5mm) BUSS PCB Fuse clips .157" (3.99mm) .929" (23.6mm) .61" (15.5mm) .031" (.79mm) .012" .217" (.3mm) (5.5mm) .50" .50" (12.7mm) (12.7mm) 4.32mm HTC-210M • 2.54mm Tin plated brass 2.29mm 8.73mm 2.54mm 6.26mm 3.91mm 6.22mm 1.46mm 2.85mm 2.54mm PCB Fuse holders HTC-45M 1.303" (33.1mm) max* .512 " • 250 V, 10 A, 2.5 W • Bayonet cap/carrier • Operating temperature range: -30 °C to + 85 °C (13.0mm) FU • cURus: Guide IZLT2 & IZLT8 File # 14853 • VDE: 40004456 Mounting Holes SE .461 " (11.7mm) .394 " Printed Circuit Board (10.0mm) .051 _ _ .05mm ) ( 1.30 + Dia. (Typ.) * Maximum dimension with fuse is installed HTC-50M • 250 V, 10 A, 2.5 W .512 " (13.0mm) • Bayonet cap/carrier • Operating temperature range: -30 °C to + 85 °C • cURus: Guide IZLT2 & IZLT8 File # 14853 • VDE: 40004456 1.303" (33.1mm) max* SE FU Common HTC specifications Mounting Holes _ .002" Dia. (Typ.) .051 " + _ .05mm ) ( 1.30 + .461 " (11.7mm) .394 " Printed Circuit Board (10.0mm) * Maximum dimension with fuse is installed • Solerability: In accordance with IEC 68-2-20 • Molded materials: UL94 V-0 Packaging codes Packaging code prefix Description Blank 10 pieces packed into a carton (HTC-15M and HTC-60M only)) BK- 100 pieces packed into a cardboard shelf package (HTC-15M and HTC-60M only) BK1- 1000 pieces packed into a poly bag BK4 4000 pieces packed into a carton (HTC-518M and HTC-528M only) AP 1000 pieces per box in Ammo pack (HTC-200M only) Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2023 Eaton All Rights Reserved Printed in USA Publication No. 2110 July 2023 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK/HTC-140M 价格&库存
很抱歉,暂时无法提供与“BK/HTC-140M”相匹配的价格&库存,您可以联系我们找货
