1113/71
1113/71
    GEEHY(极海半导体)
    BOOT ROCKER CIRCUIT BREAKER CLR
1113/71 数据手册
Rocker Switch Boots E-SEEL® (Rock-R-Seel™) rocker switch boots are molded from RUBRGLAS™ — APM’s proprietary high tear-strength, transparent silicone rubber. These durable and flexible boots seal out dust, dirt, and moisture … without compromising switch operability, position status viewing or legend visibility. Each is designed to fully enclose the switch bezel, while our unique molded-in “panel sealing rib” forms a watertight and dust-tight seal against the front panel surface. 5 SPECIFICATIONS 6 Material: APM RUBRGLAS™ (transparent silicone rubber), polymer type, ASTM D1418 Temperature Range: –80°F to +400°F Operational Life: 50,000 actuations (minimum) Resistant to: Salt spray, sunlight, ozone, weather, fungus, and most acids and lubricating oils Agency Recognition: Rock-R-Seels™ are UL-listed to UL Std. 50, types 1, 2, 4R, 5, 12, 12K, 13, and meet CSA standards Shelf Life: Excess of 25 years 7 1 2 3 HOW TO ORDER 4 Specify APM boot part number. PHOTOS 1-7 Dimensions Photo # E-SEEL Part # A B C D E in. mm in. mm in. mm in. mm in. mm Compatible with These Rocker Switch Manufacturers (Partial List) 1 C1111/7 .359 9.13 .609 15.48 .937 23.81 1.703 43.26 .900 22.87 Consult Factory 2 C1113/62 .297 7.54 .797 20.24 .687 17.46 1.093 27.78 .968 24.61 Arrow Hart – 2600 Series 3 C1113/63 .297 7.54 .406 10.32 .687 17.46 1.093 27.78 .515 13.10 Arrow Hart – 2600 Series 4 C1113/66 .228 5.79 .348 8.84 .531 13.46 .750 19.05 .531 13.49 Carlingswitch #621 5 C1113/70 .297 7.54 .437 11.11 .875 22.23 1.218 30.96 .640 16.27 Carlingswitch RSC Series 6 C1113/71 .413 10.49 .687 17.46 1.046 26.59 1.327 36.51 .703 17.86 Carlingswitch M Series Airpax R11 Eaton/Heinemann LC-1 Potter W-33 Carling LTI6 C1113/80 .560 14.22 .750 19.05 1.375 34.92 1.750 44.45 .900 22.86 7 C1113/75 .413 10.49 .687 17.46 1.046 26.59 1.437 36.51 1.390 35.32 Carlingswitch M Series Airpax R21 Eaton/Heinemann LC-2 Not Shown C1213/53 C1213/60 .312 .350 9.14 10.16 .700 1.000 19.81 21.08 .700 .820 19.81 21.08 1.120 1.120 29.21 29.21 .800 .800 23.11 23.11 Oslo Oslo DIMENSIONS FOR REFERENCE ONLY. S Series S Series Carlingswitch M Series Rocker Actuator Switch with C1113/71 E-SEEL 12
1113/71
1. 物料型号:文档列出了不同型号的E-SEEL开关靴,例如C1111/7、C1113/62、C1113/63等,每个型号都有其特定的尺寸和兼容的制造商。
2. 器件简介:E-SEEL®开关靴设计用于密封灰尘、污垢和水分,同时不影响开关的操作性、位置状态查看或标识可见性。它们完全覆盖开关边框,并具有独特的模制“面板密封肋”,形成防水和防尘的密封。
3. 引脚分配:文档没有明确提到引脚分配,因为这是关于开关靴的文档,而不是电子元件。
4. 参数特性: - 材料:APM RUBRGLAS™(透明硅橡胶),聚合物类型,符合ASTM D1418标准。 - 温度范围:-80°F至+400°F。 - 操作寿命:至少50,000次操作。 - 抗性:耐盐雾、阳光、臭氧、天气、真菌以及大多数酸和润滑油。 - 认证:UL-listed,符合UL Std. 50的多种类型,满足CSA标准。
5. 功能详解:文档强调了开关靴的密封性能和耐用性,以及它们如何保护开关免受环境因素的影响。
6. 应用信息:文档提供了如何订购E-SEEL开关靴的指南,包括指定APM靴部件编号。
7. 封装信息:文档提供了不同型号的尺寸信息,以及它们兼容的开关制造商列表。
1113/71 价格&库存
很抱歉,暂时无法提供与“1113/71”相匹配的价格&库存,您可以联系我们找货
