Bussmann®
Fuse Accessories, Displays, Kits, Etc.
Fuse Display Racks
Fusetron® View-Pack
Plug Fuse Display
Electronic Fuse Display
Fuse Display Rack
Catalog Symbol: FR-1000
The FR-1000 is a complete assortment
of Fusetron View-Packs with a display
rack. When you order a “FR-1000”,
you receive five each of the View-Packs
listed below, plus a heavy-duty wire
rack. The rack is designed to hang
from a pegboard or stand on a shelf.
The FR-1000 measures 32∑ wide,
18∑ tall and 10∑ deep.
Catalog Symbol: PFD-948
Sturdy plastic display features complete
assortment of plug fuses.
Each display comes with a set of labels
that permits customizing the product
mix.
Display measures 29∑ wide x 15∑ tall x
5∑ deep.
Catalog Symbol: No.15
A complete assortment of 125 volt and
250 volt fuses for electronic equipment.
The No. 15 display contains fifteen of
the most popular fuses for electronic
equipment, such as microwaves, computers, stereos, CB radios, or office
equipment. The sturdy wire rack holds
twelve cards of each fuse, and can be
hung from a pegboard or stood on a
shelf.
• Header card explains fuse types
and offers safety precautions.
• Sturdy wire rack can be hung from
a pegboard or stood on a shelf.
There is no charge for the rack, when
purchased with the display.
PFD-948 Display
Contents
Boxes*
Fuses
W-15
25
100
Fusetron View-Packs
W-20
25
100
Catalog Number
W-25
12
48
FRN-R-15-VP
W-30
25
100
FRN-R-20-VP
TL-15
25
100
FRN-R-25-VP
TL-20
25
100
FRN-R-30-VP
TL-30
25
100
FRN-R-35-VP
SL-15
25
100
FRN-R-40-VP
SL-20
25
100
FRN-R-45-VP
SL-30
25
100
No. 15 Display and Refills
Contents
Fuses/
Card
Cards/
Display
FRN-R-50-VP
*Each box contains 4 fuses.
BP/AGC-⁄Ω™
5
5
FRN-R-60-VP
Displays without fuses are also available. Order EMPTY-PFD to receive the
display only.
BP/AGC-1
5
10
BP/AGC-1⁄Ω™
5
5
BP/AGC-2
5
5
The PFD-948 is packed one per carton.
Carton size is 18⁄Ω™∑ ≈ 13⁄Ω™∑ ≈ 31⁄Ω¢∑,
weight is 75 lbs. The EMPTY-PFD is
also packed one per carton. Carton
size is 16∑ ≈ 6∑ ≈ 31⁄Ω¢∑, weight is 6 lbs.
BP/AGC-3
5
10
BP/AGC-4
5
5
BP/AGC-5
5
10
FRS-R-15-VP
FRS-R-20-VP
FRS-R-25-VP
FRS-R-30-VP
FRS-R-35-VP
FRS-R-40-VP
FRS-R-45-VP
FRS-R-50-VP
FRS-R-60-VP
BP/MDL-⁄Ω™
2
5
BP/MDL-1
2
5
BP/MDL-1⁄Ω™
2
5
BP/MDL-2
2
5
BP/MDL-3
2
5
BP/MDL-5
2
5
BP/ABC-10
2
5
BP/ABC-15
2
5
No. 15 (Display)
90
Display rack measures: 18⁄Ω¢∑ ≈ 10⁄Ω™∑ ≈ 24∑
186
For complete specification data, call Bussmann Information Fax ~ 636.527.1450
Bussmann®
Fuse Display Racks
No. 2880
Empty Counter or Wall Stock
Display Rack
• Holds 2880 fuses (574 boxes of
5 each).
• Six removable sections with four
channels. Units may be interlocked
without screws.
No. 200 & No. 201
Catalog Symbol: No. 205
Compact display of 125 Volt and
250 Volt fuses.
Size: 6‹Ω¢∑ W ≈ 16∑ H x 4∑ D
Glass Tube and Blade-Type
Automotive Fuses
The “200”—40 boxes (172 fuses).
Size: 4∑ ≈ 6‹Ω¢∑ x 10∑ (270 cu. in.)
Fuse
Quantity
Fuse
Quantity
Fuse
Quantity
Fuse
Quantity
AGC-⁄Ω™
AGC-1
AGC-1⁄Ω™
AGC-2
AGC-3
AGC-4
AGC-5
AGC-6
AGC-7
AGC-8
AGC-10
ABC-10
ABC-15
ABC-20
MDL⁄Ω™
5
10
5
10
10
5
10
5
5
5
5
5
15
5
5
MDL-1
MDL-1⁄Ω™
MDL-2
MDL-3
MDL-4
MDL-5
MDL-6
MDL-7
MDL-8
GLH-7
GMA-500mA
GMA-1A
GMA-2A
GMA-3A
GMA-5A
10
5
10
10
5
5
5
5
5
15
5
5
5
5
5
AGC-1
AGC-2
AGC-3
AGC-5
AGC-7⁄Ω™
AGC-10
AGC-15
AGC-20
AGC-25
AGC-30
ATC-3
ATC-4
ATC-5
ATC-7⁄Ω™
ATC-10
ATC-15
ATC-20
ATC-25
ATC-30
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
10
5
5
ATM-2
ATM-3
ATM-4
ATM-5
ATM-7⁄Ω™
ATM-10
ATM-15
ATM-20
ATM-25
ATM-30
GBC-8
MAX-20
MAX-30
MAX-40
MAX-50
MAX-60
SFE-14
SFE-20
5
5
5
5
5
5
5
5
5
5
5
5
5
2
1
2
5
5
The “201”—40 boxes (172 fuses).
Comes in handy, clear plastic service kit.
Fuse assortment same as the “200”.
3∑ ≈ 4∑ x 10∑ (142.5 cu. in.)
Christmas Light Fuses
and Displays
Bussmann offers a comprehensive line
of replacement fuses for all Christmas
tree lights and decorative light
products.
Display Cartons
Part No.
BP/AGX-7X5
BP/GLH-7X5
BP/MAS-3X5
BP/XMAS-6F
Carton
Quantity
Description
5 AGX-7 Amp, 125V Fuses
⁄Ω¢∑ ≈ 1∑ Glass Tube
5 GLH-7 Amp, 125V Fuses
⁄Ω¢∑ ≈ 1⁄Ω¢∑ Glass Tube
5 MAS-3 Amp, 125V Fuses
3.6mm x 10mm Glass Tube
Assortment: 6 Fuses
(2 ea. AGX-7, GLH-7, MAS-3)
20 Cards
20 Cards
20 Cards
20 Cards
Clip Strip
CS/XMAS-6F
Assortment: 6 Fuses
20 Cards
Note: Order by the card (each in multiples of 20).
Package Specifications
Card Size
Display Carton
Part No.
H
W
D
H
W
Weight
BP/AGX-7X5
BP/GLH-7X5
BP/MAS-3X5
BP/XMAS-6F
CS/XMAS-6F
4‹Ω¢∑
4‹Ω¢∑
4‹Ω¢∑
4‹Ω¢∑
4‹Ω¢∑
2‹Ω¢∑
2‹Ω¢∑
2‹Ω¢∑
2‹Ω¢∑
2‹Ω¢∑
7⁄Ω¢∑
7⁄Ω¢∑
7⁄Ω¢∑
7⁄Ω¢∑
6⁄Ω™∑
6⁄Ω¢∑
6⁄Ω¢∑
6⁄Ω¢∑
6⁄Ω¢∑
2‡Ω•∑
5‹Ω¢∑
5‹Ω¢∑
5‹Ω¢∑
5‹Ω¢∑
6⁄Ω¢∑
1 lb. 10 oz.
1 lb. 10 oz.
1 lb. 10 oz.
1 lb. 10 oz.
1 lb. 4 oz.
189
Bussmann®
Fuse Display Racks
FDM-1
Fuse Display Merchandiser
• Bussmann tilt-bin display maximizes your space and stimulates impulse purchases.
• Interlocking bins can be stacked or mounted on peg board.
• Header card easily attaches with plastic push pegs.
• Provides a flexible system to best fit your needs and space
requirements.
• The tilt bins are available in five and six bin models.
Fuse Display Merchandiser will consist of any number of either
size bins; header card push pegs to attach and part number
labels.
Part Number
Description
1A9721
5 Bin Display
23fiΩ• long x 6⁄Ω™ tall x 5⁄Ω™ deep
1A9722
6 Bin Display
23fiΩ• long x 4⁄Ω™ tall x 3fiΩ• deep
1A9716-01
9 Bin Display
23fiΩ• long x 3⁄Ω™ tall x 3fiΩ• deep
190
很抱歉,暂时无法提供与“1A9721”相匹配的价格&库存,您可以联系我们找货
