270303
270303
    EATON(伊顿)
    STIRUPASSYNIPL7.5MIC
270303 数据手册
Fuse Clips VT Fuse Clips for 25.4mm diameter. DIN Standard Clips for ‘F’ and‚ ‘S’ range fuse links. BS Mounting Clips suitable for 50.8mm and 76.2mm Oil, Air and Motor Fuse Links up to 200A. Bussmann Fuse Clips To complement the range of tag fixings offered by Bussmann, a range of fuse clips. These are suitable for use with British Standard, DIN dimensioned and VT ferrule style fuse links. The BS and DIN clips are rated up to 200 Amps. They are designed to be fitted onto insulated studs or directly onto a busbar. Selection Table Fuse Type 59 Clip Reference DIN fuse links to 43 625 270303 or A3354745 Voltage transformer and auxiliary type fuse links A3354705 British standard fuse links 50.8mm (2”) dia 63.5mm (2.5”) dia 76.2mm (3”) dia A3354710 A3354720 A3354730 For more information visit our website www.bussmann.com Fuse Clips Dimensions (mm) Clips for 25.4mm VT fuse links Material: Nickel silver alloy Order as part number: A3354705 Dimensions (mm) Clips for DIN fuse links Material: Nickel plated copper Order as part number: 270303 Dimensions (mm) Suitable for use with all Bussmann DIN fuse links. Also suitable for use with other Bussmann fuse links having type‚ ‘J’ end tags, to DIN 43 625, with maximum current rating of 200 amps. Clips for British Standard and DIN style fuse links Material: Nickel plated copper Order as part number: A3354745 A3354710 A3354720 A3354730 for for for for 45mm dia. 50.8mm dia. 63.5 mm dia. 76.2 mm dia. Dimensions (mm) Fuse dia. (D) H W C 45 86 112 48 50.8 86 112 48 63.5 95 124 54 76.2 100 140 58 For more information visit our website www.bussmann.com 60
270303 价格&库存
很抱歉,暂时无法提供与“270303”相匹配的价格&库存,您可以联系我们找货
