Approval Sheet
for
Aluminum Housed
Power Wirewound Resistors
AHP & AHA series
±0.25%、±0.5%、±1%
±5% & ±10%
YAGEO CORPORATION
Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C.
Tel: 886-2-2917-7555 Fax: 886-2-2917-0100
Xindian Plant: 3F, No.5, Lane 560, Chung Cheng Rd., Xindian Taipei, Taiwan, R.O.C
Tel: 886-2-2218-2139 Fax: 886-2-6629-8898
URL: www.yageo.com
Page-1
Rev.
Description
Issue Date
Drawn
Approved
00
issue new spec.
Feb 05, 2008
Lynn Chen
Joyce Chung
Description
Aluminum Housed Power Wirewound Resistors
Series
AHA & AHP
Rev.
Page-2
00
1.
PRODUCT:
High power rating, with small size and ultra precision.
(AHA & AHP SERIES)
2.
PART NUMBER:
Part number of the cement resistor is identified by the name, power, tolerance, packing,
temperature coefficient, special type and resistance value.
Example:
AHP
500
J
B
100R
(1)
(2)
(3)
(4)
(5)
(6)
Series Power Resistance Packing Temperature Resistance
Name Rating Tolerance
Style
Coefficient
Value
of Resistance
(1) Style:AHA SERIES: Lug/Threaded Terminals
AHP SERIES: Straight Leadwire Terminals
(2) Power Rating: 500=5W、10A=10W、25A=25W、50A=50W、
80A=80W、10B=100W、25B=250W
(3) Tolerance: C = ±0.25%、D = ±0.5% 、F = ±1%、J = ±5% 、K = ±10%
(4) Packaging Type: B = Bulk with wirewound or metal oxide
(5) Temperature Coefficient : 200ppm/℃
(6) Resistance Value:E24 & E96 Series ( for ±1% )
Example:0R1, 1R、10R、100R、10K……
Page-3
3.
ELECTRICAL CHARACTERISTICS
STYLE
Power Rating at 70 ℃
Resistance range
(Wirewound )
Resistance range
( Metal Oxide Film )
Operating Temp. Range
AHA500
AHP500
5W
AHA10A
AHP10A
10W
AHA25A
AHP25A
25W
AHA50A
AHP50A
50W
0R1~100R
110R~50K
110R~100K
- 55 ℃ to + 250 ℃
± 200ppm/ ℃
STYLE
AHA80A
80W
Resistance range
(Tube Ceramic Wirewound )
0R1~3K
AHA10B
100W
- 55 ℃ to + 250 ℃
± 200ppm/ ℃
* Below or over this resistance range on request.
Page-4
AHA25B
250W
4.
DERATING CURVE & TEMPERATURE RISE
Derating Curve
Rated Load (%)
120
100
80
60 A
40 B
C
75
125
175
225
275
325
Ambient Temperature (℃)
Temperature Rise
Temperatuer (℃)
AHA25B
150
AHA10B
AHA50A
AHP50A
100
AHA25A
AHP25A
AHA10A
AHP10A
50
AHA500
AHP500
60
100
80
Rated Load (%)
Short-time Overload Rating
Load Time
(Second)
Power
Incerase
1
2
3
4
5
10
30
60
180
300
600
900
2600
2000
1600
1400
1300
1000
600
450
200
150
120
110
Page-5
5.
DIMENSIONS
Unit:mm
AHA500
AHA10A
AHA25A
AHA50A
AHP500
AHP10A
AHP25A
AHP50A
AHA80A
AHA10B
AHA25B
Type
DIMENSIONS(mm)
L1±2
L2±1
L3±1
A±1
B±1
C±1
E±0.3
S±1
H±0.5
P±2
25
15
10
16.5
12.5
8.5
2
8
4
5
32
19
14
10.5
2
10
5
6
47
27
18
27
19
15
3.2
15.5
7
10
70
50
39
29
21
15
3.2
15.5
7
10
AHA80A
102
66
35
47
37
28
4.5
25
12
5*18
AHA10B
135
89
69
70
58
46
5
44.5
19.5
6*23
AHA25B
155
114
98
77
64
53
5
55.5
25
6*21
AHA500
AHP500
AHA10A
AHP10A
AHA25A
AHP25A
AHA50A
AHP50A
Page-6
6. ENVIRONMENTAL CHARACTERISTICS
Electrical Specification
Characteristics
Limits
Test Methods
Resistance 1Ω ≤R ±5%(J)
Resistance Tolerance
Resistance Tolerance 1Ω ≤R ±10%(K)
±200ppm/ °C max.
JIS-C-5202 5-2b
Δ R/R≤±(1%+0.05Ω )
Power Rating Load
Surface Temp. Rise 350°C max.
Δ R/R≤±(2%+0.05Ω )
Short-Time Overload
100% Rated Power5 Seconds
JIS-C-5202 5-1
JIS-C-5202 5-4
JIS-C-5202 5-5
Insulation Resistance
DC500V 100MΩ min
JIS-C-5202 5-6
Dielectric Withstanding Voltage
AC3000V 60Sec.
JIS-C-5202 5-7
Parameters
Short time OverLoad
Moisture Resistance
Moisture Load Life
Load Life
Vibration
Heat Resistance
Dielectric Strength
Terminal Strength
Performance
Test Conditions
5X wattage rating-5sec
Temp 40℃ moisture 95% DC100V
500HR
Temp 40℃ moisture 95% 1/10X
Wattage rating (1.5Hr ON-0.5Hr OFF)Repeat 1000Hr
Load Rating(chass is mounted)
(1.5Hr ON 0.5Hr OFF) -Repeat 1000Hr
10c/s~50c/s~10c/s(lmin)2Hr each of
paralleled and right angle
275℃ 2Hr
1000V: AHA500, AHA10A, AHA25A
(AHP500, AHP10A, AHP25A)
1500V: AHA50A
(AHP50A)
2500V: AHA10B, AHA25B
Under the same test condition of
Dieletric Strength,Load DC500v and
measure the insulation R.
(1) Pull Test (30 sec Min)
AHA500/AHP500: 1kg.
AHA10A/AHP10A: 2.3kg.
AHA25A/AHP25A,
AHP50A/AHP50A: 4.5kg
(2) Torque Test (5~15sec)
AHA10B: 27kg-cm,
AHA25B: 36Kg-cm
Page-7
Specifications
△R±(0.5%+0.05Ω)MAX
△R±(0.5%+0.05Ω)MAX
△R±(0.5%+0.05Ω)MAX
△R±(1.5%+0.05Ω)MAX
△R±(0.2%+0.05Ω)MAX
△R±(0.5%+0.05Ω)MAX
△R±(0.2%+0.05Ω)MAX
1000M Ω min
△R±(0.2%+0.05Ω)MAX
7. Packing
Packing
Power Rating
BOX(PCS)
CARTON(PCS)
5W
400
2400
10W
300
1800
25W
150
600
50W
100
600
80W
8
48
100W
10
60
250W
6
36
8. Plant Address
A.
Taiwan Xindian Plant
3F, No.5, Lane 560, Chung Cheng Road,
Xindian, Taipei, Taiwan, ROC
(台北縣新店市中正路 560 巷 5 號 3 樓)
Tel. 886-2-2218-2139
Fax. 886-2-6629-8898
B.
China Dongguan Plant
7-1, Gaoli Road, Gaoli Industrial Zone
Tangxia Zhen, Dongguan, Guangdong, China
(廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號)
Tel. 86-769-8772 0275
Fax. 86-769-8772 0275 #4333
C.
China MuDu Plant
No.158, Fengjiang Road, No.1 Building of NanBangIND.Zone,
Mu Du New District, Suzhou, China
(江蘇省蘇州市木瀆新區楓江路 158 號南濱工業區 1 號)
Tel. 86-512-66518889
Fax. 86-512-66519889
Page-8
很抱歉,暂时无法提供与“AHA10AFB-75R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+42.525011+5.45716
- 10+28.8404110+3.70104
- 25+25.1160025+3.22309
- 50+22.7868450+2.92420
- 100+20.80706100+2.67014
- 360+17.89698360+2.29669
- 720+16.65178720+2.13690
- 1080+16.012401080+2.05485
- 5040+14.593285040+1.87273
