Through-hole resistors
Power Wirewound Type
Aluminum Housed
Resistors
Lug / Threaded Style [ AHA Series ]
Straight Leadwire Style [ AHP Series ]
FEATURES
Power Rating
5W, 10W, 25W, 50W
Resistance Tolerance
±1%, ±2%, ±5%, ±10%
T.C.R.
±50ppm/°C, ±100ppm/°C, ±200ppm/°C
DIMENSIONS
Unit: mm
H
S
C
A
øE
P
B
A
ø M1:AHA
ø M2:AHP
øM1
K
AHP Series is
straight leadwire
L3
L2
L11:AHA
L12:AHP
STYLE
DIMENSION
Normal
L1I
L12
L2
L3
A
B
C
ØE
S
H
AHA500/AHP500
28.6±1.5
71.2±1.5
15.2±0.5
11.5±0.5
16.4±0.5
12.5±0.5
8.5±0.5
2.4±0.3
8.1±1.0
3.8±1.0
AHA10A/AHP10A
34.9±1.5
75.0±1.5
19.0±0.5
14.2±0.5
20.3±0.5
15.9±0.5
10.7±0.5
2.4±0.3
9.9±1.0
4.2±1.0
AHA25A/AHP25A
49.2±1.5
83.0±1.5
27.0±0.5
18.2±0.5
27.4±0.5
19.8±0.5
14.0±0.5
3.2±0.3
13.9±1.0
5.9±1.0
AHA50A/AHP50A
70.6±1.5
106±1.5
50.0±0.5
40.0±0.5
29.0±0.5
21.4±0.5
16.0±05
3.2±0.3
15.5±1.0
6.6±1.0
73
DERATING CURVE
275 °C
Rated Load (%)
Temperature (°C)
25
100
80
60
40
250W
300
80W-100W
250
200
5W-50W
150
100
350
50
100 150 200 250 300
Ambient Temperature (°C)
40
60
80
100
Rated Load (%)
ELECTRICAL CHARACTERISTICS
STYLE
Power Rating on std. heatsink at 25°C
Power Rating without heatsink at 25°C
AHA500
AHA10A
AHA25A
AHA50A
AHP500
AHP10A
AHP25A
AHP50A
5W
10W
25W
50W
3W
8W
12.5W
20W
Voltage Proof on Insulation
1,000V
1,000V
Resistance Range
0.1Ω - 1KΩ
Operating Temp. Range
-55°C to +275°C
Temperature Coefficient
0.1Ω - 1.5KΩ
0.1Ω - 5.1KΩ
0.1Ω - 15KΩ
Note: Special value is available on request.
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
5 times of rated power for 5 sec.
±1.0%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
-55°C to +250°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>100MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Pull test (30 Sec. Min): 5W: 1kg, 10W: 2.3kg, 25 - 50W: 4.5kg
±0.2%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±5.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±1.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±1.0%+0.05Ω
Note: Rated Continuous Working Voltage (RCWV) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“AHP500JB-100R”相匹配的价格&库存,您可以联系我们找货
