AHA500FB-91R
AHA500FB-91R
    YAGEO(国巨)
    插件
    AHA500FB-91R
AHA500FB-91R 数据手册
DATA SHEET ALUMINUM HOUSED RESISTORS High Power, Wirewound Chassis Mount AHA series AHP series ±1%, ±2%, ±5%, ±10% 5W to 50W Product specification – September 27, 2023 V.1 RoHS compliant & Halogen Free Through Hole Resistors Aluminum Resistors Product Specification ORDERING INFORMATION Part number of the aluminum housed power wirewound resistor resistors are identified by the series, power rating, tolerance, packing, temperature coefficient, type and resistance value. PART NUMBER AHA 500 F B - U (1) (2) (3) (4) (5) (6) 100R (7) APPLICATIONS  Power, pulse application  Industry electronic (1) SERIES AHA Series = Lug / Threaded terminal AHP Series = Axial lead  BMS  Large-sized machinery FEATURES  Reduced size  Heatsink mounted (2) POWER RATING 500= 5W 25A = 25W 10A = 10W 50A = 50W (3) TOLERANCE F = ±1% J= ±5% G = ±2% K = ±10%  Excellent surge performance  Corrosion-resistant aluminum are corrugated for added strength and power dissipation (4) PACKAGING  RoHS compliant & halogen-free (5) TEMPERATURE COEFFICIENT OF RESISTANCE B = Bulk E=±50ppm/°C, G=±200ppm/°C F=±100ppm/°C, - = Based on spec. (6) TYPE Optional code, represents specific requirement, Example: U = Resin glue filling W = Silicone sealant filling Null = Quartz filling, resin glue sealing (7) RESISTANCE VALUE E24 & E96 Series Example: 1R = 1Ω, 10R = 10Ω, 100R= 100Ω www.yageo.com Sep. 27, 2023 V.1 2 8 AHA, AHP Through Hole Resistors Product Specification Aluminum Resistors DIMENSIONS AHA Series: TYPE Normal DIMENSIONS Unit: mm L1±1.5 L2±0.5 L3±0.5 A±0.5 B±0.5 C±0.5 Ø E±0.3 S±1.0 H±1.0 P±1.0 H1±1.0 K±0.3 M±0.05 N±0.3 AHA500 28.6 15.2 11.5 16.4 12.5 8.5 2.4 8.1 3.8 6.7 1.7 2 1.5 1.3 AHA10A 34.9 19 14.2 20.3 15.9 10.7 2.4 9.9 4.2 7.95 1.9 2.4 2 2.2 AHA25A 49.2 27 18.2 27.4 19.8 14 3.2 13.9 5.9 11.1 1.9 4.4 2 2.2 AHA50A 70.6 50 40 29 21.4 16 3.2 15.5 6.6 10.3 2.2 5 2 2.2 AHP Series: TYPE DIMENSIONS Unit: mm Normal L1±3.0 L2±0.5 L3±0.5 A±0.5 B±0.5 C±0.5 Ø E±0.3 S±1.0 H±1.0 P±3.0 H1±1.0 K±0.3 M±0.05 AHP500 71.2 15.2 11.5 16.4 12.5 8.5 2.4 8.1 3.8 28 1.7 2 0.8 AHP10A 75 19 14.2 20.3 15.9 10.7 2.4 9.9 4.2 28 1.9 2.4 0.8 AHP25A 83 27 18.2 27.4 19.8 14 3.2 13.9 5.9 28 1.9 4.4 0.8 AHP50A 106 50 40 29 21.4 16 3.2 15.5 6.6 28 2.2 5 0.8 www.yageo.com Sep. 27, 2023 V.1 3 8 AHA, AHP Through Hole Resistors Product Specification Aluminum Resistors DERATING CURVE Rated Power (%) 100 80 60 40 20 25 275 Ambient Temperature (°C) ELECTRICAL CHARACTERISTICS CHARACTERISTICS AHA500 AHP500 AHA10A AHP10A AHA25A AHP25A AHA50A AHP50A Power Rating on std. heatsink at at 25°C 5W 10W 25W 50W Power Rating without heatsink at 25°C 3W 8W 12.5W 20W Standard Heatsink Surface area (cm 2 ) 415 415 535 995 Standard Heatsink Thickness (mm) 1 1 1 1 Voltage Proof on Insulation (Vrms) 1000 1000 1000 1000 Voltage Proof on Insulation (Vrms) (Resin glue filling) 1000 1000 2000 2000 Voltage Proof on Insulation (Vrms) (Silicone sealant filling) 1000 1000 1000 2000 Resistance Range 0.1Ω~1KΩ 0.1Ω~1.5KΩ 0.1Ω~5.1KΩ 0.1Ω~15KΩ Maximum Working Voltage √(P X R) Insulation Resistance >100MΩ Climatic Category 55/200/56 Operating Temp. Range - 55°C to +275°C Temperature Coefficient ±50ppm/°C , ±100ppm/°C, ±200ppm/°C Note: For resistance value out of above range is by request. www.yageo.com Sep. 27, 2023 V.1 4 8 AHA, AHP Through Hole Resistors Aluminum Resistors Product Specification TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 5 times of rated power for 5 sec. ±1.0%+0.05Ω Voltage Proof on IEC 60115-1 4.7 In V-Block for 60 sec. test voltage as No Breakdown Insulation PROCEDURE APPRAISE above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +275°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking Robustness of coatings and markings IEC 60115-1 4.16 Terminations Damp Heat Steady State Pull test (30 Sec. Min): 5W: 1kg, 10W: ±0.2%+0.05Ω 2.3kg, 25 - 50W: 4.5kg IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV(or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C ➔ Resistance to Soldering IEC 60115-1 4.18 Heat ➔ Room Temp. ➔ +155°C ±1.0%+0.05Ω Room Temp.(5 cycles) 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body Note:. RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Sep. 27, 2023 V.1 5 8 AHA, AHP Through Hole Resistors Product Specification Aluminum Resistors BULK PACKING Unit: Piece Normal PACKAGE Quantity AHA500 AHP500 Bulk 540 AHA10A AHP10A Bulk 360 AHA25A AHP25A Bulk 200 AHA50A AHP50A Bulk 126 MARKING Example: YAGEO 1916 10W 10R J YAGEO = Brand 1916 = Date code 10W = Power rating 10R = Resistance J = Tolerance www.yageo.com Sep. 27, 2023 V.1 6 8 AHA, AHP Through Hole Resistors Aluminum Resistors Product Specification REVISION HISTORY CHANGE NOTIFICATION REVISION DATE Version 1 Aug.31 , 2023 - - Update legal disclaimer Version 0 Aug.2 , 2021 - First issue of this specification - DESCRIPTION “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Sep. 27, 2023 V.1 7 8 AHA, AHP Through Hole Resistors Aluminum Resistors Product Specification LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applicatio ns under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipme nt, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space f light. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Sep. 27, 2023 V.1 8 8 AHA, AHP
AHA500FB-91R
物料型号:AHA系列(带螺母/螺纹端子)和AHP系列(轴向引线)
器件简介:高功率、线绕、符合RoHS标准、无卤素的铝壳电阻器,适用于电源、脉冲应用、工业电子、电池管理系统(BMS)和大型机械。
引脚分配:AHA系列为带螺母/螺纹端子,AHP系列为轴向引线。
参数特性: - 功率范围:5W至50W - 公差:±1%, ±2%, ±5%, ±10% - 温度系数:±50ppm/°C, ±100ppm/°C, ±200ppm/°C - 电阻值范围:0.1Ω至15KΩ - 工作温度范围:-55°C至+275°C
功能详解: - 减小尺寸,提供良好的热冲击性能 - 耐腐蚀铝壳,增加了强度和散热能力 - 可选填充材料,如树脂胶填充、硅胶密封剂填充或石英填充
应用信息:适用于需要高功率和高可靠性的应用,如电源、脉冲负载、工业电子设备、电池管理系统和大型机械。
封装信息:提供了详细的尺寸数据,包括AHA系列和AHP系列的L1、L2、L3等尺寸参数,以及标记和包装信息。
AHA500FB-91R 价格&库存
很抱歉,暂时无法提供与“AHA500FB-91R”相匹配的价格&库存,您可以联系我们找货
AHA500FB-91R
    • 1+5.87520
    • 200+2.27880
    • 500+2.19240
    • 1000+2.16000
