EWT225JB5K00
EWT225JB5K00
    SEI
EWT225JB5K00 数据手册
SWT/EWT Series Stackpole Electronics, Inc. Non-Flammable Edgewound Tubular Wirewound Resistor Features: • • • • • • • • Resistive Product Solutions High current capability RoHS compliant, lead-free and halogen-free Non-inductive style only available with silicone coating (NSWT) Suitable for soldering or thru bolt connections Wirewound ribbon on ceramic substrate SWT – Silicone coating provides temperature handling up to 350ºC SWTA – Adjustable version EWT – Vitreous enamel coating provides temperature handling up to 500ºC Electrical Specifications Type/Code (SWT, EWT, NSWT) Power Rating (Watts) @ 25ºC 25 50 100 225 25W 50W 100W 225W Ohmic Range (Ω) and Tolerance 5%, 10% SWT NSWT 0.1 - 30K 0.1 - 100 0.1 - 50K 0.1 - 275 0.1 - 100K 0.12 - 680 0.2 - 130K 0.3 - 1.7K Dielectric Strength VAC 2,500 2,500 2,500 2,500 100 Percent Rated Power (%) Power Derating Curve: -55ºC EWT 1 - 10K 1 - 20K 1 - 50K 1 - 130K 25ºC 80 60 40 20 350ºC 0 -60 0 50 100 150 200 250 300 350 Ambient Temperature (ºC) Mechanical Specifications Type/Code (SWT, EWT, NSWT) 25 50 100 225 OD 0.563 14.30 0.563 14.30 0.752 19.10 1.126 28.60 ± ± ± ± ± ± ± ± ID 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.313 7.94 0.313 7.94 0.500 12.70 0.752 19.10 Rev Date: 09/05/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± L 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 2.008 51.00 4.016 102.00 6.496 165.00 10.512 267.00 1 ± ± ± ± ± ± ± ± F 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.472 12.00 0.748 19.00 0.669 17.00 0.709 18.00 ± ± ± ± ± ± ± ± 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 E G Unit 0.177 4.50 0.315 8.00 0.315 8.00 0.354 9.00 0.079 2.00 0.197 5.00 0.197 5.00 0.197 5.00 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com SWT/EWT Series Stackpole Electronics, Inc. Non-Flammable Edgewound Tubular Wirewound Resistor Hardware: • • Resistive Product Solutions Sturdy plated steel brackets, thru-bolts, centering washers, and insulating washers Brackets provide elongated mounting holes for ease of mounting Mounting Brackets Mechanical Specifications Resistor Power Rating 25W 50W 100W 225W A B C D E F Unit 1.000 25.40 1.000 25.40 1.000 25.40 1.500 38.10 0.750 19.05 0.750 19.05 0.750 19.05 0.875 22.23 0.500 12.70 0.500 12.70 0.500 12.70 1.250 31.75 0.219 5.56 0.219 5.56 0.219 5.56 0.281 7.14 0.438 11.13 0.438 11.13 0.438 11.13 0.563 14.30 0.177 4.50 0.315 8.00 0.315 8.00 0.354 9.00 inches mm inches mm inches mm inches mm Bolts and Washers Mechanical Specifications Metal Centering Washer Resistor Power Rating 25W 50W 100W 225W OD 0.563 14.30 0.563 14.30 0.752 19.10 1.126 28.60 Core Length 2.008 51.00 4.016 102.00 6.496 165.00 10.512 267.00 Rev Date: 09/05/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Mica Insulating Washer Bolt Length 2.500 63.50 4.750 120.65 7.000 177.80 11.250 285.75 Bolt No. 10 10 10 0.25" 2 A B C D Unit 0.560 14.22 0.560 14.22 0.750 19.05 1.125 28.58 0.190 4.83 0.190 4.83 0.190 4.83 0.250 6.35 0.750 19.05 0.750 19.05 1.000 25.40 1.500 38.10 0.313 7.95 0.313 7.95 0.500 12.70 0.750 19.05 inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com SWT/EWT Series Stackpole Electronics, Inc. Non-Flammable Edgewound Tubular Wirewound Resistor Resistive Product Solutions Spring Clips Mechanical Specifications Resistor Power Rating 25W 50W A B C D Unit 0.625 15.88 0.625 15.88 0.250 6.35 0.250 6.35 0.469 11.91 0.469 11.91 0.313 7.95 0.313 7.95 inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) SWT Non-Flammable Edgewound Tubular Wirewound Silicone Coating Resistor Special YES 100% Matte Sn Always Always EWT Non-Flammable Edgewound Tubular Wirewound Vitreous Enamel Coating Resistor Special YES 100% Matte Sn Always Always Standard Product Series “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 09/05/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com SWT/EWT Series Stackpole Electronics, Inc. Non-Flammable Edgewound Tubular Wirewound Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 E W T M 5 0 J B 2 0 0 R Product Series Description Code Silicone Coating SWT (std) EWT Vitreous Enamel Non-inductive NSWT Silicone Coating Type Description Code Std Tab Connection M Mounting Hardware S Spring Clips L Welded Straight Leads A Adjustable Rev Date: 09/05/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Power Code Power 25W 25 50W 50 100 100W 225 225W Tolerance Code Tol J 5% K 10% Code B Packaging Description Size Quantity Bulk All Sizes Each Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 10 Kohm = 10K0 100 Kohm = 100K 4 www.seielect.com marketing@seielect.com
EWT225JB5K00 价格&库存
很抱歉,暂时无法提供与“EWT225JB5K00”相匹配的价格&库存,您可以联系我们找货
