JW Series
Stackpole Electronics, Inc.
Tin Plated Jumper Wire Resistor
Resistive Product Solutions
Features:
Ideal for crossovers or jumpers on circuit boards
High current ratings
Standard JW is copper plated steel, with 100% tin overplate
100% tin plate on copper wire is available as type JWQ
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical and Mechanical Specifications
Type / Code
Gauge
Reference
Maximum
Current (A)
JW50
24
3
JW55
23
3
JW60
22
3
JW80
Diameter
0.020
0.50
0.022
0.55
0.024
0.60
0.031
0.80
0.0008
0.02
0.0012
0.03
0.0012
0.03
0.002
0.05
Unit
inches
mm
inches
mm
inches
mm
inches
mm
Performance Characteristics
Item
Coating
Thickness
Specification
5u ± 2u
7.1 0.4mm - below 0.6mm - 250g
7.2 0.6mm - below 1 - 500g
8.1 Sn 100%:
Heat 195ºC ± 5ºC / 1 hour
Bending
Heat Reliability
Humidity
40ºC / 90 - 95RH / 72 hours
Solderability
235ºC ± 5ºC / 3 seconds
Rev Date: 09/01/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
JW Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
JW
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Resistor
Axial
YES
100% Matte Sn
Jan-04
04/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the
eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the
electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and
products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of
Dodd-Frank Act regarding Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free
and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually
strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our
environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms
of pollution.
How to Order
J
W
Product Series
Size
Code Description Code Diameter
JW Jumper Wire
50
0.5 mm
55 0.55 mm
60
0.6 mm
80
0.8 mm
5
Z
T
R
Tolerance
Packaging
Code
Tol
Code
Description
Size
Z Zero Ohm
50, 55, 60
T
Tape and Reel
80
50, 55, 60
A
Ammo
80
2
Resistance Value
Quantity
10000
8000
10000
8000
Four characters with
the multiplier used as
the decimal holder.
Zero Ohm = 0R00
www.seielect.com
很抱歉,暂时无法提供与“JW50ZT0R00”相匹配的价格&库存,您可以联系我们找货
