60817067
60817067
    SCHROFF.PENTAIR.
    Extraction Handle Polybutylene Terephthalate
60817067 数据手册
Main Catalog 24th Edition Main Catalog Schroff gmbh, Langenalber Strasse 96–100, D-75334 Straubenhardt WWW.PENTAIREQUIPMENTPROTECTION.COM Equipment Protection Solutions 12/2017 39601-641 © 2012 Pentair Equipment Protection 18002_Hauptkatalog_Schroff_Umschlag_AK03_EN.indd 1 10.10.2012 11:15:02 DESIGN WITH CONFIDENCE ® Pentair, together with its Hoffman®, McLean® and Schroff® brands, is a leading manufacturer of products and solutions for the housing, protection and cooling of electrical and electronic assemblies and components. Under the slogan "Design with ­CONFIDENCE®" the company offers the highest standards across the industry for quality, performance and design. Pentair offers a vast diversity of off-the-shelf products as well as modified and customized solutions for applications in the measurement and instrumentation, telecommunications and data processing, energy and industrial, transport and medical industries and for electronic systems for security and defense. When you enter a partnership with Pentair you are drawing on the capabilities of a company that has all the necessary financial and other resources at its disposal to develop, manufacture and assemble application-critical systems to your requirements, down to defined function testing and prompt delivery of the goods anywhere in the world. Regional Headquarters Anoka, MN, USA Boituva, Brazil Straubenhardt, Germany Singapore Shanghai, China Manufacturing and Logistics Locations Pharr, TX, USA Anoka, MN, USA Mt. Sterling, KY, USA Radford, VA, USA Warwick, RI, USA San Diego, CA, USA Boituva, Brazil Melbourne, Australia Reynosa, Mexico Betschdorf, France Straubenhardt, Germany Dzierzoniow, Poland Bangalore, India Qingdao, China Meiwa, Japan Pentair Equipment Protection brands pentairequipmentprotection.com 02 18002_Hautpkatalog_Schroff_EN_AK03.indd 2 17.10.2012 11:18:23 INNOVATIVE, SOPHISTICATED, CUSTOMER-ORIENTED AND WITH GLOBAL PRESENCE: Schroff The Schroff® brand stands for recognized, globally leading developments in electronics packaging components and systems for applications in measurement, instrumentation and control systems, infrastructure, security systems, data communications, telecommunications and automation. Our customeroriented thinking and mode of working is an important element of our business model. At a glance: what sets Schroff products apart: - Certified to global standards - Global availability - Outstanding quality - Innovative solutions - Comprehensive heat management - Large off-the-shelf product program - Modifications to your requirements - Custom new developments - Customer-oriented thinking and operations - Service quality and competence - Extensive testing - Best price-performance ratio Main Catalog 2016 18002_Hautpkatalog_Schroff_EN_AK03.indd 3 03 17.10.2012 11:20:01 SIX STEPS TO THE RIGHT PRODUCT 1. APPLICATION The choice of enclosure often depends on the field of application and/or market segment. Does your product require a door, shelves, slide rails or a support arm for a monitor? Is ease of access important? Do you require cooling for your components, redundancy or electromagnetic 2. ENVIRONMENT Environmental conditions are perhaps the most important factor when selecting the correct enclosure. Is it intended for use in, say, telecommunications, industry, measurement and control, infrastructure or security systems, or as a data communications system? You should also consider the main challenges the enclosure will face, such as: - electromagnetic radiation 3. STANDARDS Select an enclosure that satisfies the required standard of protection for the environment and application in question. The evaluation criteria of protection classes such as NEMA, UL, cUL, Telcordia GR-487, CSA, DIN, VDE, GOST, RoHS, CE, IEC, EN, NFF, BN, IEEE, PICMG and VITA are a measure of the capability of an enclosure to shielding? Many details are required to enable you to select the correct enclosure. You can find more technical information about electromagnetic compatibility on page 12.6. - shock and vibration - corrosion - the required loading capacity - dust or sand - fire - extreme temperatures - low atmospheric pressure Deciding these considerations simplifies the choice of the best product for your needs. You can find further information in the appendix on ­pages 12.3-12.6 withstand specific environmental conditions. Note however that these protection classes differ from one another in important aspects. Further technical information is available in the appendix on pages 12.1-12.7 and in our Standards Summary brochure, which you can order from our website www.schroff.biz/catalogues. 04 18002_Hautpkatalog_Schroff_EN_AK03.indd 4 17.10.2012 11:20:24 4. SIZE Several factors must be considered when specifying the size of the enclosure. What materials should it be built from? Where in the enclosure will the assemblies be fitted? Will you be installing devices on a mounting plate? Will you be fitting operating elements to a door? Does your application have specific requirements for the location of the enclosure? 5. MATERIAL Select the most suitable material for your product, taking into consideration the potential environmental risks and possible contamination by harmful substances against which you must protect the enclosure. – steel – stainless steel – aluminum – fiberglass – ABS – polycarbonate – polyester We will then help you select the most suitable surface finish: – electroplating – hot-dip galvanizing – passivation – anodization – paint (various compositions) Further technical information is available in the appendix on pages 12.4-12.5 and in our Standards Summary brochure (pages 26-33), which you can order from our website www.schroff.biz/catalogues. 6. THERMAL MANAGEMENT Faster and more powerful assemblies produce ever more waste heat. Effective thermal management is therefore important to ensure optimum efficiency and service life for the electronic components. While in most cases the central task is to monitor and dissipate the heat generated, there are also circumstances in which heating is necessary. Some basic questions for determining the appropriate cooling method for your application include: Which enclosure surfaces allow heat transfer? How much heat is generated by each installed component? What temperature conditions must be observed? Will your application be used in a closed room or out of doors? Will the cooling device be fitted on the top, the side or within the enclosure? With the help of your Schroff contact, select the most suitable cooling solution from our wide product range in section 4. You will also find more solutions on the Pentair McLean website www.mcleancoolingtech.com or in the McLean catalog, in the "McLean V-Series" and "McLean Thermoelectric Coolers" brochures and in the main Pentair Hoffman catalog, which you can order from www.schroff.biz/catalogues. Main Catalog 2016 18002_Hautpkatalog_Schroff_EN_AK03.indd 5 05 17.10.2012 11:20:40 ServicePLUS configuration Simple. Fast. To the ideal product. We help you to build your ideal product out of off-the-shelf components quickly, competently and simply with interactive online configurators, our telephone configuration hotline and Power Search, which lets you select standard components fast www.schroff.co.uk/configuration assembly Built by professionals. Double the benefit. For turnkey products, ServicePLUS assembly lets you keep your attention on your core activity without interruption, while we carry out the complete assembly of all your system components, competently and on time; competently and on time www.schroff.co.uk/assembly modification Minor modifications. Large impact. Quality also means 100% accuracy of fit. We therefore also modify off-the-shelf products to your individual needs, for example, drilled holes, cut-outs, printing and special colors. www.schroff.co.uk/modification solution Simple. Fast. From one source. If it is not possible to use off-the-shelf products, we will create a special custom solution - from development and design through to complete, integrated, functioning systems or even highly specific new developments. www.schroff.co.uk/solution express When fast has to be even faster. In many projects speed is of the essence, and flexibility a decisive criterion. With us you can select your delivery time from a range of express options. support Support. Solution. Availability. ServicePLUS support is our after-sales service and sets up an ongoing relationship with you. We offer a modular range of support options that can be tailored to your specific service requirements. www.schroff.co.uk/support academy Know. Share. Become a partner. With ServicePLUS academy we offer you straightforward access to our specialist knowledge. This includes: • Seminars and training about our products • Modern knowledge transfer using webcasts, white papers and webinars • Technical reports, technical details and CAD drawings available by download www.schroff.co.uk/academy lifecycle We stay with you. For the entire life of the product. With ServicePLUS lifecycle you profit from our flexibly configurable, comprehensive support over the entire life of your products and complete solutions. Select options from our range to your exact needs and create your individual Lifecycle package. www.schroff.co.uk/lifecycle 06 18002_Hautpkatalog_Schroff_EN_AK03.indd 6 17.10.2012 11:20:41 HOW TO CONTACT US Your local contact ALL CONTACT DETAILS FOR YOUR PERSONAL CONTACT PARTNER ARE HERE: Online at www.schroff.biz/contact or in the address list at the end of this catalog. YOUR ONLINE CONTACT WITH SCHROFF At www.schroff.biz you can reach us round the clock. Use the inquiry basket to inquire online about the articles you require, simply and without complication, and receive a quotation within 24 hours. For customers who prefer quick and reliable processing when ordering stock products by authorized and qualified business partners, our distribution partners are the first choice. If you are looking for professional support for adapting our products to your individual needs, contact our value-added resellers. These can of course also supply off-the-shelf products. Decide together with us whether you would like support either from our direct sales department or through our business partners in various countries. See www.schroff.biz/contact for the advantages of the different sales and distribution options. WE WILL ANSWER YOUR INQUIRY WITHIN 24 HOURS Just send us an inquiry or order by e-mail to schroff.uk@pentair.com or to your personal contact. You can naturally also send us a fax. Main Catalog 2016 18002_Hautpkatalog_Schroff_EN_AK03.indd 7 07 17.10.2012 11:20:42 HOW TO OBTAIN OUR PRODUCTS ONLINE You will see our oneClick symbol next to many products in this catalogue. By entering the order number at www.schroff.biz/oneclick you can quickly and easily obtain further information about the relevant product. - detailed product description - scope of delivery information - detailed drawings - technical information - user manuals - test reports - downloadable CAD drawings - certificates - test reports You can also use the free text search available at www.schroff.biz under "Search" in the function bar: 5. September 2012 6:12 06 Cabinets – VARISTAR Electronics Apart from the order number, you can also enter product names or other terms. 19'' fixed shelf, 75 kg VARISTAR Electronics  Static load-carrying capacity 75 kg (150 kg with strengthening rail)  Mounting height 1 U, for mounting on four panel/slide mounts  With hammer head perforation to fix cable ties Delivery comprises xr 01004066 Item 1 Qty 1 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing Catalogue D c RAL 7035 For cabinet Usable xf depth surface w x d mm mm mm mm Part no. 600 495 x 442 50 500 22130-303 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf PU 1 piece RAL 7021 Part no. 21130-303 21130-305 23130-310 Note  Cable ducting with cable ties, see page 1.25  Other sizes, see ServicePLUS, page 1.49 xf d c Order Information For further information www.schroff.biz/oneclick To help you get your bearings quickly and simply, all the ordering tables in this catalog are uniformly designed: - The first section contains the ordering information for the product. - The next section, indicated by a separating line, shows suitable accessories. - Order numbers printed in bold are available for shipping in 2 working days; order numbers in ordinary type can be shipped within 10 working days. - Further information, if available, on the product or accessories is shown at the end of the ordering table. 01004067 oneClick search code = Part no. ounts sion 08 18002_Hautpkatalog_Schroff_EN_AK03.indd 8 17.10.2012 11:20:46 Cabinets Overview............................................. 1.0 Varistar Cabinet platform.................. 1.2 Varistar Electronics........................... 1.10 Varistar EMC...................................... 1.54 Varistar Seismic................................ 1.84 Varistar MIL....................................... 1.120 Varistar Data/network systems........ 1.124 Varistar Containment........................ 1.202 LHX 20/40 Air/water heat exchangers..... 1.224 LHX 3 Air/water heat exchangers........... 1.236 Novastar............................................. 1.240 Eurorack............................................ 1.270 Outdoor ............................................. 1.316 Etsirack.............................................. 1.346 19” lab racks...................................... 1.354 PROLINE............................................ 1.362 1 2 Wall mounted case Overview............................................. 2.0 Epcase................................................ 2.36 LAN wall-mounted distributors........ 2.46 Cabinet and wall-mounted case accessories Overview............................................. 3.0 Mechanics.......................................... 3.2 Telescopic slides............................... 3.24 Electrical............................................ 3.29 Monitors, keyboards, monitoring...... 3.44 Socket strips...................................... 3.50 Power control socket strips.............. 3.72 Climate control Overview............................................. 4.0 Cooling concepts/service.................. 4.2 19” fan trays....................................... 4.4 Air filtered fans.................................. 4.20 Accessories........................................ 4.58 Desktop enclosures Overview............................................. 5.0 RatiopacPRO...................................... 5.6 PropacPRO........................................ 5.44 CompacPRO...................................... 5.76 Comptec............................................. 5.100 Accessories........................................ 5.108 Interscale........................................... 5.200 Minipac ............................................. 5.230 5 Subracks/ 19” chassis Overview............................................. 6.0 EuropacPRO...................................... 6.2 EuropacPRO for railroad applications.......................6.70 EuropacPRO industrial applications.. 6.86 EuropacPRO Rugged......................... 6.92 MultipacPRO...................................... 6.112 Inpac.................................................. 6.128 6 Front panels, Plug-in-units, Frame type plug-in-units Overview............................................. 7.0 Front panels....................................... 7.2 Plug-in units...................................... 7.16 Frame type plug-in units................... 7.64 PCB accessories................................ 7.102 Systems Overview............................................. 8.0 AdvancedTCA..................................... 8.2 AdvancedMC carriers........................ 8.26 MicroTCA............................................ 8.36 AdvancedMC modules....................... 8.56 CompactPCI, Serial, PlusIO, PSB..... 8.68 VME, VME64x, VXS, VPX..................... 8.88 Accessories........................................ 8.106 8 Power supply systems Overview............................................. 9.0 19” AC/DC switched-mode PSUs..... 9.2 19” AC/DC linear regulators............. 9.12 19” AC/DC convertors....................... 9.15 19” accessories................................. 9.18 PSUs for MicroTCA............................ 9.20 PSUs for VMEbus.............................. 9.22 PSUs for CompactPCI, VME64x.......... 9.24 9 Backplanes Overview........................................... 10.0 CompactPCI, Serial, PlusIO............ 10.4 PXI.................................................... 10.11 VXS................................................... 10.14 VME64x, VMEbus............................. 10.15 Power............................................... 10.18 Universal.......................................... 10.19 Test adaptors................................... 10.20 10 Connectors, Front panel component systems Overview........................................... 11.0 Connectors...................................... 11.2 Front panel component system...... 11.12 11 Appendix Standards abbreviations................. 12.0 Notes on ordering............................ 12.10 Order number index........................ 12.11 Product index................................... 12.62 12 3 4 7 Main Catalogue Cabinets – Overview Content Cabinets . . . . . . 1 VARISTAR Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 쮿 Cabinet platform for many application areas like electronics, datacom and networking technologies – 19" or metric versions – EMC shielded – Earthquake-proof – Variable cooling concepts – Air-conditioned cabinets – Extensive range of innovative cable routing accessories 쮿 Welded steel frame for static load-carrying capacity of up to 1200 kg 쮿 Type of protection IP 20 or IP 55 Electronics cases . . . . . . . . . 5 Subracks/ 19" chassis . . . . 6 NOVASTAR 쮿 19" electronics cabinet for applications in the measurement and control, audio and video industries 쮿 Attractive design with visible profile frame, inset cladding parts and full glass doors 쮿 Cabinet height from 6 U to 47 U 쮿 Cabinet width only 553 mm 쮿 Screw fixed aluminium rack for static load-carrying capacity of up to 400 kg 쮿 Type of protection up to IP 40 NEW Front panels, plug-in units . . . 7 Systems . . . . . . . 8 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 P 쮿 19" cabinet for electronics applications 쮿 Screw fixed aluminium frame for static load-carrying capacity of up to 400 kg 쮿 Type of protection IP 40 Appendix . . . . . 12 36109003 (01006007 01005001 07011036 00105003 ) 1.2 SCHROFF Further information: www.varistar.de E 05/2016 ELECTRONICS PROTECTION Cabinets – Overview Overview . . . . . . 1.2 Outdoor VARISTAR . . . . . . 1.2 쮿 Aluminium cabinet for outdoor use and to accommodate 19", metric or non-standardized components 쮿 Type of protection IP 55 쮿 Single-wall or double-wall versions 쮿 Static load-carrying capacity up to 400 kg VARISTAR Electronics . . . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR MIL . . . . . . . . . . . . . 1.120 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR Aisle Containments . . . . 1.202 VARISTAR Air/water heat exchanger . . . . . . . 1.224 Z 쮿 Designed for telecommunications applications in accordance with the ETS standard 쮿 Steel construction, 300 mm deep 쮿 Static load-carrying capacity 200 kg 쮿 Type of protection IP 20 NOVASTAR . . . . . 1.240 eurorack . . . . . . . 1.270 Outdoor . . . . . . . . . 1.316 etsirack . . . . . . . . 1.346 Lab racks . . . . . . . 1.354 Lab Racks PROLINE . . . . . . . 1.362 쮿 Open 19" frame for lab applications, stationary or mobile 쮿 Steel construction 쮿 Static load-carrying capacity 200 kg Cabinet Accessories . . . . 3.0 36109004 (41602001 40012001 05601002 01305003) SCHROFF.PENTAIR.CO.UK 1.3 VARISTA RMain Catalogue Cabinets – VARISTAR Content Cabinets . . . . . . 1 VARISTAR Electronics Wall mounted cases . . . . . . . . . 2 쮿 Open cabinets with decorative frame 쮿 19" cabinets with IP 20 or IP 55 protection class Accessories for cabinets and wall mounted cases . 3 쮿 Extensive range of innovative accessories for electronics cabinets Climate control . 4 Electronics cases . . . . . . . . . 5 VARISTAR EMC 쮿 Shielding up to 60 dB at 1 GHz and 40 dB at 3 GHz Subracks/ 19" chassis . . . . 6 쮿 High shielding also when combined with perforated doors or fan top covers 쮿 Individual configuration options with ServicePLUS configuration Front panels, plug-in units . . . 7 Systems . . . . . . . 8 VARISTAR Seismic 쮿 Earthquake-resistant cabinets tested to Bellcore Zone 4 쮿 Individual configuration options with ServicePLUS configuration Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 VARISTAR MIL NEW 쮿 Tested and certified to MIL 901D 쮿 With shock absorbers 쮿 Shielded against high-frequency interference 쮿 IP 55 Appendix . . . . . 12 36108003 (01006007, 01004031, 01007002, 01005018, 01012004) 1.2 SCHROFF Main catalogue www.schroff.biz E 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR Overview . . . . . . 1.2 VARISTAR Data and networking technology VARISTAR Platform . . . . . . . 1.4 쮿 Wide range of network and server cabinet versions 쮿 Server cabinets with depths up to 1200 mm 쮿 Two standard colors: light grey (RAL 7035) or black grey (RAL 7021) 쮿 Extensive, innovative range of cable routing accessories 쮿 Individual configuration options with ServicePLUS configuration VARISTAR Electronics . . . . 1.10 VARISTAR EMC . . . . . . . . . . . . 1.54 VARISTAR Seismic . . . . . . . . 1.84 VARISTAR Aisle containments NEW VARISTAR MIL . . . . . . . . . . . . 1.120 쮿 Cold aisle containments 쮿 Modular standard components 쮿 Extensive range of swing and sliding doors VARISTAR Datacom and Networking Technology . . . . 1.124 VARISTAR with air/water heat exchangers VARISTAR Aisle containment . . . . 1.202 LHX 20/40 쮿 Server cabinets with air/water heat exchanger VARISTAR Air/water heat exchangers . . . . . 1.224 쮿 Versions with single or double doors and with automatic door opening Cabinet Accessories . . . . 3.0 LHX 3 쮿 Electronics cabinets with LHX 3 air/water heat exchanger 36108004 (01006006, 01006015, 01012006, 01007015, 01006040) SCHROFF.PENTAIR.CO.UK 1.3 Cabinets – VARISTAR platform Two load-carrying classes, one accessory range: The VARISTAR frames VARISTA R platformMain CatalogueP art number in bold fac e type: ready for despatch withi n 2 working daysP art number i n normal type: ready for despatch within 1 0 working days VARISTAR is the only cabinet platform that allows identical accessories to be combined with two basic frames. The cabinet is available in Slim-Line (narrow) or Heavy-Duty (robust) profiles. Slim-Line profile The Slim-Line version is based on very thin steel profiles in order to obtain the greatest opening width between the uprights. This frame can accommodate either 19" equipment or metric components to ETS 3000-119-3. With a maximum load of 400 kg* on the 19" plane the frame is still highly robust and suitable for demanding applications in electronics or data and network technology. Heavy-Duty profile 01004035 The Heavy-Duty frame, on the other hand, is designed for use with heavy loads or in regions susceptible to earthquakes. It offers on the one hand maximum stability for a load of up to 800 kg* on the 19" plane and, thanks to its high bending stiffness, can meet the shock and vibration requirements such as occur in railway and traffic signal installations, in the control of rotating machines, on commercial ships or in low-level military installations. In the IEC 61587-2 earthquake test the Heavy-Duty frame qualified for use in Bellcore Zone 3. Equipped with very simple, low-cost strengthening brackets, the VARISTAR Seismic version meets the demands of Bellcore Zone 4. 01006035 Slim-Line profile Static load-carrying capacity Type of protection Shock test 01006034 Heavy-Duty profile 01008062 Heavy-duty profile with strengthening bracket Standard IEC 61587-1 Slim-Line 400 kg * Heavy-Duty 800 kg * IEC 60529 IEC 61587-1 IP 20, IP 55 Maximum acceleration: 5 g Duration: 11 ms Frequency: 5 Hz -100 Hz Acceleration: 1 g IP 20, IP 55 Maximum acceleration: 5 g Duration: 11 ms Frequency: 5 Hz -100 Hz Acceleration: 1 g Standard: up to Bellcore With strengthening: up to Bellcore Zone 3, acceleration: 3 g, Zone 4, acceleration: 5 g, Frequency: 1 Hz ... 5 Hz Frequency: 2 Hz ... 5 Hz 60 dB at 1 GHz, 40 dB at 3 GHz 19" Vibration test IEC 61587-1 Earthquake test IEC 61587-2 EMC shielding Installing options IEC 61587-3 60 dB at 1 GHz, 40 dB at 3 GHz 19" or ETS * Figures for static load-carrying capacity are based on the IEC 61587-1 test procedure. In this procedure the cabinet is standing on the floor under its equipment load and lifted up by its lifting eyes; no significant deformations may occur on the frame or at the 19" panel/slide mounts under maximum carrying capacity. The potential load for the VARISTAR frame is therefore, under normal operating conditions, considerably higher than the test value given under IEC 61587-1. 1.4 SCHROFF PRODUCT CATALOG D 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR platform Decidedly different: The VARISTAR sealing and shielding concept VARISTAR platform Item 1 2 3 4 5 Description Frame Conductive EMC textile gasket with CuNi coating Contact/shielding Rear panel Side panel 2 3 In most shielding designs currently available, conductive seals or springs connect the cover parts to the cabinet frame. The points of contact have thus to be kept conductive and corrosion-free. With VARISTAR, however, the conductive textile gaskets link the cover parts with one another directly, which results in two advantages: A considerably better shielding performance of 60 dB at 1 GHz (and 40 dB at 3 GHz) is obtained than with conventional designs. There is no longer any need for expensive treatment of the frame surface. The textile EMC gasket is also a protection against dust and water to IP 55. If no shielding is required, a rubber gasket is used offering the same protection to IP 55. Both gaskets are fitted to the 45°-angled surface of the exterior of the frame. 4 5 1 Shielding up to 3 GHz [dBµV] 100 90 80 70 60 50 40 1 30 2 20 10 0 0 500 1000 1500 2000 2500 3000 [Mhz] 1: Cabinet with solid door 01004141 01008061 01008005 2: Cabinet with perforated door Smooth-running and absolutely tight: The VARISTAR locking system The latching system also contributes to protection class and shielding. The innovative locking bar accepts a variable number of deadbolts, depending on the cabinet height, to ensure the most even compression of the gaskets. And best of all: Activating the locking bar causes the latches to move in the opposite direction. Thus the frictional forces of the bolts are balanced out and a resulting lopsided vertical force on the door is avoided. The doors close easily and with an absolute seal. EMC doors are fitted with 4-point locking, IP and server doors with 3-point locking. 01005080 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.5 Cabinets – VARISTAR platform Peerless and efficient: The VARISTAR profile (Slim-Line and Heavy-Duty) VARISTA R platform Mounting of the 19" bracket without depth members The VARISTAR profile has fixing holes in all three axes (height, width, depth), following a 25 mm grid. This allows for the greatest variability in the fitting of components and accessories. Thus for example 19" panel/slide mounts may be installed in a 600 mm wide cabinet without additional depth members. This saves costs and provides stability on the 19" plane. The intricately shaped form of the profile offers further new assembly possibilities. Cable eyes, for instance, can be plugged directly into the frame whilst fixing themselves. 01004034 01006105 Self-fixing cable eyes dummy New and well thought out: VARISTAR cable management Schroff has divided the available space in the VARISTAR into zones and given a simple description of the position and use of these zones. The coloured arrows show the direction of the cable ducting. Zone 1 Zone 2 01006087 쮿 In front of the 19" plane 쮿 In this zone the patch cables are ducted horizontally between the distribution fields 1.6 Zone 3 01006088 쮿 On the right and left hand side, next to the 19" plane 쮿 In this zone patch cables are ducted vertically in a kind of channel to the individual components SCHROFF PRODUCT CATALOG D 05/2016 For each zone a range of accessories has been developed to suit the conditions in the cabinet, which simplifies cabling and thus helps to include as many connections as possible in a distribution cabinet. The VARISTAR profile with its many fixing options has thus proved a real boon. Zone 4 01006085 01006086 쮿 Zone 3 is located laterally behind the 쮿 Zone 4 is located in the rear across the cabinet width 19" plane across the cabinet depth; mainly for 800 mm wide cabinets 쮿 Alternative to zone 3 for only 600 mm wide cabinets or when cable 쮿 In this zone entering cable bundles entry is at the rear of the are fixed in the cabinet, parted and cabinet ducted to the rear of the distribution fields ELECTRONICS PROTECTION Cabinets – VARISTAR platform Heat dissipation to exact requirements: cooling concepts for VARISTAR Depending on installed heat dissipation and the surroundings, VARISTAR offers various cooling options and also good conditions for problem-free operation of the installed equipment. Either top cover fans are used to assist the heat dissipation or perforated doors with 78 % air throughput are fitted. Additionally, VARISTAR LHX 20/40 with assembled air/water heat exchanger allows to cool especially strained appliances with water. And that for up to 40 kW per cabinet. 01105057 up to 2 kW 01105056 up to 6 kW 01106027 Fan unit, positioned inside 0100581 up to 40 kW 41003017 78 % air throughput 01005020 Air/water heat exchanger Classic and consistent: VARISTAR colour and design \ As well as its functional aspects, in the development of VARISTAR the design of the individual components and their combined effect on the appearance of the cabinet was always a priority. The cabinet gains its characteristic, unmistakable look from the high narrow door with the memorable hinges and the very thin, almost inconspicuous top cover edge. While rack, base and cover are offered in black grey (RAL 7021) for all standard cabinets, a choice of two colour options are available - even in our standard programme - for side panels, doors and rear panels: Either entirely black grey (RAL 7021), as is the contemporary look in data centres and recording studios. Or in light grey (RAL 7035), whereby an attractive combination of mainly light surfaces with a few dark accents is obtained. Alternatively, VARISTAR can be supplied in many RAL colours within 15 working days, or even as a combination of two special colours. The current range of colours can be seen online at www.schroff.co.uk/modification. 01006037 Colour RAL 7021 (black grey) SCHROFF.PENTAIR.CO.UK 01006036 Colour combination RAL 7035/RAL 7021 (light grey/black grey) Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.7 Cabinets – VARISTAR platform Frame dimensions Height Cabinet height mm 1200 1400 1600 1800 2000 2200 Frame H mm 1192 1392 1592 1792 1992 2192 U 24 29 33 38 42 47 h mm 1102 1302 1502 1702 1902 2102 Width Cabinet width mm 600 800 Frame W mm 592 792 Slim-Line w mm 535 735 Heavy-Duty w mm 502 702 Depth 01005087 Adjustable feet Cabinet depth mm 300 600 800 900 1000 1100 1200 D mm 292 592 792 892 992 1092 1192 Frame d mm 128.8 428.8 628.8 728.8 828.8 928.8 1028.8 d1 mm 150 450 650 750 850 950 1050 d2 mm 175 475 675 775 875 975 1075 01004081 Castors with adjustable feet Locking castors Height of adjustable feet, castors, base/plinth Adjustable feet Locking castors Castors with adjustable feet Base/plinth (feet) Base/plinth, mobile 20 ... 40 mm 85 mm 85 ... 95 mm 112 ... 132 mm 126.5 ... 134.5 mm 01004082 01004156 Base/plinth Mobile base/plinth 0100411001004111 1.8 SCHROFF PRODUCT CATALOG D 05/2016 ELECTRONICS PROTECTION Cabinets – VARISTAR platform Top cover with cut-out zones D 600 800 900 1000 1100 1200 a - b ✓ ✓ ✓ ✓ ✓ ✓ W = 600 mm c d ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ e ✓ ✓ ✓ a ✓ ✓ ✓ ✓ ✓ b ✓ ✓ ✓ ✓ ✓ ✓ W = 800 mm c d ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ e ✓ ✓ ✓ 01006097 Base plate, multi-piece b w a W c 200 50 D 600 800 900 1000 1100 1200 Cabinet width W mm 600 800 D 50 Depth in mm a 300 300 300 300 300 300 b 200 300 200 300 300 c 200 200 300 Opening width w mm 426 626 01006096 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.9 Varistar ElectronicsMain C atalogue Cabinets – Varistar Electronics Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01008004 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 01009002 19" panel mounts integrated in decorative frame 01005014 All-round gasketing to IP 55 Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01009002 Side panels with quick-release fastener, optionally lockable 01005014 3-point locking with contradirectional bolts Appendix . . . . . 12 1.10 SCHROFF E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Overview . . . . 1.10 Varistar ElectronicsMain Catalogue The universal cabinet for electronics 쮿 Selectable stability, static load-carrying capacity up to 800 kg VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 쮿 Professional solutions for cable ducting 쮿 Variable ventilation concepts, active and passive 쮿 Various versions in ServicePLUS configuration \ VARISTAR Deco VARISTAR IP 20 VARISTAR IP 55 VARISTAR Deco . . 1.12 VARISTAR IP 20 . . 1.13 VARISTAR IP 55 . . 1.14 Accessories Lever handle . . . . . 1.15 Base plate . . . . . . . 1.15 Base/plinth . . . . . . 1.16 Mounting plate . . . 1.17 19" swing frame . . . . . . . . . . . . 1.18 19 panel/slide mount . . . . . . . . . . . 1.19 19" fixing materials kit, M6 . . . . . . . . . . . . . . 1.19 Slide rails . . . . . . . . 1.20 19" shelves . . . . . . 1.21 Depth members . . 1.24 C horizontal rail . . 1.24 Cable tie, Velcro . . . . . . . . . . . 1.25 01004001 쮿 Open at front, with deco frame and integrated 19" panel mounts 01004002 쮿 With glass door and single point locking 01004003 쮿 With glass or steel door and 3-point locking ServicePLUS from page 1.26 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. variants of uprights (Slim-Line, Heavy-Duty) e.g. custom solutions (special sizes) ServicePLUS . . . 1.26 ServicePLUS IP 20 . . . . . . . . . . . . 1.27 ServicePLUS IP 55 . . . . . . . . . . . . 1.39 ServicePLUS Interior configuration . . . . . 1.44 VARISTAR EMC . . .1.54 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . .1.124 VARISTAR air/ water heat exchanger . . . . . . . 1.224 www.schroff.biz/ServicePLUS 30407004 SCHROFF.PENTAIR.CO.UK 1.11 Cabinets – Varistar Electronics Varistar Deco Varistar Electronics Main CataloguePart num ber in bold face type: ready for despatch within 2 working daysPart number in norm al type: ready for despatch w ithin 10 working days 쮿 Open at front (no door) 쮿 19" panel mounts integrated into decoration frame 쮿 Rear door with single point locking, side panels with quick release fastener 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 4 1 5 2 6 1 7 8 2 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, powder-coated, RAL 7021 Adjustable foot, assembled Raised top cover, St, RAL 7021, with 10 mm air gap all around Decorative frame, Al, integrated 19" panel mounts at the front, RAL 7035 Adapter bracket, St, 2 mm, RAL 7035, front, for assembling shelves and slide rails Rear door, St, 180° hinge, single point locking and key with safety lock, RAL 7035 Side panel, St, with quick-release fastener, RAL 7035 GND/earthing kit, supplied loose Order Information 10 01004001 Height Height H Width W Depth D U mm mm mm 38 1800 600 600 38 1800 600 800 42 2000 600 600 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces Lever handle for single point locking with push button, 1 piece DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for raised top cover PU 4 pieces Part no. 10130-001 10130-002 10130-003 10130-004 23130-077 23130-078 23130-067 25127-995 23130-085 Note W D 20 - 45 H 쮿 Lever handle can be added to rear door 쮿 For more dimensions and versions see ServicePLUS IP 20, starting on page 1.27 쮿 Please order base plate separately, see page 1.15 쮿 Please order base/plinth separately, see page 1.16 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.19 01004151 ServicePLUS see page 1.26 1.12 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Varistar IP 20 Varistar Electronic s 쮿 With glazed front door 쮿 Doors with single point locking, side panels with quick release fastener 쮿 Type of protection IP 20 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 1 4 1 5 1 6 2 7 2 8 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, powder-coated, RAL 7021 Adjustable foot, assembled Raised top cover, St, RAL 7021, with 10 mm air gap all around Front door, glazed, safety glass, 6 mm, 180° hinge, RAL 7035, single point locking, key lock cover Rear door, St, 180° hinge, RAL 7035, single point locking, key with safety lock Side panel, St, quick-release fastener with safety lock, RAL 7035 19" panel/slide mount with EIA cut-outs, St, RAL 7035, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 10 01004002 Height Height H Width W Depth D U mm mm mm 38 1800 600 600 38 1800 600 800 42 2000 600 600 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces Lever handle for single point locking with push button, 1 piece DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for raised top cover PU 4 pieces Part no. 10130-005 10130-006 10130-007 10130-008 23130-077 23130-078 23130-067 25127-995 23130-085 Note W D 20 - 45 H 쮿 Lever handle can be added to the doors 쮿 For other dimensions and versions see ServicePLUS configuration IP 20, from page 1.27 쮿 Please order base plate separately, see page 1.15 쮿 Please order base/plinth separately, see page 1.16 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.19 01004152 ServicePLUS see page 1.26 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.13 Cabinets – Varistar Electronics VARISTAR IP 55 쮿 With glazed or steel front door 쮿 Doors with 3-point locking and screw-fixed side panels 쮿 Type of protection IP 55 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 4 1 1 5 6 7 1 2 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, zinc-plated, powder-coated, RAL 7021, with all around rubber seals Adjustable foot, assembled Flat top cover, St, RAL 7021 Front door, St or glazed, RAL 7035, 180° hinge, 3-point locking, lever handle Rear panel, screw fixed, St, RAL 7035 Side panel, screw fixed, St, RAL 7035 Base plate, multi-piece, with cover plate, St, RAL 7021, with gasket 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01005006 Height Height H Width W Depth D Description U mm mm mm 42 2000 600 600 With glazed door 42 2000 600 600 With steel door Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces Part no. 10130-021 10130-022 23130-077 23130-078 25127-995 23130-072 Note 쮿 For other dimensions and versions see ServicePLUS configuration IP 55, from page 1.39 쮿 Please order base/plinth separately, see page 1.16 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.19 01005014 ServicePLUS see page 1.26 1.14 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Lever handle for single point locking 쮿 For installation instead of key lock insert 쮿 To open press push-button 쮿 DIN profile half cylinder retrofittable Delivery comprises Item 1 2 Qty 1 1 Description Lever handle for single point locking Assembly kit Order Information Description Lever handle for single point locking DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys 01005016 Part no. 23130-067 25127-995 Note 쮿 Other locks such as ASSA, KABA or RONIS available on request Base plate, multi-piece 쮿 The multi-piece base plate is open at the rear 쮿 The opening may be completed – with a filter mat – with a brush strip for the cable entry – with a cover plate Delivery comprises (kit) Item 1 5 Qty 1 1 Description Multi-piece base plate, St, 1.5 mm, RAL 7021 Assembly kit Order Information 01004050 1: Base plate, multi-piece; 2: Cover plate; 3: Brush strip; 4: Filter kit Width Depth mm mm 600 600 600 800 Item 2 Cover plate for base plate, multi-piece for 600 mm wide base plate, 200 mm deep, incl. assembly kit, 1 piece Item 3 Brush strip for base plate for 600 mm width base plate, 200 mm deep, incl. assembly kit, 1 piece Item 4 Filter mat white, class M1 in accordance with EN 799-G3, for 600 mm wide base plate, 200 mm deep, incl. assembly kit, 1 piece Part no. 23130-001 23130-002 23130-076 23130-074 23130-075 Note 쮿 Is assembled from inside 쮿 Please order cover plate, brush strip or filter mat separately SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.15 Cabinets – Varistar Electronics Stationary base 쮿 Static load-carrying capacity 1000 kg 쮿 Removable covers allow cable entry from all sides 쮿 Cannot be used in conjunction with castors 쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm 쮿 Versions – Front/rear trim perforated – Front/rear trim solid Delivery comprises (kit) 2a H 2b 1 2b 2a W D = cabinet depth Item 1 2a 2b 3 Qty 2 2 2 1 Description Support with feet, St, 3 mm Solid trim, St, 1.5 mm, RAL 7021 Perforated trim, St, 1.5 mm, RAL 7021 Assembly kit Order Information D 4 01004110 01004053 For cabinet width W Front/rear trim mm 600 perforated 600 plain Item 4 Side trim height 100 mm, depth 600 mm, PU 2 pieces Item 4 Side trim height 100 mm, depth 800 mm, PU 2 pieces Part no. 23130-187 23130-387 23130-169 23130-170 Note 쮿 Please order side trims (item 4) separately Base/plinth, mobile 쮿 Load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg 쮿 Plinth height H = 100 mm, with feet adjustable from 126 to 134 mm Delivery comprises Item 1 2 3 4 Qty 1 4 4 1 Description Frame, St, 3 mm, RAL 7021, with adjustable feet Trim, St, 1.5 mm, RAL 7021 Castor Assembly kit Order Information For cabinet width mm 600 600 For cabinet depth mm 600 800 Part no. 23130-208 23130-209 010041110 1006095 1.16 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics Mounting plate 쮿 For mounting electrical components and sub-assemblies incl. cabling 쮿 Mounting pitch 25 mm in depth and 50 mm in height for partial-height mounting 쮿 Depth members are required for partial-height mounting 쮿 Static load – 450 kg at full height, mounted to rear – 600 kg at full height, mounted to rear, with additional strengthening brackets Delivery comprises Item 1 2 Qty 1 1 Description Mounting plate, St, 3 mm, zinc-plated Assembly kit Order Information Full height SCHROFF.PENTAIR.CO.UK 010080520 1008053 For partial-height mounting For cabinet height Width mm mm 1200 for partial-height mounting 600 1800 600 2000 600 Strengthening bracket for mounting plate PU 2 pieces Depth member St, 2 mm, for cabinet depth 600 mm, 2 pieces Depth member St, 2 mm, for cabinet depth 800 mm, 2 pieces Part no. 23130-413 23130-405 23130-407 23130-418 23130-081 23130-082 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.17 Cabinets – Varistar Electronics 19" swing frame 쮿 Can accommodate 19" chassis and 19" subracks 2 쮿 For full height or partial-height mounting 쮿 Pivot point can be selected right or left 쮿 Load-carrying capacity 150 kg h2 h1 Delivery includes (kit) 1 ax. Tm Qty 1 2 2 2 1 Description Swing frame, St, 2 mm, RAL 7021 Support bar, St, 3 mm, RAL 7021 Square lock, 8 mm, incl. 2 keys 120° hinge Assembly kit Order Information 4 3 01005055 Item 1 2 3 4 5 01005059 Swing frame stop For cabinet height Height h1 mm U 900 for partial-height mounting 16 1200 for partial-height mounting 24 1400 for partial-height mounting 29 1600 for partial-height mounting 33 1800 38 2000 42 2200 47 Accessories Swing frame stop max. swing angle 120°, St, zinc-plated, 1 piece Security lock to replace the square lock, PU 1 lock incl. 2 keys Spare key for security lock, 1 piece Height h2 U 12 21 25 30 34 39 43 Part no. 21130-740 21130-741 21130-742 21130-743 21130-744 21130-745 21130-746 23130-158 60113-267 60220-003 Note 쮿 19" swing frames can be assembled: – Directly on the cabinet frame – In 50 mm increments by aid of depth members (depthadjustable) 쮿 For partial-height mounting, depth members are necessary, see page 1.24 01005061 Security lock 41001517 1.18 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics 19" panel/slide mount with universal pitch (EIA) 쮿 Assembly in 600 mm wide cabinets directly on the frame 쮿 Depth-adjustable in 25 mm increments 쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1) Delivery comprises 46 5 44,45 44.45 12,75 15,9 65,1 2 76 25 25 49,5 010041120 1004131 Standard assembly dimension xr = xf = 50 mm Qty 2 2 1 Description 19" panel/slide mount, St, 1.75 mm, finish AlZn, RAL 7035 or RAL 7021 Assembly kit, incl. GND/earthing Order Information 9,6 42,5 Item 1 01005088 For cabinet Usable Length AlZn RAL 7035 height height mm U mm Part no. Part no. Partialheight 8 395 23130-037 23130-027 mounting Partialheight 12 545 23130-038 23130-028 mounting Partialheight 16 745 23130-039 23130-029 mounting Partialheight 20 895 23130-040 23130-030 mounting Partialheight 24 1095 23130-031 23130-021 mounting Partialheight 29 1295 23130-032 23130-022 mounting Partialheight 33 1495 23130-033 23130-023 mounting 1800 38 1695 23130-034 23130-024 2000 42 1895 23130-035 23130-025 Dimensioning strip for 19" panel mounts, paper, white, serial numbered from 1 ... 47 U, PU 4 pieces RAL 7021 Part no. 23130-017 23130-018 23130-019 23130-020 23130-011 23130-012 23130-013 23130-014 23130-015 25127-997 Note 쮿 For 19" partial-height mounting depth members are necessary 쮿 Metric panel/slide mounts available on request 19" assembly kit, M6 쮿 For front panels, distribution fields and other components Delivery comprises Item 1 2 3 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated Order Information Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Qty/PU 50 100 Part no. 21101-809 21101-810 sc128 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.19 Cabinets – Varistar Electronics Slide rails 쮿 For assembly on 19" panel/slide mounts 쮿 Assembly in 1 U increments (snap-in, bolt-on) 쮿 Wide support surface (48 mm) 쮿 2 versions – Static load-carrying capacity 25 kg per pair – Static load-carrying capacity 100 kg per pair Delivery comprises 01004056 Item 1 Qty see Order information 2 1 Description Slide rail, AlZn, 1.5 mm (static load-carrying capacity 25 kg), or 2.5 mm (static load-carrying capacity 100 kg), zinc-plated Assembly kit incl. GND/earthing Order Information Static load carrying capacity 25 kg For cabinet depth D mm 600 600 800 800 xf c Length L Qty/PU mm 50 50 50 50 mm 500 500 700 700 mm 456 456 656 656 2 10 2 10 Part no. 23130-096 23130-101 23130-097 23130-102 01005086 Static load-carrying capacity 25 kg Order Information Static load carrying capacity 100 kg For cabinet depth D mm 600 600 800 800 c Length L Qty/PU mm 50 50 50 50 mm 500 500 700 700 mm 458 458 658 658 2 10 2 10 Part no. 23130-118 23130-123 23130-119 23130-124 01004058 19” c = pitch of the 19" panel/slide mounts xf = standard dimension D = cabinet depth SCHROFF PRODUCT CATALOG E 08/2017 D c xf c - 130 Static load-carrying capacity 100 kg 1.20 xf 01004130 ELECTRONICS PROTECTION Cabinets – Varistar Electronics 19'' fixed shelf, 75 kg 쮿 Static load-carrying capacity 75 kg (150 kg with strengthening rail) 쮿 Mounting height 1 U, for mounting on four panel/slide mounts 쮿 With hammer head perforation to fix cable ties Delivery comprises Item 1 Qty 1 2 1 xr 01004066 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing c For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 495 x 442 50 500 22130-303 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf PU 1 piece D d Order Information RAL 7021 Part no. 21130-303 21130-305 23130-310 Note xf w 쮿 Cable ducting with cable ties, see page 1.25 쮿 Other sizes, see ServicePLUS, page 1.49 W c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004067 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.21 Cabinets – Varistar Electronics 19'' telescopic shelf, 30 kg 쮿 Static load-carrying capacity at full extension 30 kg 1 쮿 Mounting height 1 U, for mounting on four 19" panel/slide mounts 2 쮿 Incl. telescopic slides 쮿 Hammer head perforation to fix cable ties 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 01004068 Full depth W xr w Delivery comprises Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit Order Information D c c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 417 x 482 50 500 22130-343 800 417 x 682 50 700 22130-345 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Full depth RAL 7021 Part no. 21130-343 21130-345 23130-140 Note 쮿 Cable ducting with cable ties, see page 1.25 01004069 Order Information Shortened depth Shortened by 100 mm w For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 417 x 382 50 500 22130-342 800 417 x 582 50 700 22130-344 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR RAL 7021 Part no. 21130-342 21130-344 23130-140 Note D c xr W xf d 쮿 Cable ducting with cable ties, see page 1.25 c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly dimension 1.22 SCHROFF PRODUCT CATALOG E 08/2017 01004070 ELECTRONICS PROTECTION Cabinets – Varistar Electronics 19'' telescopic shelf, 70 kg 1 쮿 Static load-carrying capacity at full extension 70 kg 2 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 4 쮿 Incl. telescopic slides 쮿 Locking with T-bar lock possible 쮿 Hammer head perforation to fix cable ties 01004071 Full depth W 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Delivery comprises xr w Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit D c Full depth c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 600 405 x 482 50 500 22130-353 800 405 x 682 50 700 22130-355 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Order Information 01004069 c = max. pitch for 19" panel/slidemounts 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.25 w Order Information 21130-355 23130-092 23130-140 Shortened by 100 mm D For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 600 405 x 382 50 500 22130-352 800 405 x 582 50 700 22130-354 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR d c Part no. 21130-353 Note W xr Shortened depth RAL 7021 RAL 7021 Part no. 21130-352 21130-354 23130-092 23130-140 Note xf 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.25 c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004070 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.23 Cabinets – Varistar Electronics Depth member 쮿 For fitting shortened 19" panel/slide mounts and mounting plates 쮿 Cable ducting by means of cable ties and cable eye 50 Delivery comprises 121,2 25 25 100 37,5 36,5 11,5 L - 27 12 Item 1 2 Qty 2 1 Description Depth member, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information L Description 010041260 1004079 For cabinet depth mm Depth member 600 Depth member 800 Cable eye A = 38 mm, B = 25 mm, PU 25 pieces Cable eye A = 47 mm, B = 50 mm, PU 25 pieces Part no. 23130-081 23130-082 21101-151 21101-150 쮿 Cable ducting with cable ties, see page 1.25 coa43697 Cable eye C-profile for the cabinet depth 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, AlZn Assembly kit incl. GND/earthing Order Information Cable retention rail and cable shell mounted on C-profile 01004129 Slide nut ,5 x Ø6 15 - 11 L 50 Part no. 23130-086 23130-087 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 29,5 L 50 31,5 For cabinet depth Length L mm mm 600 460 800 660 Accessories Cable retention rail for C-rail Width 75 mm, length 39.5 mm, PU 5 piece Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 piece 쮿 Cable ties and Velcro for cable retention rail see page 1.25 75 01504054 1.24 C-profile 01004132 01006071 Cable retention rail SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Electronics C-profile for cabinet width Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 For cable ducting in rear or front area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 01006063 C-profile Slide nut For cabinet width Length mm mm 600 550 800 750 Accessories Cable retention rail for C-rail Width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces Part no. 23130-333 23130-334 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 쮿 Cable ties and Velcro for cable retention rail see page 1.25 75 01006071 01006064 Cable retention rail 01504054 Cable ties, Velcro Main CataloguePart num ber in bold face type: ready for despatch wi thin 2 working daysPart num ber in normal type: ready for despatch within 10 working days 쮿 Fixing materials kit for cable ducting Order Information Description Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces Cable tie SCHROFF.PENTAIR.CO.UK 01005078 Velcro Part no. 20118-351 20118-352 20118-353 20118-624 01005079 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.25 Cabinets – Varistar Elektronics ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.27 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drilling, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts Varistar Elektronics ServicePLUS 1.26 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 ServicePLUS: configuration and assembly 쮿 Dimensions: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 300, 600 and 800 mm Page 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) Frames, side-by-side mounting kits, adjustable feet, castors 1.28 Side panels, rear panels 1.29 Decorative frames, glazed 1.30 doors 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Steel doors 1.31 Double doors 1.32 Flat top covers, lifting eyes 1.33 Flat top cover assemblies 1.34 with cut-out zones Fan top covers 1.35 Bases/plinths 1.36 Connecting plates for short doors/rear panels 1.37 Interior configuration for IP 20 and IP 55 19" panel/slide mounts 1.44 ETSI panel/slide mounts 1.45 Swing frames 1.46 Mounting plate, stationary 1.47 shelves, 75 kg 01004077 Example configuration (here: row 10) Qty 1 1 2 1 1 1 .. SCHROFF.PENTAIR.CO.UK Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece Side panel with quick-release fastener, RAL 7021, PU 2 pieces Safety lock for side panel, PU 4 pieces Rear panel, screw-fixed, RAL 7021, 1 piece Glazed door with single point locking, RAL 7021, IP 20, 1 piece Adjustable feet, PU 4 pieces .......... Order no. 20130-019/05 21130-051/05 23130-132/05 21130-069/05 21130-129/05 23130-079/05 .......... Telescopic shelves, 70 kg 1.48 19" shelves 1 U, fixed 75 kg, telescopic 30 kg 1.49 19" telescopic shelf, 2 U, 70 kg 1.50 Slide rails, depth members 1.51 Cable ductings 1.52 Cable ties, Velcro 1.53 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.27 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Frames, side-by-side mounting kits, adjustable feet, castors Order Information Frame Slim-Line 400 kg Heavy-Duty 800 kg Side-by-side mounting kit IP 20 Side-by-side mounting kit IP 55 (with gasketing) Adjustable feet Castors With 2 jacking feet With adjustable feet Completely in RAL 7021 (black grey) 01004078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004117 01004081 01004082 01004156 for the frame, for the frame, for the frame, side-by-side side-by-side static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: mounting bracket mounting bracket carrying capacity: carrying capacity: carrying capacity: (4 pieces), St, (4 pieces), St; 800 kg, 400 kg, 400 kg, 400 kg, 1000 kg, RAL 7021, incl. St, 1.5 mm, zinc- St, 1.5 mm, zinc- RAL 7021, not in cannot be used cannot be used cannot be used gasketing to combination with plated, with plated, with with base/plinth with base/plinth with base/plinth cover the gap decorative frame central GND/ central GND/ between two earthing point; earthing point; racks; not in please order please order combination with adjustable feet or adjustable feet or decorative frame castors castors separately separately 1 piece 1 piece PU 1 kit PU 1 kit PU 4 pieces PU 4 pieces PU 4 pieces assembled assembled supplied loose RAL 7021 RAL 7021 RAL 7021 20130-005 20130-055 20130-006 20130-056 20130-009 20130-059 20130-010 20130-013 20130-060 20130-063 20130-014 20130-064 20130-015 20130-017 20130-065 – 20130-018 20130-068 20130-019 20130-022 20130-069 20130-072 20130-023 20130-073 20130-026 20130-027 20130-077 20130-028 20130-078 20130-032 20130-082 – supplied loose assembled 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-061 23130-062 23130-062 23130-079 23130-079 23130-077 23130-077 23130-078 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-061 23130-062 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.28 RAL 7021 RAL 7021 RAL 7021 29 1400 600 600 20130-005 20130-055 23130-061 23130-062 29 1400 600 800 20130-006 20130-056 33 1600 600 600 20130-009 20130-059 23130-061 23130-062 33 1600 600 800 20130-010 20130-060 38 1800 600 600 20130-013 20130-063 23130-061 23130-062 38 1800 600 800 20130-014 20130-064 38 1800 800 600 20130-015 20130-065 23130-061 23130-062 42 2000 600 300 – 20130-017 23130-061 23130-062 42 2000 600 600 20130-018 20130-068 23130-061 23130-062 42 2000 600 800 20130-019 20130-069 42 2000 800 600 20130-022 20130-072 23130-061 23130-062 42 2000 800 800 20130-023 20130-073 47 2200 600 300 20130-026 – 23130-061 23130-062 47 2200 600 600 20130-027 20130-077 23130-061 23130-062 47 2200 600 800 20130-028 20130-078 47 2200 800 800 20130-032 20130-082 23130-061 23130-062 Other dimensions and configurations online (with basket) at www.schroff.biz/conf SCHROFF PRODUCT CATALOG E 08/2017 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Side panels, rear panels Order Information Side panel With quick release fastener Screw-fixed side panel Lock Rear panel With quick release fastener Screw-fixed rear panel Lock Completely in RAL 7021 (black grey) 01004084 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004072 for quick-release St, 1 mm, incl. fasteners of one GND/earthing, side panel; please order lock 4 locks sufficient separately for 2 side panels 01004083 St, 1 mm, incl. GND/earthing 01004087 01004072 for quick-release St, 1 mm, incl. fasteners of rear GND/earthing, panel please order lock separately 01004085 St, 1 mm, incl. GND/earthing Cabinet dimensions Height No. U mm Width Depth PU 2 pieces PU 4 pieces PU 2 pieces 1 piece PU 2 pieces 1 piece mm mm assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-043 21130-003 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 21130-044 21130-045 21130-046 21130-047 21130-048 21130-047 23130-132 23130-132 23130-132 21130-004 21130-005 21130-006 21130-007 RAL 7021 21130-093 23130-133 21130-063 21130-095 23130-133 21130-065 21130-097 23130-133 21130-067 23130-132 21130-008 21130-007 21130-098 23130-133 21130-068 21130-049 23130-132 21130-009 21130-099 23130-133 21130-069 21130-050 21130-051 23130-132 21130-010 21130-011 21130-099 23130-133 21130-069 21130-100 23130-133 21130-070 21130-101 23130-133 21130-071 21130-101 23130-133 21130-071 21130-102 23130-133 21130-072 21130-050 21130-051 21130-054 21130-055 21130-056 21130-056 23130-132 23130-132 23130-132 23130-132 21130-010 21130-011 21130-014 21130-015 21130-016 21130-016 RAL 7035 RAL 7035 22130-043 22130-003 22130-044 22130-045 22130-046 22130-047 22130-048 22130-047 23130-132 23130-132 23130-132 22130-004 22130-005 22130-006 22130-007 RAL 7035 RAL 7035 22130-093 23130-133 22130-063 22130-095 23130-133 22130-065 22130-097 23130-133 22130-067 23130-132 22130-008 22130-007 22130-098 23130-133 22130-068 22130-049 23130-132 22130-009 22130-099 23130-133 22130-069 22130-050 22130-051 23130-132 22130-010 22130-011 22130-099 23130-133 22130-069 22130-100 23130-133 22130-070 22130-101 23130-133 22130-071 22130-101 23130-133 22130-071 22130-102 23130-133 22130-072 22130-050 22130-051 22130-054 22130-055 22130-056 22130-056 23130-132 23130-132 23130-132 23130-132 22130-010 22130-011 22130-014 22130-015 22130-016 22130-016 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.29 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Decorative frames, glazed doors Order Information Deco frame Deco frame Glazed door Adapter bracket Single point locking Glazed door Lever handle 3-point locking DIN profile half cylinder Completely in RAL 7021 (black grey) 01004086 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Al, 19" plane integrated, front open, incl. GND/earthing, no door can be fitted 01004160 St, 2 mm, for deco frame, for assembly of slide rails and shelves 01004088 St, 1.5 mm, Sekurit glass 6 mm, opening angle 180°, lock cover, incl. GND/ earthing 01004147 with push button for doors with single point locking 01004091 St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lever handle with push button, incl. GND/ earthing 01004148 for lever handle, common locking Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.30 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece PU 1 pair 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-232 23130-221 21130-123 23130-067 21130-183 25127-995 21130-233 23130-222 21130-125 23130-067 21130-185 25127-995 21130-234 23130-223 21130-127 23130-067 21130-187 25127-995 RAL 7021 – – 21130-128 23130-067 21130-188 25127-995 21130-235 23130-224 21130-129 23130-067 21130-189 25127-995 21130-235 23130-224 21130-129 23130-067 21130-189 25127-995 – – 21130-130 23130-067 21130-190 25127-995 21130-236 23130-225 21130-131 23130-067 21130-191 25127-995 21130-236 23130-225 21130-131 23130-067 21130-191 25127-995 – – 21130-132 23130-067 21130-192 25127-995 RAL 7035 RAL 7035 RAL 7035 22130-232 23130-231 22130-123 23130-067 22130-183 25127-995 22130-233 23130-232 22130-125 23130-067 22130-185 25127-995 22130-234 23130-233 22130-127 23130-067 22130-187 25127-995 RAL 7035 – – 22130-128 23130-067 22130-188 25127-995 22130-235 23130-234 22130-129 23130-067 22130-189 25127-995 22130-235 23130-234 22130-129 23130-067 22130-189 25127-995 – – 22130-130 23130-067 22130-190 25127-995 22130-236 23130-235 22130-131 23130-067 22130-191 25127-995 22130-236 23130-235 22130-131 23130-067 22130-191 25127-995 – – 22130-132 23130-067 22130-192 25127-995 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Steel doors Order Information Steel door, single point locking Plain Solid, inner surface with mounting frame Perforated Lever handle Steel door 3-point locking DIN profile half cylinder Completely in RAL 7021 (black grey) 01004089 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) St, 1 mm, opening angle 180°, key, incl. GND/ earthing 01008067 St, 1.5 mm, opening angle 180°, lock cover incl. GND/ earthing, designed to carry extensive cutouts and assemblies 01004090 St, 1.5 mm, opening angle 180°, key, incl. GND/ earthing 01004147 with push button for doors with single point locking 01008085 St, 1.5 mm, opening angle 180°, inner side with mounting frame, lever handle with built-in push button, incl. GND/earthing 01004148 for lever handle, common locking Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-108 21130-568 21130-138 23130-067 21130-153 25127-995 21130-110 21130-570 21130-140 23130-067 21130-155 25127-995 21130-112 21130-572 21130-142 23130-067 21130-157 25127-995 21130-113 21130-573 21130-143 23130-067 21130-158 25127-995 21130-114 21130-574 21130-144 23130-067 21130-159 25127-995 21130-114 21130-574 21130-144 23130-067 21130-159 25127-995 21130-115 21130-575 21130-145 23130-067 21130-160 25127-995 21130-116 21130-576 21130-146 23130-067 21130-161 25127-995 21130-116 21130-576 21130-146 23130-067 21130-161 25127-995 21130-117 21130-577 21130-147 23130-067 21130-162 25127-995 RAL 7035 RAL 7035 RAL 7035 22130-108 22130-568 22130-138 23130-067 22130-153 25127-995 22130-110 22130-570 22130-140 23130-067 22130-155 25127-995 22130-112 22130-572 22130-142 23130-067 22130-157 25127-995 22130-113 22130-573 22130-143 23130-067 22130-158 25127-995 22130-114 22130-574 22130-144 23130-067 22130-159 25127-995 22130-114 22130-574 22130-144 23130-067 22130-159 25127-995 22130-115 22130-575 22130-145 23130-067 22130-160 25127-995 22130-116 22130-576 22130-146 23130-067 22130-161 25127-995 22130-116 22130-576 22130-146 23130-067 22130-161 25127-995 22130-117 22130-577 22130-147 23130-067 22130-162 25127-995 RAL 7021 RAL 7035 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.31 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Double doors Order Information Double door, 3-point locking Glazed Perforated DIN profile half cylinder Plain Completely in RAL 7021 (black grey) 01005065 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01005066 01005064 St, 1.5 mm, St, 1.5 mm, frame, St, opening angle opening angle 1.5 mm, 180°, 180°, Securit glass, lever handle with lever handle with 6 mm, push button, incl. push button, incl. opening angle GND/earthing GND/earthing 180°, lever handle with push button, incl. GND/earthing 01004148 for lever handle, common locking Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece 1 piece 1 piece 1 piece assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 21130-454 21130-213 21130-486 25127-995 21130-456 21130-215 21130-488 25127-995 21130-458 21130-217 21130-490 25127-995 21130-459 21130-218 21130-491 25127-995 21130-460 21130-219 21130-492 25127-995 21130-460 21130-219 21130-492 25127-995 21130-461 21130-220 21130-493 25127-995 21130-462 21130-221 21130-494 25127-995 21130-462 21130-221 21130-494 25127-995 21130-463 21130-222 21130-495 25127-995 RAL 7035 RAL 7035 RAL 7035 22130-454 22130-213 22130-486 25127-995 22130-456 22130-215 22130-488 25127-995 22130-458 22130-217 22130-490 25127-995 22130-459 22130-218 22130-491 25127-995 22130-460 22130-219 22130-492 25127-995 22130-460 22130-219 22130-492 25127-995 22130-461 22130-220 22130-493 25127-995 22130-462 22130-221 22130-494 25127-995 22130-462 22130-221 22130-494 25127-995 22130-463 22130-222 22130-495 25127-995 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Flat top covers, lifting eyes Order Information Flat top cover Plain flush top cover Perforated Spacer Lifting eye Spacer Lifting eye 10 Completely in RAL 7021 (black grey) M12 01004096 St, 1.5 mm, incl. GND/ earthing Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004097 M12 01004100 01004099 01004100 St, 1.5 mm, fully perforated, incl. GND/ earthing for top cover, applications and load in accordance with DIN 582 St, zinc-plated, for raising a top cover by 10 mm for raised flat top cover, application and static loadcarrying capacity in accordance with DIN 582 Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece PU 4 pieces PU 4 pieces PU 4 pieces assembled assembled assembled assembled assembled RAL 7021 RAL 7021 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 21130-242 21130-262 21130-243 21130-263 21130-242 21130-243 21130-262 21130-263 21130-242 21130-262 21130-243 21130-246 21130-263 21130-266 23130-072 23130-068 23130-085 21130-241 21130-261 23130-072 23130-068 23130-085 21130-242 21130-243 21130-262 21130-263 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 21130-246 21130-266 21130-247 21130-241 21130-267 21130-261 21130-242 21130-262 21130-243 21130-247 21130-263 21130-267 RAL 7021 RAL 7021 21130-242 21130-262 21130-243 21130-263 21130-242 21130-243 21130-262 21130-263 21130-242 21130-262 21130-243 21130-246 21130-263 21130-266 23130-072 23130-068 23130-085 21130-241 21130-261 23130-072 23130-068 23130-085 21130-242 21130-243 21130-262 21130-263 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 23130-072 23130-068 23130-085 21130-246 21130-266 21130-247 21130-241 21130-267 21130-261 21130-242 21130-262 21130-243 21130-247 21130-263 21130-267 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.33 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Flat top cover assemblies with cut-out zones Order Information Flat top cover with cut-out zones Top cover assemblies Brush strip Fan insert Thermostat Top cover plate, perforated Edge protection Lifting eye 30 20 40 10 50 0 60 °C Completely in RAL 7021 (black grey) 1000 mm 300 mm M12 300 mm 01004098 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01006092 01004102 W 01108052 D 01009056 230 VAC, nylon, black, one with mains cable St, 1.5 mm, 6 mm St, 1.5 mm, hole diameter, brush strip covers with three fans, 230 VAC incl. GND/ 3 incl. GND/ (SCHUKO/UTE earthing, number a lateral cut-out, 410 m /h, earthing two brush strips plug/ of cut-outs and completely cover a center wired, connecting IEC 60320 C13 dimension cut-out socket), drawings cable IEC 320 adjustment range see page 0 ... 60°C 1.9 41003065 01004100 PVC, 3 m, black, for open cut-out zones for top cover, applications and load in accordance with DIN 582 Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.34 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece PU 2 pieces 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled enclosed loose assembled RAL 7021 RAL 7021 21130-252 21130-253 21130-252 21130-253 21130-252 21130-253 21130-256 RAL 7021 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – – 21130-252 21130-253 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 21130-256 21130-257 – 21130-252 21130-253 21130-257 RAL 7021 21130-252 21130-253 21130-252 21130-253 21130-252 21130-253 21130-256 RAL 7021 RAL 7021 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – – 21130-252 21130-253 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 – – – – – – 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 23130-069 23130-070 20118-750 23130-071 28127-281 23130-072 21130-256 21130-257 – 21130-252 21130-253 21130-257 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Fan top covers Order Information Fan top cover Top cover for 6 fans Replacement fan for fan top Thermostat Speed control Lifting eye 30 20 40 10 50 0 60 °C Completely in RAL 7021 (black grey) 1000 mm 300 mm 300 mm 01005060 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK kta44844 01108052 01105055 01005085 fully wired, for fan top cover, St, 1.5 mm, raised fan with grille for with mains cable 90 ... 264 VAC, applications and top assembly, 230 VAC cover, static load230 VAC, (SCHUKO/UTE input SCHUKO/UTE 3 axial fans, carrying capacity plug/ plug, 230 VAC, 38x119x119 mm, 3 in accordance incl. cabling andG for 50 Hz, 162 m / IEC 60320 C13 outlet IEC 60320 C1 with DIN 582 socket), 3 socket; external ND/earthing, h adjustment range NTC sensor 1.5 m connecting cable 0 ... 60°C 2.5 m, SCHUKO/ IEC60320 C12 plug 1 piece 1 piece 1 piece 1 piece PU 4 pieces assembled assembled assembled assembled assembled 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 RAL 7021 21130-400 21130-401 21130-400 21130-401 21130-400 21130-401 21130-402 23130-165 20118-750 60715-005 23130-090 – – – – – 21130-400 21130-401 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 – – – – 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 21130-402 21130-403 – 21130-400 21130-401 21130-403 RAL 7021 21130-400 21130-401 21130-400 21130-401 21130-400 21130-401 21130-402 23130-165 20118-750 60715-005 23130-090 – – – – – 21130-400 21130-401 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 – – – – 23130-165 20118-750 60715-005 23130-090 23130-165 20118-750 60715-005 23130-090 21130-402 21130-403 – 21130-400 21130-401 21130-403 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.35 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Bases/plinths Order Information Base plate Base plate, multipiece Brush strip Base/plinth Dust filter set Cover plate Base/plinth, ventilated Side covers Base/plinth, mobile Completely in RAL 7021 (black grey) 01004104 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1.36 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004105 01004059 01004106 01004110 support with adjustable feet and 2 trims, perforated, static load-carrying capacity 1000 kg; please order side trims separately 01004053 St, 1.5 mm 01004111 support, St, 3 mm, trim, St, 1.5 mm, static load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg nylon, black 1 piece 1 piece 1 piece PU 1 kit PU 1 pair 1 piece assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 RAL 7021 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-074 filter mat, white, class M1, in accordance with EN 799-G3 St, 1.5 mm, please order gasket IP55 separately St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing ; dimension drawings see page 1.9 1 piece 23130-075 23130-076 23130-187 23130-074 23130-075 23130-076 23130-187 23130-074 23130-075 23130-076 23130-187 23130-134 23130-074 23130-135 23130-075 23130-136 23130-194 23130-187 – 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-074 23130-075 – 23130-187 23130-074 23130-075 23130-076 23130-187 23130-006 23130-134 23130-135 23130-136 23130-194 RAL 7021 RAL 7021 RAL 7021 RAL 7021 23130-002 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-002 23130-006 SCHROFF PRODUCT CATALOG E 08/2017 23130-074 23130-075 23130-076 23130-187 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-208 23130-170 23130-209 23130-169 23130-166 23130-212 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-170 23130-213 23130-166 23130-169 23130-208 – – 23130-170 23130-209 23130-170 23130-213 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-170 23130-208 23130-209 23130-074 23130-075 23130-076 23130-187 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-074 23130-075 – 23130-187 23130-166 – 23130-169 23130-170 23130-208 23130-209 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-074 23130-075 – 23130-187 23130-074 23130-075 23130-076 23130-187 23130-134 23130-135 23130-136 23130-194 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-169 23130-212 23130-170 23130-166 23130-213 23130-169 23130-208 23130-170 23130-170 23130-209 23130-213 – ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 20 Connecting plates for short doors/rear panels Order Information Dimensioning connecting plate door/rear panel Connecting plate for door and rear panel Plain With brush strip Assembly kit Other VARISTAR interior mounting parts Completely in RAL 7021 (black grey) 01005071 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Height Width mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK door and rear panel must be selected 400 mm shorter than the cabinet height; cannot be used with double door 01005063 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel 01005069 St, 1 mm, assembly also possible at top, height 400 mm, please order assembly kit separately in conjunction with rear panel 01004066 01004056 only required if rear panel with quick-release fastener is assembled above the connecting plate 1 piece 1 piece PU 1 kit assembled assembled assembled RAL 7021 RAL 7021 21130-472 21130-473 21130-478 21130-479 rack shelves, 19" shelves, slide rails, cable ducting 23130-164 23130-164 from page 1.44 from page 1.44 RAL 7035 RAL 7035 22130-472 22130-478 23130-164 22130-473 22130-479 23130-164 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.37 Cabinets – Varistar Elektronics ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.39 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drilling, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.38 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 ServicePLUS: configuration and assembly 쮿 Dimensions: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 300, 600 and 800 mm Page 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days Frames, side-by-side mounting kits, adjustable feet, castors 1.40 Side panels, rear panels, doors, top covers 1.41 Flat top covers, lifting eyes 1.42 Connecting plates for short doors/rear panels 1.43 Interior configuration for IP 20 and IP 55 19" panel/slide mounts 1.44 ETSI panel/slide mounts 1.45 Swing frames 1.46 Mounting plates, stationary shelves, 75 kg 1.47 Telescopic shelves, 70 kg 1.48 19" shelves 1 U, fixed 75 kg, telescopic 30 kg 1.49 19" telescopic shelves, 2 U, 70 kg 1.50 Slide rails, depth members 1.51 Cable ductings 1.52 Cable ties, Velcro 1.53 01004077 Example configuration (here: row 10) Qty 1 1 1 1 1 1 .. Description Frame Slim-Line, height 2000 mm, width 600 mm, depth 800 mm, 1 piece IP 55 gasketing kit, 1 piece Side panel, screw-fixed, RAL 7021, PU 2 pieces Rear panel, screw-fixed, RAL 7021, 1 piece Glazed door with 3-point locking, RAL 7021, IP 55, 1 piece Adjustable feet, PU 4 pieces .......... SCHROFF.PENTAIR.CO.UK Part no. 20130-019/05 23130-064/05 21130-011/05 21130-069/05 21130-189/05 23130-079/05 .......... Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.39 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Frames, side-by-side mounting kits, adjustable feet, castors Order Information Frame Slim-Line 400 kg Heavy-Duty 800 kg Gasket kit IP 55 Side-by-side mounting kit IP 55 (with gasketing) Adjustable feet Castors with 2 jacking feet with adjustable feet Completely in RAL 7021 (black grey) 01004078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004157 01004120 01004081 01004082 01004158 for the frame, for the frame, for the frame, side-to-side seals are glued to static loadstatic loadstatic loadstatic loadstatic loadcarrying capacity: carrying capacity: the frame, so that mounting bracket carrying capacity: carrying capacity: carrying capacity: (4 pieces), St, all cladding parts 800 kg, 400 kg, 400 kg, 400 kg, 1000 kg, RAL 7021, incl. conform to St, 1.5 mm, zinc- St, 1.5 mm, zinccannot be used cannot be used cannot be used gasketing to protection type plated, with plated, with with base/plinth with base/plinth with base/plinth cover the gap IP 55 central GND/ central GND/ between two earthing earthing racks; cannot be point; please point; please used with order adjustable order adjustable decorative frame feet or castors feet or castors separately separately 1 piece 1 piece PU 1 kit PU 1 kit PU 4 pieces PU 4 pieces PU 4 pieces assembled assembled RAL 7021 RAL 7021 20130-005 20130-055 20130-006 20130-056 20130-009 20130-059 20130-010 20130-013 20130-060 20130-063 20130-014 20130-064 20130-015 20130-017 20130-065 – 20130-018 20130-068 20130-019 20130-022 20130-069 20130-072 20130-023 20130-073 20130-026 20130-027 20130-077 20130-028 20130-078 20130-032 20130-082 – assembled supplied loose assembled 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-064 23130-062 23130-062 23130-079 23130-079 23130-077 23130-077 23130-078 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-064 23130-062 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.40 RAL 7021 RAL 7021 29 1400 600 600 20130-005 20130-055 23130-064 23130-062 29 1400 600 800 20130-006 20130-056 33 1600 600 600 20130-009 20130-059 23130-064 23130-062 33 1600 600 800 20130-010 20130-060 38 1800 600 600 20130-013 20130-063 23130-064 23130-062 38 1800 600 800 20130-014 20130-064 38 1800 800 600 20130-015 20130-065 23130-064 23130-062 42 2000 600 300 – 20130-017 23130-064 23130-062 42 2000 600 600 20130-018 20130-068 23130-064 23130-062 42 2000 600 800 20130-019 20130-069 42 2000 800 600 20130-022 20130-072 23130-064 23130-062 42 2000 800 800 20130-023 20130-073 47 2200 600 300 20130-026 – 23130-064 23130-062 47 2200 600 600 20130-027 20130-077 23130-064 23130-062 47 2200 600 800 20130-028 20130-078 47 2200 800 800 20130-032 20130-082 23130-064 23130-062 Other dimensions and configurations online (with basket) at www.schroff.biz/conf SCHROFF PRODUCT CATALOG E 08/2017 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 23130-079 23130-077 23130-078 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Side panels, rear panels, doors, top covers Order Information Screw-fixed side panel Screw-fixed rear panel Glazed door 3-point locking Steel door 3-point locking DIN profile half cylinder Plain flush top cover Flat top cover Lifting eye Completely in RAL 7021 (black grey) M12 01004083 St, 1 mm, incl. GND/earthing 01004085 St, 1 mm, incl. GND/earthing Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004091 St, 1.5 mm, Sekurit glass, 6 mm, opening angle 180°, lever handle with push button, incl. GND/ earthing Cabinet dimensions Height No. U mm 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 01004096 01004100 St, 1.5 mm, incl. GND/earthing for top cover, applications and load in compliance with DIN 582 Depth PU 2 pieces 1 piece 1 piece 1 piece 1 piece 1 piece PU 4 pieces mm mm assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 RAL 7021 RAL 7021 21130-063 21130-183 21130-153 25127-995 21130-065 21130-185 21130-155 25127-995 21130-067 21130-187 21130-157 25127-995 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 01004148 for lever handle, common locking Width Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 01008085 St, 1.5 mm, opening angle 180°, inner side with mounting frame, lever handle with built-in push button, incl. GND/ earthing 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 21130-003 21130-004 21130-005 21130-006 21130-007 21130-008 21130-007 21130-009 21130-010 21130-011 21130-010 21130-011 21130-014 21130-015 21130-016 21130-016 RAL 7035 22130-003 22130-004 22130-005 22130-006 22130-007 22130-008 22130-007 22130-009 22130-010 22130-011 22130-010 22130-011 22130-014 22130-015 22130-016 22130-016 RAL 7021 21130-242 21130-243 21130-242 21130-243 21130-242 23130-072 23130-072 23130-072 21130-068 21130-188 21130-158 25127-995 21130-243 21130-246 21130-069 21130-189 21130-159 25127-995 21130-241 23130-072 21130-242 21130-243 23130-072 21130-069 21130-189 21130-159 25127-995 21130-070 21130-190 21130-160 25127-995 21130-071 21130-191 21130-161 25127-995 21130-071 21130-191 21130-161 25127-995 21130-072 21130-192 21130-162 25127-995 RAL 7035 RAL 7035 RAL 7035 21130-246 21130-247 21130-241 21130-242 21130-243 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 RAL 7021 22130-063 22130-183 22130-153 25127-995 22130-065 22130-185 22130-155 25127-995 22130-067 22130-187 22130-157 25127-995 21130-242 21130-243 21130-242 21130-243 21130-242 23130-072 23130-072 23130-072 22130-068 22130-188 22130-158 25127-995 21130-243 21130-246 22130-069 22130-189 22130-159 25127-995 21130-241 23130-072 21130-242 21130-243 23130-072 22130-069 22130-189 22130-159 25127-995 22130-070 22130-190 22130-160 25127-995 22130-071 22130-191 22130-161 25127-995 22130-071 22130-191 22130-161 25127-995 22130-072 22130-192 22130-162 25127-995 21130-246 21130-247 21130-241 21130-242 21130-243 21130-247 23130-072 23130-072 23130-072 23130-072 23130-072 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.41 Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Flat top covers, lifting eyes Order Information Base plate Base plate, multipiece Cover plate Seal IP 55 Base plate, one-piece, EMC, IP 55 Base/plinth Base/plinth, ventilated Side cover Base/plinth, mobile Completely in RAL 7021 (black grey) 01004104 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1.42 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004106 01004073 for base plate with cover 01004051 AlZn, 1.5 mm, incl. GND/ earthing, assembly from outside 01004110 support with adjustable feet and 2 trims, perforated, static load-carrying capacity 1000 kg; please order side trims separately 01004053 St, 1.5 mm 01004111 support, St, 3 mm, trim, St, 1.5 mm, static loadcarrying capacity on castors 400 kg, on adjustable feet 1000 kg St, 1.5 mm, multipiece, opening to rear 200 mm deep (no rear opening with 300 mm cabinet depth), incl. GND/ earthing, dimension drawings see page 1.9 1 piece St, 1.5 mm, please order gasket IP55 separately 1 piece 1 piece 1 piece PU 1 kit PU 1 pair 1 piece assembled assembled assembled assembled assembled assembled assembled RAL 7021 RAL 7021 AlZn RAL 7021 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-076 23130-073 23130-076 23130-073 23130-076 23130-073 23130-036 23130-073 23130-073 – 23130-076 23130-073 23130-036 23130-073 – 23130-073 23130-076 23130-073 23130-006 23130-076 23130-073 RAL 7021 RAL 7021 23130-002 23130-001 23130-002 23130-001 23130-002 23130-001 23130-002 23130-005 23130-009 23130-001 23130-002 23130-005 23130-006 23130-009 23130-001 23130-002 23130-006 SCHROFF PRODUCT CATALOG E 08/2017 23130-076 23130-073 23130-076 23130-073 23130-076 23130-073 21130-281 21130-282 21130-281 21130-282 21130-281 21130-282 21130-283 21130-285 21130-281 21130-282 21130-283 21130-284 21130-285 21130-281 21130-282 23130-187 23130-194 23130-187 23130-187 RAL 7021 21130-282 21130-281 21130-282 21130-281 23130-073 23130-073 21130-285 23130-076 23130-073 21130-281 21130-282 23130-036 23130-073 – 23130-073 23130-073 23130-194 23130-187 AlZn 21130-281 – 23130-076 23130-187 23130-194 23130-036 23130-073 23130-187 21130-284 21130-282 21130-283 23130-076 23130-187 21130-283 21130-284 21130-285 21130-281 21130-282 21130-284 23130-187 23130-187 23130-187 23130-194 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-208 23130-170 23130-209 23130-169 23130-166 23130-212 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-170 23130-213 23130-166 23130-169 23130-208 – – 23130-170 23130-209 23130-170 23130-213 RAL 7021 RAL 7021 23130-169 23130-208 23130-170 23130-209 23130-169 23130-170 23130-208 23130-209 23130-169 23130-208 23130-170 23130-169 23130-209 23130-212 23130-187 23130-166 – 23130-187 23130-169 23130-170 23130-208 23130-209 23130-194 23130-187 23130-187 23130-194 23130-169 23130-212 23130-170 23130-166 23130-213 23130-169 23130-208 23130-170 23130-170 23130-209 23130-213 – ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS VARISTAR IP 55 Connecting plates for short doors/rear panels Order Information Dimensioning connecting plate door/rear panel Connecting plate Completely in RAL 7021 (black grey) 01005071 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Height Width mm mm Completely in RAL 7021 400 400 600 800 Colour combinations 400 400 600 800 SCHROFF.PENTAIR.CO.UK 01005072 St, 1 mm, can door and rear also be fitted in panel must be upper part, selected 400 mm height 400 mm, shorter than the cabinet height; with assembly kit cannot be used with double door 1 piece assembled RAL 7021 21130-504 21130-505 RAL 7035 22130-504 22130-505 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.43 Cabinets – Varistar Elektronics ServicePLUS Interior mounting 19" panel/slide mounts Order Information 19" panel/slide mounts EIA Painted RAL 7021 AIZn 19" assembly kit M6 Adapter bracket for reduced width W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) U height identification for 19" panel/ slide mount c D Dimension Standard fitting xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width 01004112 St, 1.75 mm; reduced-width adapter bracket required for 800 mm width; depth members are required for partial-height mounting 00505050 sc128 paper strip, white, assembly kit: serial numbered item 1: screws, from 1 ... 47 H item 2: cage nuts, item 3: washers 01004128 St, 2 mm, finish AlZn, for fixing the 19" panel/slide mounts in 800 mm wide cabinets Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.44 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF PRODUCT CATALOG E 08/2017 PU 1 pair PU 1 pair PU 4 pieces PU 50 pieces PU 4 pieces assembled assembled assembled supplied loose assembled RAL 7021 AIZn 23130-012 23130-032 25127-997 21101-809 – 23130-013 23130-033 25127-997 21101-809 – 23130-014 23130-034 25127-997 21101-809 – AIZn 23130-014 23130-034 25127-997 21101-809 23130-091 23130-015 23130-035 25127-997 21101-809 – 23130-015 23130-035 25127-997 21101-809 – 23130-015 23130-035 25127-997 21101-809 23130-091 23130-016 23130-036 25127-997 21101-809 – 23130-016 23130-036 25127-997 21101-809 – 23130-016 23130-036 25127-997 21101-809 23130-091 RAL 7035 AlZn 23130-022 23130-032 25127-997 21101-809 – 23130-023 23130-033 25127-997 21101-809 – 23130-024 23130-034 25127-997 21101-809 – AlZn 23130-024 23130-034 25127-997 21101-809 23130-091 23130-025 23130-035 25127-997 21101-809 – 23130-025 23130-035 25127-997 21101-809 – 23130-025 23130-035 25127-997 21101-809 23130-091 23130-026 23130-036 25127-997 21101-809 – 23130-026 23130-036 25127-997 21101-809 – 23130-026 23130-036 25127-997 21101-809 23130-091 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting ETSI panel/slide mounts Order Information ETSI panel/slide mount Dimensions Panel/slide mount Completely in RAL 7021 (black grey) coa43693 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004114 St, 2 mm, in accordance Al-Zn finish, with ETS 300119suitable only for 3 and IEC 60917-211; Slim-Line frame; shelves available SU = 25 mm on request Cabinet dimensions Height No. U mm Width Depth mm mm Height SU Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 AIZn 50 50 60 60 68 68 68 76 76 76 76 76 84 84 84 84 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK PU 1 pair assembled 23130-052 23130-053 23130-054 23130-054 23130-055 23130-055 23130-055 23130-056 23130-056 23130-056 AlZn 50 50 60 60 68 68 68 76 76 76 76 76 84 84 84 84 23130-052 23130-053 23130-054 23130-054 23130-055 23130-055 23130-055 23130-056 23130-056 23130-056 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.45 Cabinets – Varistar Elektronics ServicePLUS Interior mounting Swing frames for cabinet width 600 mm Order Information Swing frame Stop 120° Safety lock 01005070 Height U partial height partial height 29 33 38 42 47 Spare key 01005061 01015060 St, 2 mm, RAL 7021, loadcarrying capacity: 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) St; for safety reasons a swing frame stop is recommended for swing frame, instead of square lock, incl. 2 keys 01015059 Usable height U Width mm 1 piece assembled PU 1 kit assembled 1 piece assembled PU 2 pieces supplied loose 12 600 21130-740 23130-158 60113-267 60220-003 21 600 21130-741 23130-158 60113-267 60220-003 25 30 34 39 43 600 600 600 600 600 21130-742 23130-158 60113-267 60220-003 21130-743 21130-744 23130-158 23130-158 60113-267 60113-267 60220-003 60220-003 21130-745 23130-158 60113-267 60220-003 21130-746 23130-158 60113-267 60220-003 Interior mounting Swing frames for cabinet width 800 mm Order Information Swing frame 120° Swing frame 120° Swing frame 160° Stop 120° Swing frame 160° Swing frame trim Stop 160° Asymmetrical assembly 1 1 2 2 100 200 01005070 Height U partial height partial height 29 33 38 42 47 1.46 01005061 01005070 01005061 Safety lock Symmetrical assembly 100 01005058 01005057 01015060 St; for safety reasons a swing frame stop is recommended St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 160° hinge, square locks incl. 2 keys St, swing frame stop is recommended for safety reasons St, 1.5 mm, RAL 7021, trim (item 1, width 200 mm) incl. handle (item 2) and cutout for cable eyes St, 1.5 mm, RAL 7021, trim (item 1, 2 x width 100 mm) incl. handle (item 2) and cut-out for cable eyes for swing frame, instead of square lock, incl. 2 keys PU 1 kit assembled 1 piece assembled PU 1 kit assembled 1 piece assembled PU 2 pieces assembled 1 piece assembled Usable height U mm St, 2 mm, RAL 7021, loadcarrying capacity 150 kg, 120° hinge, square locks incl. 2 keys (Dimension drawings link) 1 piece assembled 12 800 21130-747 23130-158 21130-761 23130-159 – – 60113-267 21 800 21130-748 23130-158 21130-762 23130-159 21130-432 21130-442 60113-267 25 30 34 39 43 800 800 800 800 800 21130-749 21130-750 23130-158 23130-158 21130-763 21130-764 23130-159 23130-159 21130-433 21130-434 21130-443 21130-444 60113-267 60113-267 21130-751 23130-158 21130-765 23130-159 21130-435 21130-445 60113-267 21130-752 21130-753 23130-158 23130-158 21130-766 21130-767 23130-159 23130-159 21130-436 21130-437 21130-446 21130-447 60113-267 60113-267 Width SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting Mounting plate, stationary shelves, 75 kg Order Information Mounting plate Full height Height 1200 mm Stationary shelf Full depth Strengthening brackets Stationary shelf Shortened by 100 mm Depth member, 3 rows Completely in RAL 7021 (black grey) 01008052 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01008053 St, zinc-plated, 3 mm, static loadcarrying capacity up to 450 kg (rear mounted); strengthening bracket increases static load-carrying capacity; please order separately 01008080 St profile, increases static load-carrying capacity of mounting plate to 150 kg 01004142 01004142 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying cap. 75 kg, 1 U, capacity 75 kg, depth 479 mm, 1 U, incl. GND/ incl. GND/ earthing earthing, for recessed installation order depth members 01004126 length 460 mm, St, 1.5 mm, finish AlZn; required for recessed shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece PU 2 pieces 1 piece 1 piece PU 1 pair assembled assembled assembled assembled assembled assembled zinc-plated zinc-plated RAL 7021 – 23130-413 23130-418 RAL 7021 RAL 7021 AIZn 21130-323 21130-322 23130-081 21130-325 21130-324 23130-082 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 21130-323 21130-322 23130-081 21130-325 21130-333 21130-324 21130-332 23130-082 23130-081 – 23130-413 23130-418 23130-405 23130-413 23130-418 23130-406 23130-414 23130-418 23130-407 23130-413 23130-418 – – – 21130-323 21130-325 21130-322 21130-324 23130-081 23130-082 23130-407 23130-413 23130-418 23130-408 23130-414 23130-418 – 23130-413 23130-418 – 23130-413 23130-418 – 23130-414 23130-418 zinc-plated zinc-plated RAL 7021 – 23130-413 23130-418 21130-333 21130-332 23130-081 21130-335 21130-334 23130-082 – – – 21130-323 21130-322 23130-081 21130-325 21130-335 21130-324 21130-334 23130-082 23130-082 RAL 7035 RAL 7035 AlZn 22130-323 22130-322 23130-081 22130-325 22130-324 23130-082 22130-323 22130-325 22130-322 22130-324 23130-081 23130-082 22130-323 22130-322 23130-081 22130-325 22130-333 22130-324 22130-332 23130-082 23130-081 – 23130-413 23130-418 23130-405 23130-413 23130-418 23130-406 23130-414 23130-418 23130-407 23130-413 23130-418 – – – 22130-323 22130-325 22130-322 22130-324 23130-081 23130-082 23130-407 23130-413 23130-418 23130-408 23130-414 23130-418 – 23130-413 23130-418 – 23130-413 23130-418 – 23130-414 23130-418 22130-333 22130-332 23130-081 22130-335 22130-324 23130-082 – – – 22130-323 22130-322 23130-081 22130-325 22130-335 22130-324 22130-334 23130-082 23130-082 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.47 Cabinets – Varistar Elektronics ServicePLUS Interior mounting Telescopic shelves, 70 kg Order Information Telescopic shelf, 2 U Full depth Shortened by 100 mm Mounting bracket T-bar lock GND/earthing Completely in RAL 7021 (black grey) 01004144 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) 01004145 St, 1.5 mm, static St, 1.5 mm, static load-carrying load-carrying capacity 70/50 kg capacity 70/50 kg (width 600/ (width 600/ 800 mm), incl. 800 mm), incl. telescopic slide, telescopic slide, please order please order mounting bracket mounting bracket separately separately 01005054 St, finish AlZn 01004125 to lock the telescopic shelf 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.48 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 1 piece 1 piece PU 4 pieces 1 piece PU 1 kit assembled assembled assembled assembled assembled AIZn 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 RAL 7021 RAL 7021 21130-353 21130-352 21130-355 21130-354 21130-353 21130-355 21130-352 21130-354 21130-353 21130-352 21130-355 21130-373 21130-354 21130-372 23130-274 23130-092 23130-140 – – – – – 21130-353 21130-355 21130-352 21130-354 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 – – – 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 21130-373 21130-372 21130-375 21130-374 – – 21130-353 21130-352 21130-355 21130-375 21130-354 21130-374 RAL 7035 RAL 7035 22130-353 22130-352 22130-355 22130-354 22130-353 22130-355 22130-352 22130-354 AlZn RAL 7021 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 22130-353 22130-352 22130-355 22130-373 22130-354 22130-372 23130-274 23130-092 23130-140 – – – – – 22130-353 22130-355 22130-352 22130-354 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 – – – 23130-274 23130-092 23130-140 23130-274 23130-092 23130-140 22130-373 22130-372 22130-375 22130-374 – – 22130-353 22130-352 22130-355 22130-375 22130-354 22130-374 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting 19" shelves 1 U, stationary 75 kg, telescopic 30 kg Order Information 19'' stationary shelf, 1 U, 75 kg Full depth Shortened by 100 mm W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Full depth 19'' telescopic shelf, 1 U, 30 kg Shortened by GND/earthing 100 mm c D Dimension Standard fitting 01004118 01004119 01004123 01004122 St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static St, 1.5 mm, static xf = distance load-carrying load-carrying load-carrying load-carrying from front capacity 30 kg, capacity 30 kg, capacity 75 kg, capacity 75 kg, c = pitch of 19" incl. telescopic incl. telescopic depth 500 mm, depth 600 mm, panel/slide slide; slide; incl. GND/ incl. GND/ mounts please order please order earthing earthing D = cabinet depth GND/earthing kit GND/earthing kit W = cabinet width separately separately 05904052 for telescopic shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm RAL 7021 RAL 7021 RAL 7021 RAL 7021 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 21130-303 21130-305 21130-302 21130-304 21130-343 21130-345 21130-342 21130-344 RAL 7035 RAL 7035 RAL 7035 RAL 7035 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 22130-303 22130-305 22130-302 22130-304 22130-343 22130-345 22130-342 22130-344 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK 1 piece 1 piece 1 piece 1 piece PU 1 kit assembled assembled assembled assembled assembled 23130-140 21130-303 21130-302 21130-343 21130-342 21130-305 21130-303 21130-304 21130-302 21130-345 21130-343 21130-344 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-302 21130-343 21130-342 23130-140 – – – – – 21130-303 21130-302 21130-343 21130-342 21130-305 21130-303 21130-304 21130-302 21130-345 21130-343 21130-344 21130-342 21130-303 21130-302 21130-343 21130-342 – – – – 21130-303 21130-302 21130-343 21130-342 21130-305 21130-304 21130-345 21130-344 21130-303 21130-302 21130-343 21130-342 23130-140 23130-140 23130-140 23130-140 – 23130-140 23130-140 23130-140 22130-303 22130-302 22130-343 22130-342 22130-305 22130-303 22130-304 22130-302 22130-345 22130-343 22130-344 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-302 22130-343 22130-342 23130-140 – – – – – 22130-303 22130-302 22130-343 22130-342 22130-305 22130-303 22130-304 22130-302 22130-345 22130-343 22130-344 22130-342 22130-303 22130-302 22130-343 22130-342 – – – – 22130-303 22130-302 22130-343 22130-342 22130-305 22130-304 22130-345 22130-344 22130-303 22130-302 22130-343 22130-342 23130-140 23130-140 23130-140 23130-140 – 23130-140 23130-140 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.49 Cabinets – Varistar Elektronics ServicePLUS Interior mounting 19" telescopic shelf, 2 U, 70 kg Order Information Dimension Standard fitting Telescopic shelf, 2 U, 70 kg W 01004146 xf = distance from front c = pitch of 19" panel/slide mounts D = cabinet depth W = cabinet width Cabinet dimensions Height No. U mm Width Depth mm mm 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004123 1.50 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 01004122 01004125 05904052 St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 400 mm, depth 682 mm, incl. telescopic slide, please order, T-bar lock and earthing kit separately 1 piece to lock the telescopic shelf 1 piece PU 1 kit assembled assembled assembled assembled 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 xf mm c mm RAL 7021 RAL 7021 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 21130-353 21130-355 21130-352 21130-354 RAL 7035 RAL 7035 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 22130-353 22130-355 22130-352 22130-354 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 GND/earthing St, 1.5 mm, RAL 7021, static load-carrying capacity 70 kg, width 417 mm, depth 482 mm, incl. telescopic slide, please order, T-bar lock and earthing kit separately 1 piece Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 T-bar lock xf Completely in RAL 7021 (black grey) Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Shortened by 100 mm c D Full depth SCHROFF PRODUCT CATALOG E 08/2017 for telescopic shelf 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 21130-355 21130-354 21130-353 21130-352 23130-092 23130-140 – – – – 21130-353 21130-352 21130-355 21130-353 21130-354 21130-352 23130-092 23130-140 21130-353 21130-352 23130-092 23130-140 – – 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 23130-092 23130-140 – – 21130-353 21130-352 21130-355 21130-354 21130-353 21130-352 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 22130-355 22130-354 22130-353 22130-352 23130-092 23130-140 – – – – 22130-353 22130-352 22130-355 22130-353 22130-354 22130-352 23130-092 23130-140 22130-353 22130-352 23130-092 23130-140 – – 23130-092 23130-140 23130-092 23130-140 – – 22130-353 22130-352 22130-355 22130-354 22130-353 22130-352 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting Slide rails, depth members Order Information Slide rail 25 kg Depth member, 3 rows W xf Completely in RAL 7021 (black grey) 01004146 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) Short slide rail 100 kg c D Dimension Standard fitting 01004115 01004154 St, 1.5 mm, St, 2.5 mm, St, 1.5 mm, xf = distance finish AlZn, static zinc-plated, static finish AlZn, static from front load-carrying load-carrying load-carrying c = pitch of 19" capacity 15 kg/ capacity 100 kg/ capacity 25 kg/ panel/slide pair pair pair mounts D = cabinet depth W = cabinet width 01004126 length 460 mm, St, 1.5 mm, finish AlZn; required for recessed shelf Cabinet dimensions Height No. U mm Width Depth mm mm xf mm c mm 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 23130-097 23130-096 23130-119 23130-118 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 50 50 50 50 50 50 50 50 50 50 50 150 50 50 50 150 500 700 500 700 500 700 500 200 500 700 500 500 200 500 700 500 23130-097 23130-096 23130-119 23130-118 23130-097 23130-119 23130-096 23130-097 23130-118 23130-119 Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK PU 2 pieces PU 2 pieces PU 1 kit PU 1 pair supplied loose supplied loose supplied loose assembled AIZn zinc-plated AIZn 23130-096 23130-118 23130-094 23130-094 AIZn 23130-081 23130-082 23130-081 23130-082 23130-094 23130-081 23130-082 23130-081 23130-096 23130-118 23130-094 23130-099 23130-096 23130-116 23130-118 23130-094 23130-097 23130-119 23130-096 23130-096 23130-118 23130-118 23130-094 23130-099 23130-116 23130-094 – 23130-096 23130-097 23130-118 23130-119 23130-094 23130-081 23130-082 23130-096 23130-118 23130-094 23130-082 AlZn zinc-plated AlZn 23130-096 23130-118 23130-094 23130-094 23130-094 – 23130-081 23130-082 23130-081 23130-082 AlZn 23130-081 23130-082 23130-081 23130-082 23130-094 23130-081 23130-082 23130-081 23130-096 23130-118 23130-094 23130-099 23130-096 23130-116 23130-118 23130-094 23130-097 23130-119 23130-096 23130-096 23130-118 23130-118 23130-094 23130-099 23130-116 23130-094 – 23130-096 23130-097 23130-118 23130-119 23130-094 23130-081 23130-082 23130-096 23130-118 23130-094 23130-082 23130-094 – 23130-081 23130-082 23130-081 23130-082 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.51 Cabinets – Varistar Elektronics ServicePLUS Interior mounting Cable ductings Order Information Cable ducting with C-profile C-rail for cabinet depth C-rail for cabinet width Slide nut Cable shell Cable support for C-rail Completely in RAL 7021 (black grey) 01006109 St, 1.5 mm, finish AlZn 01006107 St, 1.5 mm, finish AlZn 01504054 for C-rail Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) vnt009 for C-rail or for cable support rail, for cable bundles of 42 ... 46 mm, further dimensions see page 1.24 01006110 PA, UL 94 V-0, black, assembly by clipping onto the C-rail Cabinet dimensions Height No. U mm Width Depth mm mm Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1.52 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 PU 2 pieces PU 2 pieces PU 10 pieces PU 10 pieces PU 5 pieces supplied loose supplied loose supplied loose supplied loose supplied loose AIZn AIZn 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 23130-334 21120-140 20114-731 60118-472 – – – – – 23130-086 23130-087 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 – – – – 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-333 21120-140 20114-731 60118-472 23130-086 23130-087 – 23130-086 23130-087 23130-087 AlZn 23130-086 23130-087 23130-086 23130-087 23130-086 23130-087 23130-086 AlZn 23130-334 21120-140 20114-731 60118-472 – – – – – 23130-086 23130-087 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 – – – – 23130-333 21120-140 20114-731 60118-472 23130-334 21120-140 20114-731 60118-472 23130-086 23130-087 – 23130-086 23130-087 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – Varistar Elektronics ServicePLUS Interior mounting Cable ties, Velcro Order Information Cable tie Velcro General components Mechanics Completely in RAL 7021 (black grey) from page 3.2 01005078 Colour combination RAL 7035 (light grey)/ RAL 7021 (black grey) plastic, 92 mm x 2.5 mm, further dimensions see page 1.25 01005079 black, length 300 mm, further dimensions see page 1.25 Electrics Cabinet dimensions Height No. U mm Width Depth mm mm PU 25 pieces PU 10 pieces supplied loose supplied loose Completely in RAL 7021 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 – – 20118-351 20118-624 20118-351 20118-624 from page 3.29 Power distribution from page 3.50 Colour combinations 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 29 29 33 33 38 38 38 42 42 42 42 42 47 47 47 47 1400 1400 1600 1600 1800 1800 1800 2000 2000 2000 2000 2000 2200 2200 2200 2200 600 600 600 600 600 600 800 600 600 600 800 800 600 600 600 800 600 800 600 800 600 800 600 300 600 800 600 800 300 600 800 800 SCHROFF.PENTAIR.CO.UK Climate control from page 4.0 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.53 VARISTAR EMCMain Catalogue Cabinets – VARISTAR EMC Content Cabinets . . . . . . 1 Wall mounted cases . . . . . . . . . 2 Accessories for cabinets and wall mounted cases . 3 Climate control . 4 Electronics cases . . . . . . . . . 5 01008001 Subracks/ 19" chassis . . . . 6 Front panels, plug-in units . . . 7 Systems . . . . . . . 8 41003017 Cooling with perforated HF door with high air throughput (78 % open area) 01007004 Cooling with HF fan top cover for up to 6 fans Power supply units . . . . . . . . . . 9 Backplanes . . . 10 Connectors, front panel component system . . . . . . . 11 01007005 Cable entry in rear section of base plate; sealing by means of sliding plates 01007003 Cable entry by means of HF connection plate Appendix . . . . . 12 1.54 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC Overview . . . . . . 1.54 VARISTAR EMC Main Catalogue Best performance in HF shielding 쮿 Shielding up to 60 dB at 1 GHz, 40 dB at 3 GHz (tested to IEC 61587-3) VARISTAR Platform . . . . . . . . . 1.4 Dimensions . . . . . . 1.8 쮿 Cable entry to front or rear or via base 쮿 Cooling with perforated front door or with fan top cover 쮿 Standard cabinets available from stock or individually configurable with appropriate accessory range VARISTAR EMC, base plate without cable ducting . . . . 1.55 VARISTAR EMC with perforated door . . . . . . . . . . . . . 1.57 VARISTAR EMC with fan top cover 1.58 VARISTAR EMC Accessories 01005017 01007017 쮿 Versions with/without cable entry through base plate 쮿 With perforated HF front and rear door 쮿 IP 55 쮿 Base plate with cable ducting 01007018 쮿 With fan top cover and perforated base plate with cable entry Base/plinth . . . . . . 1.59 19" swing frame . . . . . . . . . . . 1.60 19" panel/slide mount . . . . . . . . . . 1.61 19" fixing materials kit, M6 . . . . . . . . . . . . . . 1.61 Slide rails . . . . . . . . 1.62 19" shelves . . . . . . 1.63 Depth members . . 1.66 C horizontal rail . . 1.66 Cable tie, Velcro . . . . . . . . . . . 1.67 ServicePLUS . . 1.68 ServicePLUS configuration . . . . 1.69 ServicePLUS from page 1.68 e.g. individual configuration and assembly e.g. modifications (cut-outs, special colours) e.g. custom solutions (special sizes) www.schroff.biz/ServicePLUS VARISTAR Electronics . . . . . . 1.10 VARISTAR Seismic . . . . . . . . . 1.84 VARISTAR Datacom and Networking Technology . . . . . . 1.124 VARISTAR air/ water heat exchanger . . . . . . . 1.224 30407004 SCHROFF.PENTAIR.CO.UK 1.55 Cabinets – VARISTAR EMC VARISTAR EMC VARISTA R EMCMain CataloguePart number in bold face type: ready for despatch within 2 working daysP art number in normal type: ready for des patch within 10 working days 쮿 Shielding 60 dB at 1 GHz, 40 dB at 3 GHz (tested to IEC 61587-3) 쮿 Type of protection IP 55 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 400 kg (Slim-Line) 쮿 Base plate versions – without cable ducting – with cable ducting Delivery comprises (assembled) 01005017 Item 1 Qty 1 2 3 4 4 1 1 5 1 6 2 7a 7b 1 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, RAL 7021, with textile gasket all-around Adjustable foot, assembled Flat top cover, St, inner surface AlZn, outside RAL 7021 Front door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Rear door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Side panel, screw-fixed, St, inner surface AlZn, outside RAL 7035 Base plate, one-piece, St, 1.5 mm, finish AlZn Base plate with cable ducting, St, 1.5 mm, finish AlZn; cable entry to rear with conductive seal, 359 mm x 60 mm opening 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information Height Height H U mm 01005015 120 100 Description Base plate without cable entry Base plate with cable 42 2000 600 800 entry Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces 42 [dBµV] Width W Depth D mm mm 2000 600 800 Part no. 10130-020 10130-192 23130-077 23130-078 25127-995 23130-072 80 1 60 2 40 20 Note 쮿 For more dimensions and versions see ServicePLUS configuration, from page 1.69 쮿 Please order base/plinth separately, see page 1.59 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.61 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] 1) Shielding without cable ducting 2) Shielding with cable ducting, tested to IEC 61587-3, standard dimensions of test objects 2000 x 600 x 600 mm 01007060 ServicePLUS see page 1.68 1.56 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC VARISTAR EMC with perforated doors VARISTAR EMC 쮿 Shielding 40 dB at 1 GHz (tested to IEC 61587-3) 쮿 Air throughput 78 % 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) Item 1 Qty 1 2 3 4 4 1 1 5 1 6 2 7 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, RAL 7021, with textile gasket all around Adjustable foot, assembled Flat top cover, St, inner surface AlZn, outside RAL 7021 Front door, perforated, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Rear door, perforated, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Side panel, screw-fixed, St, inner surface AlZn, outside RAL 7035 Base plate with cable ducting, St, 1.5 mm, finish Al-Zn; cable entry to rear with conductive seal, 359 mm x 60 mm opening 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01007017 Height Height H Width W Depth D U mm mm mm 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for top cover PU 4 pieces Part no. 10130-190 23130-077 23130-078 25127-995 23130-072 Note 01007019 Perforation [dBµV] 120 쮿 For more dimensions and versions see ServicePLUS configuration, from page 1.69 쮿 Please order base/plinth separately, see page 1.59 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.61 100 80 60 40 20 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] Shielding: Tested to IEC 61587-3, standard dimensions of test object 2000 x 600 x 600 mm 01007059 ServicePLUS see page 1.68 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.57 Cabinets – VARISTAR EMC VARISTAR EMC with fan top cover VARISTA R EMC 쮿 Shielding 50 dB at 1 GHz (tested to IEC 61587-3) 쮿 Fan top cover with 3 fans (up to 6 fans can be mounted) 쮿 Perforated base plate with cable ducting 쮿 Doors with 4-point locking and screw-fixed side panels 쮿 Static load-carrying capacity 400 kg (Slim-Line) Delivery comprises (assembled) 01007018 Item 1 Qty 1 2 3 4 1 4 1 5 1 6 2 7 1 8 2 9 1 Description Welded basic frame, Slim-Line, St profile, RAL 7021, with conductive seal all-around Adjustable foot, assembled Raised top cover, St, 1.5 mm, RAL 7021; fan top cover with 3 axial fans, 230 VAC, incl. cabling and GND/ earthing; SCHUKO/UTE plug, cable length 2.5 m, IEC 60320-C13 socket; assembly space for 3 further fans Front door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Rear door, St, inner surface AlZn, outside RAL 7035, 180° hinge, 4-point locking, lever handle Side panel, screw-fixed, St, inner surface AlZn, outside RAL 7035 Base plate with cable ducting, perforated, St, 1.5 mm, finish AlZn; cable entry to rear with conductive seal, 359 mm x 60 mm opening 19" panel/slide mount with EIA cut-outs, AlZn, assembled at front, depth-adjustable in 25 mm increments GND/earthing kit, enclosed loose Order Information 01007004 Fan top cover [dBµV] Height Height H Width W Depth D U mm mm mm 42 2000 600 800 Castors load-carrying capacity 400 kg, PS/St, PU 4 pieces, 2 locking, 2 non locking Castors with integrated adjustable feet load-carrying capacity 400 kg, PU 4 pieces DIN profile half cylinder, common locking for lever handle (1 key fits all locks) incl. 2 keys Lifting eye for fan top PU 4 pieces Part no. 10130-191 23130-077 23130-078 25127-995 23130-090 Note 120 쮿 For more dimensions and versions see ServicePLUS configuration, from page 1.69 쮿 Please order base/plinth separately, see page 1.59 쮿 For assembly of shelves and slide rails another pair of panel/ slide mounts is necessary, see page 1.61 100 80 60 40 20 0 0 100 200 300 400 500 600 700 800 900 1000 [MHz] Shielding: Tested to IEC 61587-3, standard dimensions of test object 2000 x 600 x 600 mm 01007057 ServicePLUS see page 1.68 1.58 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC Stationary base VARISTAR EMC 쮿 Static load-carrying capacity 1000 kg 쮿 Removable trims allow cable entry from all sides 쮿 Cannot be used in conjunction with castors 쮿 Plinth height 100 mm, with feet adjustable from 112 to 132 mm 쮿 Versions – Front/rear trim perforated – Front/rear trim solid 2a H 2b 1 2b 2a D = cabinet depth W D 4 01004110 01004053 Delivery comprises (kit) Item 1 2a 2b 3 Qty 2 2 2 1 Description Support with feet, St, 3 mm Solid trim, St, 1.5 mm, RAL 7021 Perforated trim, St, 1.5 mm, RAL 7021 Assembly kit Order Information For cabinet width W Front/rear trim mm 600 perforated 600 solid Item 4 Side trim height 100 mm, depth 800 mm, PU 2 pieces Part no. 23130-187 23130-387 23130-170 Note 쮿 Please order side trims (item 4) separately Base/plinth, mobile VARISTAR EMC 쮿 Load-carrying capacity on castors 400 kg, on adjustable feet 1000 kg 쮿 Plinth height H = 100 mm, with feet adjustable from 126 to 134 mm Delivery comprises Item 1 2 3 4 Qty 1 4 4 1 Description Frame, St, 3 mm, RAL 7021, with adjustable feet Trim, St, 1.5 mm, RAL 7021 Castor Assembly kit Order Information For cabinet width mm 600 01004111 SCHROFF.PENTAIR.CO.UK For cabinet depth mm 800 Part no. 23130-209 01006095 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.59 Cabinets – VARISTAR EMC 19" swing frame VARISTA R EMC 쮿 Can accommodate 19" chassis and 19" subracks 2 쮿 For full height or partial-height mounting within cabinets 쮿 Pivot point can be selected right or left 쮿 Load-carrying capacity 150 kg h2 h1 Delivery comprises (kit) 1 Tm ax. Qty 1 2 2 2 1 Description Swing frame, St, 2 mm, RAL 7021 Support bar, St, 3 mm, RAL 7021 Square lock, 8 mm, incl. 2 keys 120° hinge Assembly kit Order Information 4 3 01005055 Maximum mounting depth for swing frame Cabinet Slim-Line Heavy-Duty Item 1 2 3 4 5 01005059 Width 600 mm 220 mm 200 mm For cabinet height Height h1 mm U 900 for partial-height mounting 16 1200 for partial-height mounting 24 1400 for partial-height mounting 29 1600 for partial-height mounting 33 1800 for partial-height mounting 38 2000 42 Swing frame stop max. swing angle 120°, St, zinc-plated, 1 piece Security lock to replace the square lock, PU 1 lock incl. 2 keys Spare key for security lock, 1 piece Height h2 U 12 21 25 30 34 39 Part no. 21130-740 21130-741 21130-742 21130-743 21130-744 21130-745 23130-158 60113-267 60220-003 Note Swing frame stop 쮿 19" swing frames can be assembled: – Directly on the cabinet frame – In 50 mm increments by aid of depth members (depth-adjustable) 쮿 For partial-height mounting, depth members are necessary, see page 1.66 01005061 Security lock 41001517 1.60 SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC 19" panel/slide mount with universal pitch (EIA) VARISTAR EMC 쮿 Assembly in 600 mm wide cabinets directly on the frame 쮿 Depth-adjustable in 25 mm increments 쮿 In accordance with IEC 60297-1 (DIN 41 494, part 1) Delivery comprises 46 5 44,45 44.45 12,75 15,9 65,1 2 76 25 25 49,5 Qty 2 2 1 Description 19" panel/slide mount, St, 1.75 mm, finish AlZn, RAL 7035 or RAL 7021 Assembly kit, incl. GND/earthing Order Information 9,6 42,5 Item 1 01004112 01004131 For cabinet Usable Length AlZn RAL 7035 height height mm U mm Part no. Part no. 8 395 23130-037 23130-027 12 545 23130-038 23130-028 16 745 23130-039 23130-029 Partial20 895 23130-040 23130-030 height 24 1095 23130-031 23130-021 mounting 29 1295 23130-032 23130-022 33 1495 23130-033 23130-023 38 1695 23130-034 23130-024 2000 42 1895 23130-035 23130-025 Dimensioning strip for 19" panel mounts, paper, white, serial numbered from 1 ... 47 U, PU 4 pieces RAL 7021 Part no. 23130-017 23130-018 23130-019 23130-020 23130-011 23130-012 23130-013 23130-014 23130-015 25127-997 Note 쮿 For 19" partial-height mounting depth members are necessary 쮿 Metric panel/slide mounts available on request Standard assembly dimension xr = xf = 50 mm 01005088 19" assembly kit, M6 VARISTAR EMC 쮿 For front panels, distribution fields and other components Delivery comprises Item 1 2 3 Description Panhead screw, M6 x 16, St, zinc-plated Plastic washer, black Cage nut, M6, St, zinc-plated Order Information Description 19" assembly kit (screw, washer, nut) 19" assembly kit (screw, washer, nut) Qty/PU 50 100 Part no. 21101-809 21101-810 sc128 SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.61 Cabinets – VARISTAR EMC Slide rails VARISTA R EMC 쮿 For assembly on 19" panel/slide mounts 쮿 Assembly in 1 U increments (snap-in, bolt-on) 쮿 Wide support surface (48 mm) 쮿 2 versions – Static load-carrying capacity 25 kg per pair – Static load-carrying capacity 100 kg per pair Delivery comprises 01004056 Item 1 Qty see Order information 2 1 Description Slide rail, AlZn, 1.5 mm (static load-carrying capacity 25 kg), or 2.5 mm (static load-carrying capacity 100 kg), zinc-plated Assembly kit incl. GND/earthing Order Information Static load carrying capacity 25 kg For cabinet depth D mm 800 800 01005086 Static load-carrying capacity 25 kg xf c Length L Qty/PU mm 50 50 mm 700 700 mm 656 656 2 10 Part no. 23130-097 23130-102 Order Information Static load carrying capacity 100 kg For cabinet depth D mm 800 800 c Length L Qty/PU mm 50 50 mm 700 700 mm 658 658 2 10 Part no. 23130-119 23130-124 01004058 19” c = pitch of the 19" panel/slide mounts xf = standard dimension D = cabinet depth SCHROFF PRODUCT CATALOG E 08/2017 D c xf c - 130 Static load-carrying capacity 100 kg 1.62 xf 01004130 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC 19'' stationary shelf, 75 kg VARISTAR EMC 쮿 Static load-carrying capacity 75 kg (150 kg with strengthening rail) 쮿 Mounting height 1 U, for mounting on four panel/slide mounts 쮿 With hammer head perforation to fix cable ties Delivery comprises xr 01004066 Item 1 Qty 1 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Assembly kit incl. GND/earthing c For cabinet Usable xf c RAL 7035 depth surface w x d mm mm mm mm Part no. 800 495 x 642 50 700 22130-305 Strengthening rail for stationary 19" shelf PU 1 piece D d Order Information RAL 7021 Part no. 21130-305 23130-310 Note w xf 쮿 Cable ducting with cable ties, see page 1.67 쮿 Other sizes, see ServicePLUS, page 1.80 W c = max. pitch of the 19" slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004067 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.63 Cabinets – VARISTAR EMC 19'' telescopic shelf, 30 kg VARISTA R EMC 쮿 Static load-carrying capacity at full extension 30 kg 1 쮿 Mounting height 1 U, for mounting on four 19" panel/slide mounts 2 쮿 Incl. telescopic slides 쮿 Hammer head perforation to fix cable ties 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting 01004068 Full depth W xr w Delivery comprises Item 1 Qty 1 2 3 2 1 Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit Order Information c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 800 417 x 682 50 700 22130-345 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR D c d Full depth RAL 7021 Part no. 21130-345 23130-140 xf Note 쮿 Cable ducting with cable ties, see page 1.67 01004069 Order Information Shortened depth Shortened by 100 mm W For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 800 417 x 582 50 700 22130-344 GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xr w RAL 7021 Part no. 21130-344 23130-140 D 쮿 Cable ducting with cable ties, see page 1.67 xf d c Note c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly pitch 1.64 SCHROFF PRODUCT CATALOG E 08/2017 01004070 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC 19'' telescopic shelf, 70 kg VARISTAR EMC 1 쮿 Static load-carrying capacity at full extension 70 kg 2 쮿 Mounting height 2 U, for mounting on four 19" panel/slide mounts 4 쮿 Incl. telescopic slides 쮿 Locking with T-bar lock possible 쮿 Hammer head perforation to fix cable ties 01004071 W Delivery comprises w Item 1 Qty 1 2 3 2 1 xr Full depth 쮿 2 versions – Full depth – Depth shortened by 100 mm for rear cable ducting Description Perforated shelf, St, 1.5 mm (colour see Order Information) Telescopic slide Assembly kit D c Full depth c RAL 7035 For cabinet Usable surface xf depth wxd mm mm mm mm Part no. 800 405 x 682 50 700 22130-355 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR xf d Order Information RAL 7021 Part no. 21130-355 23130-092 23130-140 Note 01004069 c = max. pitch for 19" panel/slide mounts Shortened depth W 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.67 Order Information w Shortened by 100 mm D d c xr For cabinet Usable surface xf c RAL 7035 depth wxd mm mm mm mm Part no. 800 405 x 582 50 700 22130-354 Item 4 T-bar lock for 1 telescopic shelf (can be mounted right or left), 1 piece GND/earthing for telescopic 19" shelf PU 1 kit, for VARISTAR RAL 7021 Part no. 21130-354 23130-092 23130-140 Note xf 쮿 Please order T-bar lock (item 4) separately 쮿 Cable ducting with cable ties, see page 1.67 c = max. pitch of the 19" panel/slide mounts xf, xr = standard assembly dimension SCHROFF.PENTAIR.CO.UK 01004070 Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.65 Cabinets – VARISTAR EMC Depth member VARISTA R EMC 쮿 For mounting of shortened 19" panel/slide mounts 쮿 Cable ducting by means of cable ties and cable eyes 36,5 11,5 Delivery comprises 50 100 37,5 121,2 25 25 L - 27 Qty 2 1 Description Depth member, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 12 Description L 01004126 Item 1 2 01004079 Cable eye For cabinet depth mm Depth member 800 Cable eye A = 38 mm, B = 25 mm, PU 25 pieces Cable eye A = 47 mm, B = 50 mm, PU 25 pieces Part no. 23130-082 21101-151 21101-150 쮿 Cable ducting with cable ties, see page 1.67 coa43697 C-profile for the cabinet depth VARISTA R EMC 쮿 For cable ducting in lateral area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, AlZn Assembly kit incl. GND/earthing Order Information Cable retention rail and cable shell mounted on C-profile 01004129 Slide nut 15 ,5 Ø6 50 11 Part no. 23130-087 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note L 쮿 Cable ties and Velcro for cable retention rail see page 1.67 39,5 29,5 L- ,5 x 31 For cabinet depth Length L mm mm 800 660 Accessories Cable retention rail for C-rail width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces 50 75 01504054 1.66 C-profile 01004132 01006071 Cable retention rail SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC C-profile for cabinet width VARISTAR EMC 쮿 For cable ducting in rear or front area of cabinet 쮿 For cable shells and cable retention rails Delivery comprises Item 1 2 Qty 2 1 Description C-profile, St, 1.5 mm, finish AlZn Assembly kit incl. GND/earthing Order Information 01006063 C-profile Slide nut For cabinet width Length mm mm 800 750 Accessories Cable retention rail for C-rail width 75 mm, length 39.5 mm, PU 5 pieces Cable shell for cable bundle 18 ... 22 mm, PU 10 pieces Cable shell for cable bundle 22 ... 26 mm, PU 10 pieces Cable shell for cable bundle 26 ... 30 mm, PU 10 pieces Cable shell for cable bundle 30 ... 34 mm, PU 10 pieces Cable shell for cable bundle 34 ... 38 mm, PU 10 pieces Cable shell for cable bundle 38 ... 42 mm, PU 10 pieces Cable shell for cable bundle 42 ... 46 mm, PU 10 pieces Cable shell for cable bundle 46 ... 50 mm, PU 10 pieces Slide nut for C-profile, PU 10 pieces Part no. 23130-334 60118-472 20118-775 20118-776 20118-777 20114-728 20114-729 20114-730 20114-731 20118-778 21120-140 Note 39,5 쮿 Cable ties and Velcro for cable retention rail see page 1.67 75 01006071 01006064 Cable retention rail 01504054 Cable ties, Velcro VARISTAR EMC 쮿 Fixing materials kit for cable ducting Order Information Description Cable tie, Plastic, 92 mm x 2.5 mm, PU 25 pieces Cable tie, Plastic, 186 mm x 5 mm, PU 25 pieces Cable tie, Plastic, 360 mm x 5 mm, PU 25 pieces Velcro strip, PE/PA, black, length 300 mm, PU 10 pieces Cable tie 01005078 Velcro Part no. 20118-351 20118-352 20118-353 20118-624 01005079 VARISTAR EMC VARISTAR EMC ServiceP LUS SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.67 Cabinets – VARISTAR EMC ServicePLUS configuration Simple. Fast. To the ideal product. Components can be varied and combined freely 쮿 Configuration tables from page 1.69 assembly Assembled by professionals. Double benefit! Fitting of all mechanical, electrical and electronic components by our specialists 쮿 Without extra cost modification Small changes. Large impact. Custom drillings, cut-outs and special colours for off-the-shelf products 쮿 Download CAD data and send back with modifications solution Simple. Fast. From one source. Integration and custom developments 쮿 Climate control, complete assembly, cabling (power supply), function test 쮿 Online configuration: www.schroff.co.uk/configuration 쮿 Ready for despatch within 10 working days 쮿 Ready for despatch within 10 working days 쮿 Special sizes, customised solutions academy Knowledge. Sharing. Partnerships. Knowledge transfer and partnership 쮿 Seminars, white papers, CAD drawings, test reports, user reports 쮿 Further information: www.varistar.co.uk 1.68 lifecycle We are with you. For the entire product life. Flexible support throughout the product lifecycle 쮿 Delivery to point of use, installation service, exchange service, replacement parts SCHROFF PRODUCT CATALOG E 08/2017 ELECTRONICS PROTECTION Cabinets – VARISTAR EMC ServicePLUS VARISTAR ServicePLUS: configuration and assembly VARISTAR EMC ServicePLUS 쮿 Dimensions: – Height: 29 ... 47 U (1400 ... 2200 mm) – Width: 600 and 800 mm – Depth: 600, 800 and 1000 mm 쮿 2 colour combinations: – Frame and covers in black grey (RAL 7021) – Frame, top cover and base in black grey (RAL 7021); Side panel, door and rear panel in light grey (RAL 7035) 쮿 Build your cabinet out of individual components (please suffix each part number with /05) 쮿 Once you have selected the desired cabinet dimensions, the row number (first column of the configuration tables) will guide you through all subsequent configuration pages that apply to these dimensions (see example below) 쮿 The cabinet is assembled by us and ready for despatch within 10 working days 01004077 Example configuration (here: row 9) SCHROFF.PENTAIR.CO.UK Part number in bold face type: ready for despatch within 2 working days Part number in normal type: ready for despatch within 10 working days 1.69
60817067 价格&库存
很抱歉,暂时无法提供与“60817067”相匹配的价格&库存,您可以联系我们找货
