E-1000
E-1000
    BIVAR
    CARD GUIDE PRESS 10X0.078" BLK
E-1000 数据手册
REV. D E F PART NO. L 0.310 [7.9mm] 0.078 [2.0mm] D T 0.156 [4.0mm] C A 0.500 [12.7mm] A ±0.005 0.102+0.003 -0.001 TYP. C±0.005 0.118+0.003 -0.001 Ø.172+.003 -.001 0.133+0.003 -0.001 0.168+0.003 -0.001 Recommended Mounting Holes TYP. L ±.062 (1.6) E-200 2.0 (50.8) E-250 E-300 E-350 E-400 E-450 E-500 E-550 E-600 E-650 E-700 E-750 E-800 2.5 (63.5) 3.0 (76.2) 3.5 (88.9) 4.0 (101.6) 4.5 (114.3) 5.0 (127.0) 5.5 (139.7) 6.0 (152.4) 6.5 (165.1) 7.0 (177.8) 7.5 (190.5) 8.0 (203.2) PART NO. E-850 E-900 E-950 E-1000 E-1050 E-1100 E-1150 E-1200 E-1250 E-1300 E-1350 E-1400 L ±.062 (1.6) 8.5 (215.9) 9.0 (228.6) 9.5 (241.3) 10.0 (254.0) 10.5 (266.7) 11.0 (279.4) 11.5 (292.1) 12.0 (304.8) 12.5 (317.5) 13.0 (330.2) 13.5 (342.9) 14.0 (355.6) DATE APPROVED 02/26/04 07/10/14 05/13/16 M. C. J. C. J. C. DESCRIPTION Engineering Update w/o Changes Materials Update Engineering Update w/o Changes D ±.005 (.1) T ±.005 (.1) A +.016 (.41) -.032 (.81) 1.016 (25.8) C +.016 (.41) -.032 (.81) N/A .078 (2.0) .125 (3.2) 1.516 (38.5) N/A .078 (2.0) .125 (3.2) 3.016 (76.6) N/A .078 (2.0) .125 (3.2) 5.016 (127.4) N/A .078 (2.0) .125 (3.2) 6.031 (153.2) N/A .078 (2.0) .125 (3.2) A +.016 (.41) -.047 (1.2) C +.016 (.41) -.032 (.81) 7.531(191.3) 3.766 (95.7) .078 (2.0) .141 (3.6) 9.031(229.4) 4.516 (114.7) .078 (2.0) .141 (3.6) 10.547(267.9) 5.274 (134.0) .093 (2.4) .156 (4.0) 12.047(306.0) 6.024 (153.0) .093 (2.4) .156 (4.0) D ±.005 (.1) DESC DWG. NO. 84006-01 84006-02 84006-03 84006-04 84006-05 84006-06 84006-07 84006-08 84006-09 84006-10 84006-11 84006-12 T ±.007 (.2) DESC DWG. NO. 84006-13 84006-14 84006-15 84006-16 84006-17 84006-18 84006-19 84006-20 84006-21 84006-22 84006-23 84006-24 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 66, 15% GLASS, 94V-0, BLACK. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. ± .1 ± .01 ± .005 DESIGNED: S. Irving CHECKED: D. Green ANGULAR X° ± 1° DATE: 08/10/98 DATE: 12/03/02 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: ECON-O-GIDE PRESS-IN CARD GUIDE REVISION: PART NO: E-XXX CAGE CODE : 32559 F SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
E-1000 价格&库存
很抱歉,暂时无法提供与“E-1000”相匹配的价格&库存,您可以联系我们找货
