REV.
D
E
F
PART
NO.
L
0.310 [7.9mm]
0.078 [2.0mm]
D
T
0.156 [4.0mm]
C
A
0.500 [12.7mm]
A
±0.005
0.102+0.003
-0.001 TYP.
C±0.005
0.118+0.003
-0.001
Ø.172+.003
-.001
0.133+0.003
-0.001
0.168+0.003
-0.001
Recommended Mounting Holes
TYP.
L
±.062 (1.6)
E-200
2.0 (50.8)
E-250
E-300
E-350
E-400
E-450
E-500
E-550
E-600
E-650
E-700
E-750
E-800
2.5 (63.5)
3.0 (76.2)
3.5 (88.9)
4.0 (101.6)
4.5 (114.3)
5.0 (127.0)
5.5 (139.7)
6.0 (152.4)
6.5 (165.1)
7.0 (177.8)
7.5 (190.5)
8.0 (203.2)
PART
NO.
E-850
E-900
E-950
E-1000
E-1050
E-1100
E-1150
E-1200
E-1250
E-1300
E-1350
E-1400
L
±.062 (1.6)
8.5 (215.9)
9.0 (228.6)
9.5 (241.3)
10.0 (254.0)
10.5 (266.7)
11.0 (279.4)
11.5 (292.1)
12.0 (304.8)
12.5 (317.5)
13.0 (330.2)
13.5 (342.9)
14.0 (355.6)
DATE
APPROVED
02/26/04
07/10/14
05/13/16
M. C.
J. C.
J. C.
DESCRIPTION
Engineering Update w/o Changes
Materials Update
D
±.005 (.1)
T
±.005 (.1)
A
+.016 (.41)
-.032 (.81)
1.016 (25.8)
C
+.016 (.41)
-.032 (.81)
N/A
.078 (2.0)
.125 (3.2)
1.516 (38.5)
N/A
.078 (2.0)
.125 (3.2)
3.016 (76.6)
N/A
.078 (2.0)
.125 (3.2)
5.016 (127.4)
N/A
.078 (2.0)
.125 (3.2)
6.031 (153.2)
N/A
.078 (2.0)
.125 (3.2)
A
+.016 (.41)
-.047 (1.2)
C
+.016 (.41)
-.032 (.81)
7.531(191.3)
3.766 (95.7)
.078 (2.0)
.141 (3.6)
9.031(229.4)
4.516 (114.7)
.078 (2.0)
.141 (3.6)
10.547(267.9) 5.274 (134.0)
.093 (2.4)
.156 (4.0)
12.047(306.0) 6.024 (153.0)
.093 (2.4)
.156 (4.0)
D
±.005 (.1)
DESC
DWG. NO.
84006-01
84006-02
84006-03
84006-04
84006-05
84006-06
84006-07
84006-08
84006-09
84006-10
84006-11
84006-12
T
±.007 (.2)
DESC
DWG. NO.
84006-13
84006-14
84006-15
84006-16
84006-17
84006-18
84006-19
84006-20
84006-21
84006-22
84006-23
84006-24
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 66, 15% GLASS, 94V-0, BLACK.
1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101.
± .1
± .01
± .005
DESIGNED:
S. Irving
CHECKED:
D. Green
ANGULAR
X°
± 1°
DATE:
08/10/98
DATE:
12/03/02
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
ECON-O-GIDE PRESS-IN CARD GUIDE
REVISION:
PART NO:
E-XXX
CAGE CODE : 32559
F
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“E-250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.166641+0.85678
- 10+5.8411710+0.69832
- 25+5.3802725+0.64322
- 50+5.0610450+0.60505
- 100+4.75809100+0.56884
- 300+4.31606300+0.51599
- 500+4.12481500+0.49313
- 1000+3.879021000+0.46374
- 2500+3.576442500+0.42757
