HCG-202-165
HCG-202-165
    BIVAR
    CARD GUIDE HORZ 2X0.078" BLK
HCG-202-165 数据手册
REV. DESCRIPTION F Engineering Update w/o Changes G Removed Material Code C/L A DATE APPROVED 02/27/04 05/13/16 M. C. J. C. 0.310 [7.9mm] 0.088 [2.2mm] TYP. C/L 0.078 [2.0mm] 0.275 [7.0mm] 0.156 [4.0mm] B 0.500 [12.7mm] HCG-XX1-XXX 0.212+0.003 -0.001 Ø.172+.003 -.001 0.172+0.003 -0.001 B Recommended Mounting Holes HCG-XX2-XXX PART NO. A ±.032 (.8) B ±.016 (.4) C/L ±.005 (.1) HCG-201-165 HCG-202-165 2.0 (50.8) 1.0 (25.4) .165 (4.2) HCG-251-165 HCG-252-165 2.5 (63.5) 1.5 (38.1) .165 (4.2) HCG-301-165 HCG-302-165 3.0 (76.2) 2.0 (50.8) .165 (4.2) HCG-351-165 HCG-352-165 3.5 (88.9) 2.5 (63.5) .165 (4.2) HCG-401-165 HCG-402-165 4.0 (101.6) 3.0 (76.2) .165 (4.2) HCG-451-165 HCG-452-165 4.5 (114.3) 3.5 (88.9) .165 (4.2) HCG-501-165 HCG-502-165 5.0 (127.0) 4.0 (101.6) .165 (4.2) HCG-551-165 HCG-552-165 5.5 (139.7) 4.5 (114.3) .165 (4.2) HCG-601-165 HCG-602-165 6.0 (152.4) 5.0 (127.0) .165 (4.2) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 66, 94V-0, BLACK. DESIGNED: 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. CHECKED: ± .1 ± .01 ± .005 S. Irving D. Green ANGULAR X° ± 1° DATE: 10/21/99 DATE: 11/26/02 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DOUBLE SIDED HORIZONTAL CARD GUIDE FOR P.C.B. REVISION: PART NO: HCG-XXX-XXX CAGE CODE : 32559 G SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
HCG-202-165 价格&库存
很抱歉,暂时无法提供与“HCG-202-165”相匹配的价格&库存,您可以联系我们找货
