FR-250
FR-250
    BIVAR
    CARD GUIDE FR 2.5X0.078" RUST
FR-250 数据手册
temp-o-gide™ Flame Retardant Card Guides for 1⁄16th PCBs • 25 Standard Lengths from 2"- 14" in 1⁄2 " increments • Precision Molded for rigidity, strength and heat resistance from flame retardant 94V-O UL rated materials • Stainless Steel Conductive Inserts available for all lengths (see page 13) Rigid, strong and economical, TEMP-O-GIDEs provide the design flexibility and installed reliability that your most demanding products require. Retention is firm and there are no special tools or fixtures required for installation. Locking ejectors can be used for positive PCB retention and insertion/extraction ease (see page 12-14 for details). Mounting Information: Snap-in metal plates: 0.047" - 0.090" (1.2mm - 2.3mm) thick Hole Size: 0.172" (4.4mm) diameter + 0.003" (0.08mm) 0.002" (0.06mm) x 0.232" (5.9mm) 1/64th drill Center - 0.220" x 0.168"+ 0.003"- 0.001" Rear - 0.235" x 0.168"+ 0.003"- 0.001" Material Specifications: UL Rated 94V-O, Rust colored, Flame Retardant 6/6 Nylon Oxygen Index: +28% UL File #E84658 Application Notes: Slotting or elongating of the second and third mounting hole is recommended to allow for length variations and to provide for easier assembly. Prolonged pre-assembly exposure to high humidity can cause molded Nylon components to “grow” out of tolerance. Storage in a cool dry place is recommended. Open sealed vapor barrier bags at the time of production to assure optimum shelf life. Recommended Mounting Holes Temp-O-Gide 2" thru 8" Lengths L ±.062 (1.6) A ±.032 (.81) FR-200 1.969 (50.0) .984 (25.0) FR-250 2.469 (62.7) FR-300 2.969 (75.4) FR-350 3.469 (88.1) FR-400 3.939 (100.0) FR-450 4.438 (112.7) FR-500 4.938 (125.4) FR-550 5.438 (138.1) FR-600 5.906 (150.0) FR-650 6.406 (162.7) FR-700 6.875 (174.6) FR-750 7.375 (187.3) FR-800 7.875 (200.0) Part No. 1.484 (37.7) 2.969 (75.4) 4.953 (125.8) 5.969 (151.6) Temp-O-Gide 8-1/2" thru 14" Lengths L ±.062 (1.6) Part No. FR-850 8.375 (212.7) FR-900 8.875 (225.4) FR-950 9.375 (238.1) FR-1000 9.875 (250.8) FR-1050 10.375 (263.5) FR-1100 10.875 (276.2) FR-1150 11.344 (288.1) FR-1200 11.844 (300.8) FR-1250 12.344 (313.5) FR-1300 12.812 (325.4) FR-1350 13.312 (338.1) FR-1400 13.812 (350.8) cage code (FSCM) 32559 © copyright 2004 Bivar Inc. A +.032 (.81) -.047 (1.2) C +.016 (.41) -.032 (.81) D ±.005 (.13) T ±.007 (.18)" 7.469 (189.7) 3.735 (94.9) .078 (2.0) .141 (3.6) 8.938 (227.0) 4.469 (113.5) .078 (2.0) .141 (3.6) 10.406 (264.3) 5.203 (132.2) .093 (2.4) .156 (4.0) 11.906 (302.4) 5.953 (151.2) .093 (2.4) .156 (4.0) www.bivar.com 18
FR-250 价格&库存
很抱歉,暂时无法提供与“FR-250”相匹配的价格&库存,您可以联系我们找货
