SFS-650
SFS-650
    BIVAR
    CARD GUIDE SNAP 6.5LX.075"SW NAT
SFS-650 数据手册
Bivar 1985 INNOVATION Comp-O-Gide™ Comp-O-Gide tm Industry Standard Snap-in Card Guides for 1⁄16th PCBs Industry Standard Snap-in Card Guides for 1/16th PCBs • 52 configurations to meet most standard requirements • Precision Molded for rigidity, strength and heat resistance from 94V-2 UL rated materials • Stainless Steel Conductive Inserts available for all sizes (see page 19) • Two channel depths and two channel widths available to accommodate 1⁄16th & 3⁄32nd PCBs • Common industry standards interchange with competitive devices COMP-O-GIDE, was introduced in 1985 to provide second sources for previously single source card guides. The series has expanded to offer wider selection and application specific function. Rigid, strong and economical, COMP-O-GIDEs provide the installed reliability that your most demanding products require. Retention is firm and there are no special tools or fixtures required for installation. Mounting Information: Snap-in metal plates: 0.047" - 0.090" (1.2mm - 2.3mm) thick Hole Size: 0.180" (4.6mm) diameter + 0.003 (0.08mm), 0.001 (0.03mm) 3⁄16th drill Material Specifications: UL Rated 94V-2, natural, 6/6 Nylon per ASTM D4066 PA111 Oxygen Index: +28% UL File #E135532 Application Notes: Slotting or elongating of the second and third mounting hole is recommended to allow for length variations and to provide for easier assembly. Prolonged pre-assembly exposure to high humidity can cause molded Nylon components to “grow” out of tolerance. Storage in a cool dry place is recommended. Open sealed vapor barrier bags at the time of production to assure optimum shelf life. Comp-O-Gide for 1⁄16th PCBs 21⁄2" thru 8" Lengths 16 Printed Circuit Board Packaging Hardware Part No. A B ±.031 (.79) ±.016 (.41) SFS-250 SFS-300 SFS-350 SFS-400 SFS-450 SFS-451 SFS-500 SFS-550 SFS-600 SFS-650 SFS-651 SFS-700 SFS-750 SFS-800 2.5 (63.5) 3.0 (76.2) 3.5 (88.9) 4.0 (101.6) 4.5 (114.3) 4.5 (114.3) 5.0 (127.0) 5.5 (139.7) 6.0 (152.4) 6.5 (165.1) 6.5 (165.1) 7.0 (177.8) 7.5 (190.5) 8.0 (203.2) 1.5 (38.1) 2.0 (50.8) 2.5 (63.5) 3.0 (76.2) 3.0 (76.2) 3.5 (88.9) 4.0 (101.6) 4.5 (114.3) 5.0 (127.0) 5.02 (127.5) 5.5 (139.7) 6.0 (152.4) 6.5 (165.1) 7.0 (177.8) Cage Code (FSCM) 32599 © Copyright 2001 Bivar Inc.
SFS-650 价格&库存
很抱歉,暂时无法提供与“SFS-650”相匹配的价格&库存,您可以联系我们找货
