CCK17S/90
CCK17S/90
    VECTOR
    CARD RACK KIT 5UX19X12 SNAP-IN
CCK17S/90 数据手册
Subracks - VectorPak Subrack Types ® 37 Introduction Designed in accordance with EIA standard RS-310, Vector subracks and modules offer versatility within a 19” rackmount format. All racks are adjustable in both height and depth, offering standard product solutions for standard and custom requirements. All Subrack sizes are compatible with Vector prototyping boards (see Vectorbord section), and can accommodate other sizes as well. Several card guide types (metal or plastic, snap-in, rivet, or screw-down) are available. Cages VectorPak® Subrack and Module Subrack Types by Part Number Stem: CCK - Card Cage frame kit. Kits with no card guides use ‘F’ in number (e.g., CCK13F/90). Other kits have 21 pair of guides included: ‘S’= plastic snap-in type e.g., CCK13S/90; ‘M’ or ‘P’= metal or plastic, fastened with hardware. Guide spacing is .25”. CCA - Same as CCK version, but all are assembled with guides. CMA - Assembled Module Subrack for EFP modules. Modules available separately. CCM - Assembled rack for Card Mount Modules (CM type). Modules available separately. For Rack Accessories see page 41A For Desktop outer enclosure, see page 42 New Item: CCK19F/90 (For max 11.5” x 13.5” cards) Subrack Kits (CCK) .060” Assembled Subracks with Card Guides (CCA) - CCK 13 Model Type CCK - Kit only with snap-in card guides CCA - Factory assembled version of CCK with snap-in card guides CCM - Factory assembled card mount cage with snap-in card guides CMA - Assembled module cage with module guides Series Number (Max. Card Size) 12 - 3U (5.25”) X 19” x 9” (4.5” x 4.5”) 21 pair Card Guides included 13 - 3U (5.25”) X 19” X 9” (4.5” x 6.5”) 21 pair Card Guides included 14 - 3U (5.25”) X 19” X 12” (4.5” x 9.6”) 16 - 3U (5.25”) X 19” X 15.75” (4.5” x 13.5”) 15 - 4U (7.00”) X 19” X 12” (6.25” x 9.6”) 20 - 4U (7.00”) X 19” X 15.75” (6.25” x 13.5”) 17 - 5U (8.75”) X 19” X 12” (8.00” x 11.0”) 18 - 6U (10.50”) X 19” X 15.75” (9.75” x 13.5”) 19 - 7U (12.25”) X 19” X 15.75” (11.5” x 13.5”) 100 -7U (12.25”) X 19” X 9.00” (11.5” x 7”) Assembled Card Mount Subracks (CCM) - S - /90 Note: /90 denotes side walls with .200” slot width On CCA, K frames only also denotes snap-in version CCK Type F - Frame only, snap-in plastic, metal or plastic screw-down card guides available separately C - Continuous guide plate, assembled cage only S - Sanp-in guides included M - Screw-in Aluminum card guides P - Screw-in plastic card guides CMA 13 or 14 - XX/90 16 - Designed for 1.6” wide EFP modules 20 - Designed for 2.0” wide EFP modules 30 - Designed for 3.0” wide EFP modules For Front Door Panels and Covers see page 41A 11115 Vanowen St., North Hollywood, CA 91605 Phone (818) 985-8208 Toll-Free (800) 423-5659 Web site: http://www.vectorelect.com A Fine Technology Group Subracks Assembled Module Subracks (CMA) Assembled Subracks with Continuous Guide Plate 38 Subracks - VectorPak® Assembled Subracks with Card Guides (CCA) Assembled Cardmount Subracks (CCM) Cardmount Subracks • • • • • • • Subracks • • • • Model CCM13S/90 Card Module Rack with assorted cardmount modules Accepts CM45A65 Card Mount Modules Card guide positions are variable at .25” increments Assembled module rack - plastic snap-in install on 1” centers Different width modules may be inserted interchangeable without guide changes Card mount modules (CM Series) with 1” to 4” widths For 3U and 4U applications Adjustable rear struts for connection of backplanes (struts available separately) .062” thick aluminum plates are inserted into guide; PC Card is attached firmly to plate Front panels on card mount may be removed for custom punching, plating and printing Modules may be secured by thumb screws (SC10-3A, 10-32 included) For Desktop outer enclosure, see page 42 Card Mount Modules Part No. CM45A65-1 CM45A65-2 CM45A65-4 CM45B95-1 CM45B95-2 CM45B95-4 CM62F95-1 CM62F95-2 CM62F95-4 CM90F95-1 CM90F95-2 CM90F95-4 Height Width Length H1 H2 5.25” 4.5” 5.25” 4.5” 5.25” 4.5” 5.25” 4.5” 5.25” 4.5” 5.25” 4.5” 7.0” 6.25” 7.0” 6.25” 7.0” 6.25” 10.5” 9.00” 10.5” 9.00” 10.5” 9.00” W 1.0” 2.0” 4.0” 1.0” 2.0” 4.0” 1.0” 2.0” 4.0” 1.0” 2.0” 4.0” L 6.57” 6.57” 6.57” 9.57” 9.57” 9.57” 9.57” 9.57” 9.57” 9.57” 9.57” 9.57” B 3.8” 3.8” 3.8” 3.8” 3.8” 3.8” 5.5” 5.5” 5.5” 7.6” 7.6” 7.6” C 3.6” 3.6” 3.6” 6.6” 6.6” 3.6” 6.6” 6.6” 6.6” 6.6” 6.6” 6.6” Module Rack CCM13S CCM13S CCM13S CCM14S CCM14S CCM14S CCM15S CCM15S CCM15S CCM18S CCM18S CCM18S Card Guide CG2-65 CG2-65 CG2-65 CG2-95 CG2-95 CG2-95 CG2-95 CG2-95 CG2-95 CG2-95 CG2-95 CG2-95 Card Guides Free Standing Connector Mounted Card Guides Secure connection, rugged support of 0.062” thick, free standing circuit boards. For applications in which space is at a premium. Several sizes and styles available. Aluminum alloy construction. Mounting hardware included (HD55 Hardware Kit) Part No. BR27D Use With Connector R644 A B C D .60” 2.96” .47” .25” For Use With 4.5” wide Plugbords with centered contacts, such as Vector 3677, 3682 and 3662 series Typical BR27 mounting (Ordering Table see page 37) A Fine Technology Group Specifications subject to change without notice Subracks - VectorPak For Modules ® 39 Module Subracks CMA Module Racks These cages provide attractive, sturdy, and mechanically excellent housing to enclose electronic assemblies. These units have the benefits and features of custom enclosures without the expense. • • • • • EFP modules feature aluminum extruded sides to accept PC cards. Extended front panels on modules allow thumb screw locking of module to subrack for easy insertion and extraction. The extended front panel also provides an attractive appearance. Side panels fasten to sturdy Vector TSW model (1.75” wide) Struts with two screws. Subrack models accept widths of 1.6”, 2.0”, and 3.0” EFP modules; 4.5” module optional. Rear struts are adjustable in width and height. (Ordering Table see page 37) EFP Modules • • • • • • • EFP204A66F 2” EFP Module with HA11 Handle Extended front panels provide thumb screw mounting & flush fit from module to module & with strut line. Modules provide shielding; H.F. shielding optional Front panels may be customized -cutouts, print ing & color. All covers have locking detent; slides out of groove when released Supplied in Kit form Modules with 6.5” depth accept 4.5” x 6.5” cards Modules with 9.7” depth accept 4.5” x 9.6” cards For Side Panels & Mounting Hardware see page 41B Part No. EFP164A66 EFP164A97 EFP204A66 EFP204A97 EFP304A66 EFP304A97 EFP454A66 EFP454A97 P/N HA11/2 Kit Type F L W1 W2 H1 H2 EFP164A66F EFP164A97F EFP204A66F EFP204A97F EFP304A66F EFP304A97F EFP454A66F EFP454A97F 6.5” 9.6” 6.5” 9.6” 6.5” 9.6” 6.5” 9.6” 1.65” 1.65” 2.05” 2.05” 3.05” 3.05” 4.55” 4.55” 1.31” 1.31” 1.71” 1.71” 2.71” 2.71” 4.21” 4.21” 5.22” 5.22” 5.22” 5.22” 5.22” 5.22” 5.22” 5.22” 4.62 4.62” 4.62” 4.62” 4.62” 4.62” 4.62” 4.62” Handle Full Rear Panel Piece Parts Front F Rear Panel# Cover Cutouts FP16-52 BP13-4 BP13-4F FP16-52 BP13-4 BP13-4F FP2A52 BP17-4 BP17-4F FP2A52 BP17-4 BP17-4F FP3A52 BP27-4 BP27-4F FP3A52 BP27-4 BP27-4F FP3A52 BP27-4 BP27-4F FP45A52 BP42-4 BP42-4F Pkg 2 11115 Vanowen St., North Hollywood, CA 91605 Phone (818) 985-8208 Toll-Free (800) 423-5659 Web site: http://www.vectorelect.com A Fine Technology Group Subracks • • • CMA13-20/90 Module Subrack shown with eight 2” wide EFP Modules (sold separately) 1.6”, 2.0” and 3.0” evenly spaced modules are accepted Side Panels -double screw attachment to wide TSW \ (1.75”) metal strut Rear Struts-adjustable in width and height-BR16-1 bracket Special aluminum extruded case guides and spacers provide secure mounting for modules Standard 19” width. Other widths available by special order. Filler panels available where mixing widths creates gaps Aluminum construction Paint or color anodize options available 40 Subracks - VectorPak® Card Guides Card Guides Subracks Tapered slot, snap-in card guides provide easy installation/removal High quality card guides feature tapered slots for easy insertion. Snap-in nylon models provide easy installation and removal without tools, and can be positioned at 0.25” increments when used with Vector-Pak Tstruts (TS169-6/90). Screw-mounted models (installation hardware included) are available in metal or plastic and provide variable positioning along entire length of strut. Holes for mounting guides to struts are based on center-to-center multiples of 0.75”. All materials are flame retardant. Metal or plastic screw down card guides attach with SC4-27/25 flat head screw and NT4-7PA square nut Card Guide Ordering Table Part No. Type CG2-45P CG2-45S CG2-50P CG2-65M CG2-65P CG2-65S CG2-80M CG2-80P CG2-80S CG2-95M CG2-95P CG2-95S CG2-135M Plastic, Screw Nylon, Snap-in Plastic, Screw Metal, Screw Plastic, Screw Nylon, Snap-in Metal, Screw Plastic, Screw Nylon, Snap-in Metal, Screw Plastic, Screw Nylon, Snap-in Metal, Screw Length Centers Card Length 2.89” 3.17” 4.36” 5.42” 5.42” 5.42” 6.64” 6.64” 6.93” 8.14” 8.14” 8.43” 13.19” 2.25” 2.25” 3.75” 4.50” 4.50” 4.50” 6.00” 6.00” 6.00” 7.50” 7.50” 7.50” 12.55” 4.50” 4.50” 5.00 6.50” 6.50” 6.50” 8.00” 8.00” 8.00” 9.50” 9.50” 9.50” 13.50” Application Subrack series 12, 13, 14, 17, 18 & 100 and Vector P series sidewalls Subrack series 14, 15, 17, 18 and 100 and Vector P series sidewalls ending in 119 or 156 CCA19 Packages of 12 ea. Screw-down types include installation hardware and are available in custom lengths on request. A Fine Technology Group Specifications subject to change without notice Requires .156” hole Snap-in Guide and TS169-6/90 Strut
CCK17S/90 价格&库存
很抱歉,暂时无法提供与“CCK17S/90”相匹配的价格&库存,您可以联系我们找货
